Old 11-30-2011, 12:35 PM   #181
Tabushi's Avatar
Send a message via AIM to Tabushi Send a message via Yahoo to Tabushi
What alternatives on BATTERIES you have in the market ?, any LIFE that fits ?
thanks
Patricio "PATO" Concha
E-Mail : [email protected]
Facebook : http://www.facebook.com/patoconcha
Whatsapp : +56 9 66165085
Tabushi is offline   Reply With Quote
Old 11-30-2011, 12:45 PM   #182
YBSLOW's Avatar
Default Life battery
Originally Posted by Merrillizer View Post
I run a Hyperion G3 life 850mah in my V10, enough for 45minutes, weighs under 50 grams
This was posted a couple of pages back. I got some off ebay and they fit well.
YBSLOW Racing
RC Target - Capricorn
HOTRACE Tyres, Tru Source, Fantom
POWER MASTER Fuel, 2mm Designs
Protoform Bodies, Avid Bearings, AMR Engines
YBSLOW is offline   Reply With Quote
Old 12-01-2011, 07:34 AM   #183
Tabushi's Avatar
Originally Posted by lil-bump View Post
I run Serpent diffs(733TE). Make sure you did not overfill the diff. If the diff becomes pressurized from over filling it will leak. Does it leak until empty is the question???
Pass you soon...
Serpent diffs are a direct fit ?, or mods required ?
Old 12-01-2011, 09:22 AM   #184
lil-bump's Avatar
Trader Rating: 83 (100%+)
Don't get me wrong. I do not run a shepherd car. I have no clue if a serpent diff will fit in a shepherd 1/10 sedan. I would think not; because of the unique brake system on the V10/V11. The point I was trying to make is that with serpent diffs "in a serpent car" if you I overfill the diffs they will leak.
Sorry for the confusion.
Pass you soon...
Elliott Hart
Serpent America
Desoto Racing Team
Chicky fan club member #9
One Eighth Racers of Toledo
lil-bump is offline   Reply With Quote
Old 12-01-2011, 01:47 PM   #185
Vasilis's Avatar
Originally Posted by G87z View Post
What size screws did you switch to? The standard is 2x6. I went to a 2x8. I have found that if you over tighten the diff cover it deforms and then it leaks no matter what you do. I have just started to replace the diff housing every 2rebuilds or so. Also after you build the diff you can place a thin line of CA on the outside of the housing right on the portion of the seal that you can see. Also always replace the seal each time you do a rebuild.
It is funny you brought this up as I just replaced my diff housing last night.
I had some 2.6x8mm screws and decided to use them. For sure my diffs have deformed as the car was used only a couple of times when it was first released and it's been a shelf queen ever since.
Shepherd Velox V8 eleven - RB C10
Shepherd Velox V10 - RB T10RC
Xray XB9 - RB BXR
Vasilis is offline   Reply With Quote
Old 12-02-2011, 12:28 PM   #186
Default Team Shepherd America
There has been alot of rumors in regards to Team Shepherd America and Team-Shepherd Germany splitting. The rumors have ranged from Team Shepherd deciding not to work with us and back. We are posting to clear this it was Team Shepherd America's decision to make this change. Team Shepherd America has decided that it would not be in the best interest of both parties involved to continue the relationship with Shepherd Germany. It was a decision that we at Shepherd America did not take lightly to come to this decision to discontinue. But there was no solution. Team Shepherd America discontinued relations yesterday. Team Shepherd has been very good in regard's to this as they are working with a new party at this time. We at or in no way are splitting up in a bad way. Just differences were not able to be resolved to our liking. Shepherd has a very good chassis and also very good design. We do not want people to be concerned about the parts supply as it will be seamless with this. We wish all the Shepherd Drivers the best of luck as well as Shepherd Micro Racing Germany the best.
We apologize for any concerns that have came as well as worry. Please do not be concerned you will be supported.
[email protected]
ShepherdAmerica is offline   Reply With Quote
Old 12-08-2011, 06:06 PM   #187
Default life batteries
i seen this battery pack on border online shop was wondering if it would fit in the v10 avionics life rx pack 6.6 v 1300 30c part# ori60503 dimension 70x36x21mm
weight 92g
bigtee is offline   Reply With Quote
Team Associated TC5 RCknight Electric On-Road 13256 12-15-2017 05:13 PM
Shepherd V8 '09 Josh Cyrul Nitro On-Road 400 10-13-2011 07:09 AM
2009 Great Lakes Challenge "GLC" presented by Shepherd Micro Racing Brian Berry Nitro On-Road 164 08-10-2009 07:44 AM
