Closed Thread
Old 06-03-2011, 09:32 AM   #46
Jspeed's Avatar
Clete,
Sometimes a car will need to be run with different shores from front to back for even balance & wear. They can also even out rubber temps on all four corners. Once you figure what works on you track, your slicks will last you twice as long and your car will be more fun to drive & race.
Jspeed is offline
Old 06-03-2011, 10:18 AM   #47
Clete Landefeld's Avatar
Originally Posted by Jspeed View Post
Clete,
thanks Jeff....
I know troy found some of your tires to test... we all are stoked to see the fatties on the back... we have a fantastic track... it is a little abbrassive... but none the less, fantastic. I would still like to find a little more mechanical grip... it will come with time.. Now that the weather is warm.. we can make changes and really make some headway.. I want to try the to find a little more on power steering..
Clete
SnotRocket Racing, Team TimeZone, Kamikaze Toys and Hobbies, McKune Design, RC Plus... Thanks for all the help guys!
Clete Landefeld is offline
Old 06-03-2011, 02:52 PM   #48
mgodson's Avatar
Default Let's Keep it Growing!
Originally Posted by Clete Landefeld View Post
http://usgtnats.sports.officelive.co...ventRules.aspx
Easy and Even accross the nation....
Nice to see guy's focused on having fun. Let's keep it that way! Make a point of helping the new guy, keep the racing close, and don't forget to laugh.
See you ONROAD,
Godson
mgodson is offline
Old 06-03-2011, 06:57 PM   #49
I agree with jspeed, sometimes different shores help a lot in leveling grip front to back so tires last longer.
jneg is offline
Old 06-05-2011, 04:16 PM   #50
T-Hawk's Avatar
Default Brake Pads?
The word is Ofna is discontinuing part#OFN36659. The upgraded brake pads. Does anyone know of an upgraded replacement pad?
T-Hawk is offline
Old 06-06-2011, 08:24 AM   #51
Use the Kyosho.. get the sintered pads... that what I use and it works fine... ask Tom Camou
Clete
Old 06-06-2011, 08:52 AM   #52
T-Hawk's Avatar
Part# ifw324?
T-Hawk is offline
Old 06-06-2011, 09:01 AM   #53
Part# ifw324?
ummmm..... looks like the right ones... we will have to dremel the holes a little.. but ... should be fine..
Clete
Old 06-06-2011, 10:09 AM   #54
I use RC8FT brake pads and they work perfectly. You do have to use the dremel but it is worth it. It doesn't needs pads so you can use the metal "pads". They last a long time as well with no fading due to heat.
jneg is offline
Old 06-06-2011, 10:09 AM   #55
T-Hawk's Avatar
Well, is that the part# you used?
T-Hawk is offline
Old 06-08-2011, 08:27 PM   #56
yep this is the number.... let me know if you need some help with the modification
Clete
Old 06-09-2011, 09:59 AM   #57
36659 is not Discontinued. Some suppliers may have discontinued stocking that item.
D Starks is offline
Old 06-09-2011, 10:20 AM   #58
D,
Is there a source that you would recomend....that actually has them in stock.... Let us know, thanks...
Clete
Old 06-09-2011, 10:34 AM   #59
Check RCBOYZ.com. I know they have them for the DM. If all else fails , p.m. me and I can send some from our shop here. I have those in stock.
People spend their lives worrying about death. I'm sliding in broadside h ollering "Wow, what a ride"
spooky 1 is offline
Old 06-09-2011, 10:37 AM   #60
Nitro house is the best place to get Ofna parts, I think they stock them all.
williamw is offline
Closed Thread
GT class--buggy-based on road! duneland Nitro On-Road 9643 11-16-2016 04:11 AM
The Big Locked Thread donitaROSE Manila Racers 89718 03-26-2015 08:17 AM
2010 Great Lakes Challenge - Toledo, Ohio Brian Berry Nitro On-Road 238 03-10-2011 08:36 AM
