Old 09-26-2004, 02:42 AM   #1
Send a message via AIM to CheckkYaaSelff
Default I WANT TOP SPEED! I'm Confused?!
Hey guys i own a yokomo GT4. I've read around about pinions and gears but still confused cause i've been reading mixed anwers and need some answers.
So If i wanted top speed the best gearing combo would be Highest pinion and smallest spur gear is this correct? Would this apply to both 1st gear and second gear? And if i wanted bottom end it would be the other way around? Thanks
CheckkYaaSelff is offline   Reply With Quote
Old 09-26-2004, 02:47 AM   #2
Default Top Speed
Spot on, just remember not to gear it too tall.
opposite lock is offline   Reply With Quote
Old 09-26-2004, 03:25 AM   #3
Is 16/47 and 20/44 ok?
Also another question with the yokomo response pulley kit which is 26T front pulley, 16T rear side pulley, and 18T drive pulley would this cause less top speed? Would it be better to remove the response pulley kit to 23T front pulley, 19T rear side pulley, and 23T drive pulley to obtain more top seed? Any pros and cons or anything i should be aware about of changing pulleys, pinions, and spur? and what do you mean not to tall? Sorry I've only been in this hobbie for about 3 months now. Still learning.
I know that for track its better to have bottom end but i just want to see the top speed for my RC. I have 2 rear suspension so i can swap it out for track and parking lot bashing.
Old 09-26-2004, 03:39 AM   #4
Your pinion teeth difference is 4 but your spur teeth difference is only 3.
They will mesh better if you maintain the same teeth difference.
Old 09-26-2004, 03:45 AM   #5
Oh I get it. Alrighty thanks. Do you know the answer to the other question i asked about the response pulley set?
Old 09-26-2004, 04:00 AM   #6
Unless you are running different diameter front/rear tires,I would stay with the standard to maintain equal traction on all 4 corners,
and adjust the pinion/spur configeration to obtain your top speed
Old 09-26-2004, 04:11 AM   #7
edit: NVM i found the answer. Thanks for all your help!
Old 09-27-2004, 12:12 PM   #8
tomkelley's Avatar
That pulley set is meant for short tracks, and changes the internal drive ratio from 2.000 to 2.555 for greatly improved acceleration. However your top end speed will now be greatly reduced, so use the stock pulley set for more top end speed.
Detroit Radio Control Car Club
www.drccc.org
tomkelley is offline   Reply With Quote
I'm New And Confused!!! shaunmotyka Nitro Off-Road 2 02-19-2008 03:03 PM
13.5... anyone confused yet? racer34v Electric On-Road 46 07-04-2007 08:04 PM
Confused kjkiller Monster Trucks 2 07-16-2006 09:37 AM
confused JIMCAR Nitro On-Road 8 03-31-2006 08:14 PM
Im confused!!! Dirtfreak15 Rookie Zone 13 12-27-2004 09:41 PM
