Old 09-25-2004, 01:52 AM   #1
Default Best tires for these conditions?
mostly blacktop/asphalt racing, i assume thers some pebbels, and usually very tight turns at full speed sending my ntc3 spinning..
your thoughts? the stock tires that came with it fall off with the highspeed cornering, i hope thats not the case with the pre-glued foams i'm thnking of buying
Skoob is offline   Reply With Quote
Old 09-25-2004, 03:51 AM   #2
Rapid Roy's Avatar
Did you glue your tires on? Usually the kit tires are too hard for racing. Not enough grip. Foams would work as long as the surface isn't too dusty. Sorex or take offs are the most popular rubber tire locally.
Rapid Roy is offline   Reply With Quote
Old 09-28-2004, 02:16 PM   #3
R/C Tech Charter Subscriber
You can also check out Twister Tires. Great traction and wear at a great low price.
www.twistertires.com
racinghobbies is offline   Reply With Quote
Old 10-04-2004, 07:16 AM   #4
Pyramid's Avatar
Default Re: Best tires for these conditions?
If it is parking lot racing you are talking about, I believe you wanted tire with more rubber 'packed' in the foaming process. I know speedmind makes that kind which resist more on wear (and chunking since they are harder). On permanent track, those too much rubber packed does not perform well and inconsistent in my opinion. And you should know, only where the tires manufactured from that differentiate its final selling price. The foams are all coming from the same source
Pyramid is offline   Reply With Quote
Old 10-04-2004, 07:27 AM   #5
Slotmachine's Avatar
Send a message via MSN to Slotmachine
Try some GQ Tires $8.99 per pair use the 37 srore front and rear to start. Go to WWW.RCTEXAS.COM $3.95 flat rate shiping, and they have cool looking orange rims too!!!!!
HOBBYWING NORTH AMERICA /FALCON SEKIDO/ TEKNO RC TEAM/VBC Racing America/VP-PRO RACING TIRES/2010 R.O.A.R. VTA National Champion Driving a T2R PRO/NANO-TECH Batteries Paul Rush
Slotmachine is offline   Reply With Quote
Old 10-04-2004, 07:43 AM   #6
Pyramid's Avatar
I'm glad I took more time before start promoting GQs
Old 10-04-2004, 08:49 AM   #7
Default what?
What are you talking about?
Old 10-04-2004, 11:38 PM   #8
Pyramid's Avatar
Default Re: what?
It is obvious someone has promote his brand of tires on this threat first and I feel a bit leary to jump after the post for another tire brands promotion.
Old 10-05-2004, 06:53 AM   #9
Default Well!
I do believe the question was, what is the best tire for these conditions? I`m just offering some friendly advice and oppinion, not trying to be nasty.
Old 10-05-2004, 08:32 AM   #10
Pyramid's Avatar
right on........
Old 10-05-2004, 09:05 AM   #11
Sow&Steady's Avatar
Default Re: Well!
Don't worry. Pyramid is happy ... he promotes them orange rims ferociously!
http://3hobby.net REVISITED V2 - Its on steroids!
https://www.facebook.com/ssteady
Sow&Steady is offline   Reply With Quote
Old 10-05-2004, 09:51 AM   #12
Suspended
I LOVE GQ TIRES!!
SERPENTFREAK69 is offline   Reply With Quote
Old 10-18-2004, 06:53 AM   #13
Pyramid's Avatar
X-RAY T2 -007 IMMACULATE conditions EZRC R/C Items: For Sale/Trade 0 01-29-2008 07:18 PM
1/10 Practice in Frosty Conditions Skiddins Electric On-Road 6 03-15-2007 03:31 PM
What to get to keep bashing in good conditions? milen Rookie Zone 3 12-07-2005 05:42 PM
On- raod track conditions axel Chat Lounge 2 05-06-2005 04:27 PM
Battery conditions for different classes. axel Electric On-Road 2 04-18-2005 09:30 PM
