Old 02-04-2005, 09:09 AM   #1306
Hi guys!
I have a question concerning the RRR which I acquired recently, I feel that there may be a problem with the fuel tank,but I am not sure.
This is what happened: At our local track ,after the straight there is a big right hand sweeper and then a left hand turn onto a fast chicane. My engine which is properly tuned just go a little bit lean each time after the car finish negotiating the sweeper. The problem does not end there , the track also has a slow left hand turn on the other side ,this time the engine just go rich(also everytime i negotiate this left turn). I have checked the fuel tank but it does not leak.
I also notice that after the fuel in the fuel tank drop to a lower level, say somewhere in the mid mark, the engine goes leaner but sometime it returns to normal again.The engine in this car just fluctuate so much.Previously with my two other cars(one is a Mugen), I have never encounter such problem at all.
Hope you guys can help! Thanks!
air world is offline   Reply With Quote
Old 02-04-2005, 03:11 PM   #1307
Send a message via Skype™ to JordanC
Originally posted by Marcos.J
thats what i do know i was just trying to make it easier
with the Kyosho springs the rates all change from the beginning of compression to coil bind. You are better off just comparing two springs by puhing them toghether and looking at the difference there.
JordanC is offline   Reply With Quote
Old 02-04-2005, 05:47 PM   #1308
InitialD's Avatar
Originally posted by air world
Hi guys!
A suggestion perhaps? Have you tried to use a pressure chamber from the tank to the pipe or a longer fuel tubing connecting the tank and pipe?
I think this commonly happens on 1/8th scale engines especially after coming out of a fast sweeper... The regulated pressure from the pressure chamber should help to maintain pressure from the pipe to the tank to get a more reliable idle.
Old 02-04-2005, 06:01 PM   #1309
afm
afm's Avatar
Any one has the part number of option that converts Kyosho's front diff on to solid axle????
AFM
afm is offline   Reply With Quote
Old 02-04-2005, 07:18 PM   #1310
Thanks Initial D, I did install one but still it didn't help
A friend of mine who also bought a RRR also suffer from this problem. Whenever the fuel level drops to a certain degree, the engene gets faster and faster,then suddenly it becomes ok again
Old 02-04-2005, 07:40 PM   #1311
jeffreylin's Avatar
R/C Tech Charter Subscriber
It's a common RRR problem--there is an air leak in your tank. Replace it and the problem should go away. However, to avoid this to happen again, you should get the new upper deck (read my post a few pages back) and that should help.
jeffreylin is offline   Reply With Quote
Old 02-04-2005, 08:44 PM   #1312
Thanks Jeffreylin! I have checked and rechecked the fuel tank, but I could not find any air leak. Even after running the car, I could not find any trace of fuel seeping out of the tank,especially at the mid mark where the two halves joint.
I notice something which I am not sure whether its of any significance: When I gun the throttle,bubbles or foams start to form in the tank(this should be normal,I think). But as soon as i let go of the throttle, a very big bubble will erupt from the bottom of the tank,particularly at the fuel inlet point.Is this normal?
Old 02-04-2005, 08:54 PM   #1313
anyone going to the winternats with the kyosho rrr who has the new radio tray. if you have an extra and will sell please let me know. please call me at 305-807-9529. i am leaving tomorrow morning so will not be able to check replies after tomorrow. thanks.
Joe Chaplow is offline   Reply With Quote
Old 02-04-2005, 10:49 PM   #1314
Super Moderator
Marcos.J's Avatar
Trader Rating: 182 (100%+)
AFM
easy shoe gloo
Old 02-05-2005, 12:30 AM   #1315
Dynamite's Avatar
Send a message via MSN to Dynamite
Originally posted by JCB
when will the world's edition be out??
already had mine for a week, just finished building it today first race day tomorrow, well taking it easy anyway lol
make sure you got servo horns because it does not come with any, and there was not enough shims in the kit to do the clutch properly, just two little annoyances - was the regular rrr kit the same?
other then a few niggles the car looks great and should prove to be a rocket ship
Dynamite is offline   Reply With Quote
Old 02-05-2005, 12:37 AM   #1316
Bundy_Bear's Avatar
Has anyone heard anymore about a rubber version V1RRR being available?
BB
MissMooRC Racing
Find us on Facebook https://www.facebook.com/missmoorc
Bundy_Bear is offline   Reply With Quote
Old 02-05-2005, 01:16 AM   #1317
BrainTeased's Avatar
You do not need a new tank, but you need the new upper deck (or file the holes on your existing upper deck so it's about 5mm long in the front and 4mm long in the rear).
Hi Jeff may i ask what holes am i suppose to file?
www.feralbatteries.com.au
BrainTeased is offline   Reply With Quote
Old 02-05-2005, 01:32 AM   #1318
NiMo's Avatar
Could be your tank is fitted too tightly and is affected by vibration
NiMo is offline   Reply With Quote
Old 02-05-2005, 01:37 AM   #1319
NiMo's Avatar
BB
Kit No. 31257, was released in November.
Old 02-05-2005, 01:41 AM   #1320
Bundy_Bear's Avatar
NiMo:
Do you have any idea where there are available online?
BB
MissMooRC Racing
FOR SALE - Mugen MBX5T ProSpec and Kyosho STR with chassis conversion and Kyosho big MattWells R/C Items: For Sale/Trade 5 04-28-2017 10:25 AM
1986 1/12 Kyosho Plazma MKIII With Kyosho LeMan 600E Motor Funkymojo R/C Items: For Sale/Trade 2 05-17-2012 11:11 AM
Custom painted Kyosho SP2 and Kyosho STRR bodies.... RC3 Graphics SWEET W/ PICS CRFXXXT R/C Items: For Sale/Trade 1 01-07-2008 07:38 PM
MACH. 28/NEW PS, KYOSHO MINI INFERNO ST/W/3NEW IB1400 8 CELL PACKS, KYOSHO 1./8 BUGGY newbie2 R/C Items: For Sale/Trade 5 11-18-2007 06:07 PM
Convert Kyosho Quick Start system on Kyosho QRC to Pullstart Morpheus2be Monster Trucks 0 02-16-2005 11:26 PM
