Kyosho v-one rrr
#1292
Re: Kyosho USA
Originally posted by dougday
Does anybody have any information on the opening of Kyosho Distributorship in the USA?
I have heard it said that Kyosho would be doing their own Distribution in the USA shortly. Is there anybody here who has any information about this ?
towerhobbies is big but is kinda slow on getting the new stuffs
#1293
V-One RRR
I am looking at picking up a couple RRR kits and spares. Who has the best prices around? I saw that www.rcsquare.com was at $350.00 US.
Would love some input from you guys...
J
J
#1294
Kyosho USA
I beleive that Great Planes is handling distribution in North America for Kyosho.
However it seems that at the moment there is a big discrepancy in price compared to the rest of the world market.
#1295
Re: Kyosho USA
US is a lot cheaper than Europe.
#1296
Re: V-One RRR
J
J
http://www.pro-s-futaba.co.jp/
29,400 yen when i ordered mine last december
#1297
when will the world's edition be out??
#1298
Correction:
Pro-Shop had them on the 27th Jan 37100yen
#1299
Originally posted by NiMo
not sure about lbs, but the part numbers indicate the pressures.
1st 2 the winds, 2nd 2 the pressure.
3517 = 3½ turns and 1.7 pressure.
So 3517 = 3.5 turn of 1.7mm wire.
Unfortunately it does not give you the lb/in.
#1300
The first number is the number of active coils(full coils) and the second number is the outer diameter of the wire(in certain cases this is after the paint has been sprayed on the pastel colored springs).
#1301
I remember reading some kind of formula to calculate the spring weight. Something like (number of active coils) x (inner diameter of wire)(outer diameter of wire).
#1304
Originally posted by JordanC
Who really cares??? As long as your car is handling
All I do is decide if I want to go harder or softer, then place two different springs end to end then squash them to check the pressures.
