Old 01-24-2005, 10:00 AM   #1171
the 3racing has an aluminum brake pulley. i have it. is this what you guys are talking about?
Joe Chaplow is offline   Reply With Quote
Old 01-24-2005, 10:35 AM   #1172
Francis M.'s Avatar
I finally took the rrr for a full day of racing. this car just has so much corner speed. The car was pretty stock except for Kyosho front universals, Skyline 4mm rear shock tower, and I think the most trick peice is the Skyline exhaust wire bracket.
After missing almost two months of racing and the first full day with this car, now i get what every body has been raving about. This car is just as good as advertized.
TQ-racing Yokomo BD7 Airtronics
Francis M. is offline   Reply With Quote
Old 01-24-2005, 04:10 PM   #1173
jeffreylin's Avatar
R/C Tech Charter Subscriber
Default Re: Re: Re: Re: Re: Re: Re: RRR WC edition
Originally posted by 3434
Jefferylin, are they still in business?? I can't get in touch with them. They don't answer e-mails, they haven't sent my parts and/or they haven't refunded my account.
i just visited them yesterday. i don't know why you cannot get in touch with them as no one else seems to have problem with them.
jeffreylin is offline   Reply With Quote
Old 01-24-2005, 04:19 PM   #1174
Data's Avatar
you beat me to it again, mine still sitting on the shelf collecting dusts.
made an al. brake holder, let me know if you want to use it. i won't be needing it for a while yet.
data
Data is offline   Reply With Quote
Old 01-24-2005, 04:32 PM   #1175
Francis M.'s Avatar
data
thanks Billy
Old 01-24-2005, 04:45 PM   #1176
I've been breaking in my RRR on our small local track. I'm really impressed so far. It has great steering with a stable rear end. I played with the solid front and like it a lot. The car was very controllable, even on our low traction surface. I'm curious to see how the solid works on large smooth tracks with higher traction.
Btw, I got some Eagle Racing MTX-3 universals to work. I'm waiting on some Kyosho universals. Had to use the mugen drive hexes (smaller axel diameter) and made some shims to take up some gap between the drive hex and outer bearing.
Surge is offline   Reply With Quote
Old 01-24-2005, 06:26 PM   #1177
Registered User
junito yukiyu's Avatar
Send a message via MSN to junito yukiyu
Default ..
i,ve been trying to put the stupid diff on mine and the akerman is giving me hell , I NEED HELP!! , if any body knows a trick or something , plesa share it!!
junito yukiyu
junito yukiyu is offline   Reply With Quote
Old 01-24-2005, 06:34 PM   #1178
AndyT 's Avatar
Traj....
Thanks for posting that email reply from Skyline racing, I`ll be getting in contact with them to get that exhaust wire etc.
Did you run the RRR at Kambah for the Summernats? If so, how did it go?
Was that your name i saw on the frequency board at Moorebank last weekend? ..... if so, how have you found the RRR performs around Moorebank. I`m still building mine up but currently running a FT NTC3 which i think Moorebank is just too big a track for....its quite good on smaller ones ala Eastern Creek.
Thanks.
Cheers
AndyT  is offline   Reply With Quote
Old 01-24-2005, 06:50 PM   #1179
Default Re: ..
junito yukiyu
Try sanding down the ball cups on the steering block until it clears the diff housing.
Running a solid, I might try sanding down the housing to keep my steering ball cups entact. But I wouldn't do that with a diff for fear of leakage.
Old 01-24-2005, 07:05 PM   #1180
TRAJ's Avatar
Originally posted by AndyT
Traj....
Thanks.
Cheers
hey Andy yer i did race at Kambah
i did 16-17 laps in the first 2heats and the 3rd heat only 6 (couldnt get the engine going) and ended up coming 3rd in the D final.
Nah i havnt run the RRR at Moorebank yet but i am very excited to
yer when i had my FW05R also shaft drive it just cant take the size of moorebank even with 37T ring gears
TRAJ is offline   Reply With Quote
Old 01-24-2005, 07:14 PM   #1181
InitialD's Avatar
Are you sure? Well, if you have problems with FW05R gearing on your track, then you will also have problems with the RRR...
Old 01-24-2005, 07:19 PM   #1182
TRAJ's Avatar
My RRR is geared way better and the other RRRs at my track do very well.
The FW05R was quick out of the corners but down the main straight wich is like 50m or so it was laking top end and this was with a Murnan NS great gearing and clutch/2speed setting.
Old 01-24-2005, 07:22 PM   #1183
InitialD's Avatar
Perhaps as with all FW0RR guys, that was their initial problem. Something to do with the pipe...
Old 01-24-2005, 07:25 PM   #1184
TRAJ's Avatar
hehehe i had a RBv12 inline pipe set part number #01751-402K http://www.rbproducts.com/mainEn.php...oudes_inline12
and still wasnt get the speed i wanted
Old 01-24-2005, 08:50 PM   #1185
Default Re: Re: Re: Re: Re: Re: Re: Re: RRR WC edition
Thanks, thats a lot more then I am getting from them.
You have a PM
3434 is offline   Reply With Quote
FOR SALE - Mugen MBX5T ProSpec and Kyosho STR with chassis conversion and Kyosho big MattWells R/C Items: For Sale/Trade 5 04-28-2017 10:25 AM
1986 1/12 Kyosho Plazma MKIII With Kyosho LeMan 600E Motor Funkymojo R/C Items: For Sale/Trade 2 05-17-2012 11:11 AM
Custom painted Kyosho SP2 and Kyosho STRR bodies.... RC3 Graphics SWEET W/ PICS CRFXXXT R/C Items: For Sale/Trade 1 01-07-2008 07:38 PM
MACH. 28/NEW PS, KYOSHO MINI INFERNO ST/W/3NEW IB1400 8 CELL PACKS, KYOSHO 1./8 BUGGY newbie2 R/C Items: For Sale/Trade 5 11-18-2007 06:07 PM
Convert Kyosho Quick Start system on Kyosho QRC to Pullstart Morpheus2be Monster Trucks 0 02-16-2005 11:26 PM
