Old 01-12-2005, 07:26 AM   #1081
Ron C.'s Avatar
Default Re: Engine
Originally posted by bulletdays
Any Idea about problem in my engine?
hi, would anyone share his idea on this...
i changed my clutch, then after 2-3 runs in the track i tried to start my engine again, starting is normal as it goes to idle the way it is, but i notice that when i rev it the wheels are not moving i tried to rev it for about 5-7 times then it moves, but at first it wont move, i know this is not normal. I remove the plug and notice that there are a lot of unburned fuel inside... i can still run the car with a good performance, im just thinking why the wheels are not moving for several revs after starting.
wonder my Low end mixt is rich or lean, probably not the top end because i can feel it has a good top end with a light trail of smoke.
and i the engine smells different, maybe because of the unburned fuel... am i damaging the engine?
Does anyone have experience this? please i need your ideas...
Thanks in advance.
Hi bulletdays,
It sounds more like it's the clutch setting. Try Backing out the
Clutch Nut (thing that holds down the spring) little by little until
you find your clutch engaging where you like it to.
You may also want to make sure the end bell play is right.
Hope this helps.
Mugen Seiki / MSR / Airtronics / Enneti Tyres / O'Donnell Racing / Checkpoint / Hobbico
Ron C. is offline   Reply With Quote
Old 01-12-2005, 07:48 AM   #1082
Send a message via Yahoo to Jamea
What's up Ron, how is it going?
on the rrr I noticed that there is a lil play on the upper arm, is this ok or does it have to be shimmed?
Jamea is offline   Reply With Quote
Old 01-12-2005, 08:57 AM   #1083
Ron C.'s Avatar
J !
I am doing good, thank you.
How about you my friend, how have you been?
Yeah, it's typical to find some play on the Upper Arms. I also found
some on the rear lower arms and likewise on the others. Kyosho
has a shim set which we use. Get the Kyosho Manufacturer Stock #96641.
Hope this helps.
When you get a chance, please send me an email on how things
are going in your end of the Globe. Also looking forward to seeing
you again soon.
Old 01-12-2005, 10:22 AM   #1084
uaerc's Avatar
Default Re: Re: Engine
Originally posted by jwf-ronni
Hi bulletdays,
Hope this helps.
Hi
yeah thats what i feel..i kind of had the same problem... when i was more of a rookie.... took it tot he LHS.... Hobby centre.. have you heard of it.. take it to them ... they will fix it...
cheers
ziizo
uaerc is offline   Reply With Quote
Old 01-12-2005, 04:27 PM   #1085
Brake Problem-
I seem to have managed to strip the plastic diff pulley which is keyed for the brake disc to sit on,
Does anyone hav any suggestions on how this may have happened and what settings etc. do I need to check to ensure it does not happen again.
Cheers
Dickie
Dickie is offline   Reply With Quote
Old 01-12-2005, 09:14 PM   #1086
Racing4Evo's Avatar
Send a message via AIM to Racing4Evo
That happened to me too. I guess that the brake disk heated up and melted the plastic. I haven't had problems with the second one I put it though. At any rate, Kyosho makes an aluminum one which I will be getting shortly.
Racing4Evo is offline   Reply With Quote
Old 01-12-2005, 10:57 PM   #1087
bulletdays's Avatar
jwf_ronni - Thanks a lot i will try that!
uaerc - yah i know that LHS, but seem to be very bz all the time, but in anyway that would be the last option... thanks...
bulletdays is offline   Reply With Quote
Old 01-12-2005, 11:35 PM   #1088
jeffreylin's Avatar
R/C Tech Charter Subscriber
Hey Peter, SoCal or Revelation this weekend?
jeffreylin is offline   Reply With Quote
Old 01-13-2005, 12:08 AM   #1089
Racing4Evo's Avatar
Revelation! It's about time the rain stopped!
Old 01-13-2005, 12:48 PM   #1090
Send a message via ICQ to SpeedsterRRR
Hey guys! I would like to make a small question. I replaced the front one-way diff with the regular diff, as a solid axis.
However, even in the tight position for the belt, the diff makes contact with the ballcups of the steering system!!! Anyone had that problem? What can I do? Am I doing something wrong?
(I used the diff case provided in the original package)
SpeedsterRRR is offline   Reply With Quote
Old 01-13-2005, 01:02 PM   #1091
See my post on page 31 dated 12-16-04
Kyofan
Kyofan is offline   Reply With Quote
Old 01-13-2005, 06:09 PM   #1092
Is there a spring set for the RRR? If there isn't, what part numbers should I be looking at to compile a spring set? I'm at rcmart.com but there seems to be two types of springs and I don't know which go with the RRR.
Dave
DaRollaRacer is offline   Reply With Quote
Old 01-13-2005, 06:40 PM   #1093
Ron C.'s Avatar
Dave
Dave,
You would look for Kyosho Manufacturer Stock # :
- VZ072-3517 Front Silver 3x1mm
- VZ073-4516 Rear Silver 4x1.6mm
- VZ072-3017 Front Black 3x1.7mm (Comes with the car kit)
- VZ073-4016 Rear Black 4x1.6mm
- VZ072-2517 Front Gold 2.5x1mm
- VZ073-3516 Rear Gold 3x1.6mm (Comes with the car kit)
Hope this helps..
Old 01-13-2005, 07:14 PM   #1094
NR
NR's Avatar
Trader Rating: 52 (100%+)
Originally posted by Team-RTR
thats a very good idea.
I have a better idea F$%# OFF
NR is offline   Reply With Quote
Old 01-13-2005, 08:20 PM   #1095
I dont understand...
I regards to alternate pipe mounting positions...I was sold a topdeck mount and assured it would work for rrr but as mentioned before the mount was too long. Instead of mounting it under the deck I mounted ontop. And it is still protected by other parts on front stay etc. Doesnt quite look as slick as the topdeck under mount though. Oh well.
rcosmax is offline   Reply With Quote
FOR SALE - Mugen MBX5T ProSpec and Kyosho STR with chassis conversion and Kyosho big MattWells R/C Items: For Sale/Trade 5 04-28-2017 10:25 AM
1986 1/12 Kyosho Plazma MKIII With Kyosho LeMan 600E Motor Funkymojo R/C Items: For Sale/Trade 2 05-17-2012 11:11 AM
Custom painted Kyosho SP2 and Kyosho STRR bodies.... RC3 Graphics SWEET W/ PICS CRFXXXT R/C Items: For Sale/Trade 1 01-07-2008 07:38 PM
MACH. 28/NEW PS, KYOSHO MINI INFERNO ST/W/3NEW IB1400 8 CELL PACKS, KYOSHO 1./8 BUGGY newbie2 R/C Items: For Sale/Trade 5 11-18-2007 06:07 PM
Convert Kyosho Quick Start system on Kyosho QRC to Pullstart Morpheus2be Monster Trucks 0 02-16-2005 11:26 PM
