Old 01-05-2005, 12:17 PM   #1051
kidDynomite's Avatar
Originally posted by ziggy12345
No. Use a sharp drill and place the deck on a piece of wood.
Cheers
Also run the piece under water first to keep the fiber dust to a minimum. Use a mask too fpr bigger c/f jobs like grinding or milling. Otherwise you'll be blowing black stuff out of your nose. Not good.
kidDynomite is offline   Reply With Quote
Old 01-07-2005, 08:41 PM   #1052
Doctor Danger's Avatar
Default front and rear shox
I was wondering about the placement of shocks on the front lower arm for the 3RRR...there s two options ....the kit one says to mount on higher hole wot happens if i mount it on the lower hole.
Doctor Danger is offline   Reply With Quote
Old 01-07-2005, 10:29 PM   #1053
your car will be doomed... j/k
Joe Chaplow is offline   Reply With Quote
Old 01-07-2005, 11:32 PM   #1054
uaerc's Avatar
Originally posted by NiMo
If I read you right, Drags is a straight line sprint, in this case there are other things to look at:
The FW05 is very quick off the mark but is heavier and can suffer from torque steer if the grip is not 100%
The RRR is lighter and wont have torque steer, but belt cars for some reason do not get off the blocks too quickly.
Which ever way you go you must have one-way and front overdrive so the front pulls the car straight with a little wheelspin.
Yeah its a straight line sprint....about 80 meters or so of track. I was thinking of geting the combination Josh used... 37 ring gears and 23/ 27 pinions with 45/50 spurs... on the FW05 !! that might make it a bit faster then the usual..
I have not yet played with my RRR yet.. so i am not used to the setup on this car. As you said earlier the gearings are diff on this car.// any fast gear combinations on this car which i should look at ?
By the way the track you race on has quite large striaghts u must be on 37 ring gears urself right. ... what pinions are you using.....
cheers
ziizo
uaerc is offline   Reply With Quote
Old 01-08-2005, 01:15 AM   #1055
rjl
rjl's Avatar
Default Re: front and rear shox
You need to fit the longer shock end and you will have slightly more leverage.
rjl is offline   Reply With Quote
Old 01-08-2005, 01:42 AM   #1056
NiMo's Avatar
cheers
ziizo
Main straight is 155ft (47m)
If I was running the Kyosho ring gears then yes it would be 37T, but I run the Kawahara ring gears, 45T both ends.
NiMo is offline   Reply With Quote
Old 01-08-2005, 07:14 PM   #1057
ianhobbies's Avatar
Location: Costa Del Sol, Marbella, Spain www.bradir.net
Send a message via ICQ to ianhobbies
Default RRR WC EDITION
according to rc magazine japan (yaesu) kyosho is releasing a WC edition model, any more info guys?
WWW.BRADIR.NET - The Radio Control Motorsport Blog! / twitter @ianhobbies
ianhobbies is offline   Reply With Quote
Old 01-09-2005, 12:19 AM   #1058
Trader Rating: 43 (100%+)
SKyline R/C Racing will release a new one that will not break your Upper deck. I will keep update with you guys.
www.skylinercracing.com
Originally posted by TRAJ
Thanks alot Ziggy
when you drilled it did the carbon flake or split?
monokenny is offline   Reply With Quote
Old 01-09-2005, 12:28 AM   #1059
Here is a picture
Old 01-09-2005, 12:55 AM   #1060
Team-RTR's Avatar
thats a very good idea.
SERPENT | NOVAROSSI | XRAY | TEKIN | FUTABA
Team-RTR is offline   Reply With Quote
Old 01-09-2005, 03:31 AM   #1061
Trader Rating: 47 (100%+)
A bit like the one I've made for my car.
TOP GEAR R/C
EAST COAST HOBBIES
Craig1 is offline   Reply With Quote
Old 01-09-2005, 07:31 AM   #1062
what is the need for a new muffler stay?
Old 01-09-2005, 07:53 AM   #1063
dameetz's Avatar
Default Re: Stripped 2nd spur gear
Originally posted by dameetz
I don't know whats wrong but eversince i changed from stock gearing I stripped my 2nd spur gear more often. This weekend alone I stripped 2 new 2nd spur gears. I m using 17/22and 23 with 60/55 spur gears. I aligned and realinged the mounting and using a piece of paper for a good meshing but still my 2nd stripped. Has anybody got this problem as well?
Can someone help me with the above mention problem? I stripped my 2nd spur again today I was using 17/23 and 60/55. I rechecked my motor mount it is still tight( not moving). Is my gearing ratio between 1st and 2nd jumped too much? If I m not mistaken this gearing ratio was used by the pros during the worlds.
Dudududududuuuuuu.....
dameetz is offline   Reply With Quote
Old 01-09-2005, 11:00 AM   #1064
NiMo's Avatar
Default Re: RRR WC EDITION
Some info here:
New Items
Old 01-09-2005, 12:53 PM   #1065
jeffreylin's Avatar
R/C Tech Charter Subscriber
Default Re: Re: Stripped 2nd spur gear
Check your second gear meshing again. It's kind of hard to check the second gear but you must make sure that it is tight. Also is your 2 speed working right? Is it shifting too late or too early? That might be a problem too.
jeffreylin is offline   Reply With Quote
FOR SALE - Mugen MBX5T ProSpec and Kyosho STR with chassis conversion and Kyosho big MattWells R/C Items: For Sale/Trade 5 04-28-2017 10:25 AM
1986 1/12 Kyosho Plazma MKIII With Kyosho LeMan 600E Motor Funkymojo R/C Items: For Sale/Trade 2 05-17-2012 11:11 AM
Custom painted Kyosho SP2 and Kyosho STRR bodies.... RC3 Graphics SWEET W/ PICS CRFXXXT R/C Items: For Sale/Trade 1 01-07-2008 07:38 PM
MACH. 28/NEW PS, KYOSHO MINI INFERNO ST/W/3NEW IB1400 8 CELL PACKS, KYOSHO 1./8 BUGGY newbie2 R/C Items: For Sale/Trade 5 11-18-2007 06:07 PM
Convert Kyosho Quick Start system on Kyosho QRC to Pullstart Morpheus2be Monster Trucks 0 02-16-2005 11:26 PM
