Old 01-02-2005, 01:12 AM   #1006
rjl
rjl's Avatar
Big clutch gap. Brilliant!
rjl is offline   Reply With Quote
Old 01-02-2005, 01:30 AM   #1007
Send a message via Skype™ to JordanC
bah humbug
JordanC is offline   Reply With Quote
Old 01-02-2005, 01:45 AM   #1008
compaq888's Avatar
Send a message via AIM to compaq888
you guys are not making any sense
compaq888 is offline   Reply With Quote
Old 01-02-2005, 02:55 AM   #1009
who really does
Old 01-02-2005, 02:56 AM   #1010
we are talking about the black clutch flyweights that are in the RRR kit. They work very very well!
Old 01-02-2005, 08:37 AM   #1011
dameetz's Avatar
Default Stripped 2nd spur gear
I don't know whats wrong but eversince i changed from stock gearing I stripped my 2nd spur gear more often. This weekend alone I stripped 2 new 2nd spur gears. I m using 17/22and 23 with 60/55 spur gears. I aligned and realinged the mounting and using a piece of paper for a good meshing but still my 2nd stripped. Has anybody got this problem as well?
Dudududududuuuuuu.....
dameetz is offline   Reply With Quote
Old 01-02-2005, 11:24 AM   #1012
ziggy12345's Avatar
Hi
I destroyed the diff locking insert today. Has anybody else had trouble with this?
I rebuilt the diff with 60K and it was fine. What diff oils are people running?
Cheers
Dedicated RC Car Speed Site
http://www.fast-rc.co.uk/forum/index.php
Sponsored by:
Norfolk and Chance
ziggy12345 is offline   Reply With Quote
Old 01-02-2005, 12:03 PM   #1013
were you running it in the front or rear.
3racing do a alloy version
Speedmerchant WGT
Shepherd V10 Velox Idm evo 4
Shepherd V8 velox Idm evo 4
www.DHmodelsport.co.uk
jas1 is offline   Reply With Quote
Old 01-02-2005, 12:46 PM   #1014
ziggy12345's Avatar
Front.
I saw the alloy ver. I might get that
Cheers
Sponsored by:
Norfolk and Chance
Old 01-02-2005, 01:54 PM   #1015
are u running foams, do you not like oneway,
if your running rubber i would go with 100,000wt plus, maybe yokomo hard diff grease or mugen super grease.
Speedmerchant WGT
Old 01-02-2005, 02:05 PM   #1016
ziggy12345's Avatar
It was damp so had to run rubber. Our track is tight with no sweeping bends so solid front works best with foams
Cheers
Sponsored by:
Norfolk and Chance
Old 01-02-2005, 02:14 PM   #1017
Sow&Steady's Avatar
Cheers
Ziggy, this is Ashby? The pictures I've seen certainly doesn't give the impression that its tight. Thanks for the tip!
http://3hobby.net REVISITED V2 - Its on steroids!
https://www.facebook.com/ssteady
Sow&Steady is offline   Reply With Quote
Old 01-02-2005, 02:53 PM   #1018
could do with you finding a good set up for ashby to share, 1st nationals not far away
Speedmerchant WGT
Old 01-02-2005, 02:54 PM   #1019
ziggy12345's Avatar
Only the big sweeper is a real power on corner everything else is brake, steer, power. Not open like Tibshelf
Cheers
Sponsored by:
Norfolk and Chance
Old 01-02-2005, 02:55 PM   #1020
ziggy12345's Avatar
What car? and what tyres? If its the RRR like your sig then same as me!
We was at the track today but it was damp to start again. I havent had a race with the RRR in the dry yet. After the final the track was dry and we tested the foam setup but my front belt went. Prior to this it was really flying.
Setup was as follows. All stock apart from changes as listed
Front
Black Springs 35 wt oil upright
Roll bar 90 deg (most)
2 deg camber
Clips at back
Diff with 60K oil
10 servo saver
0 deg toe
2mm droop
6mm ride height
GQ 35 tyres 62mm dia
Stock gears
Moded 5 port motor 16% nitro
Rear
Black springs 35 wt oil upright
4mm rear shock tower
outer camber pivot 3mm spacers
2 deg camber 3 deg toe in
4mm droop
7mm ride height
GQ 35 tyres 64mm dia
Rear diff 20K oil
Loletta body
If the belt handnt snapped i would have tried the following
Tyres 61mm rear 60 front
Less roll bar on front
Tighter clutch
If it is ever dry this year i will post a tried and tested setup
Cheers
Sponsored by:
Norfolk and Chance
FOR SALE - Mugen MBX5T ProSpec and Kyosho STR with chassis conversion and Kyosho big MattWells R/C Items: For Sale/Trade 5 04-28-2017 10:25 AM
1986 1/12 Kyosho Plazma MKIII With Kyosho LeMan 600E Motor Funkymojo R/C Items: For Sale/Trade 2 05-17-2012 11:11 AM
Custom painted Kyosho SP2 and Kyosho STRR bodies.... RC3 Graphics SWEET W/ PICS CRFXXXT R/C Items: For Sale/Trade 1 01-07-2008 07:38 PM
MACH. 28/NEW PS, KYOSHO MINI INFERNO ST/W/3NEW IB1400 8 CELL PACKS, KYOSHO 1./8 BUGGY newbie2 R/C Items: For Sale/Trade 5 11-18-2007 06:07 PM
Convert Kyosho Quick Start system on Kyosho QRC to Pullstart Morpheus2be Monster Trucks 0 02-16-2005 11:26 PM
