Old 12-23-2004, 08:38 AM   #976
TRAJ's Avatar
its the same way around as this car
TRAJ is offline   Reply With Quote
Old 12-23-2004, 08:39 AM   #977
TRAJ's Avatar
heres the pic
Old 12-23-2004, 09:16 AM   #978
TRAJ's Avatar
its fixed just have to use specific spacers for the S9451 servo!
and the servo horn was too thick
Old 12-23-2004, 09:58 AM   #979
it is the right way round, i think this problem is going happen depending on what servo you run, it happened when i built up my car, i filed alittle of the top deck so it cleared, unfortunetly all servos arn't the same dimensions.
Speedmerchant WGT
Shepherd V10 Velox Idm evo 4
Shepherd V8 velox Idm evo 4
www.DHmodelsport.co.uk
jas1 is offline   Reply With Quote
Old 12-23-2004, 07:01 PM   #980
Default 4MM Rear Shock Tower
Kyosho v-one RRR
I have 4mm rear shock towers for sale. Special 1mm recess on mount area, no need to shim bottom shock mount.
Extra holes for increased upper shock mount placement.
$20.00 includes shipping.
I have 284 positive feedback on ebay.
ebay user name rc_products
email [email protected]
see pix
gonad is offline   Reply With Quote
Old 12-23-2004, 11:02 PM   #981
Originally posted by TRAJ
im having a problem with the front steering
when i assemble the flange ball onto ther servo horn and put it on the servo , i then put it back on the chassis, the frlange ball hits the top carbon deck!
has this happened to anyone before?
does anyone know hot to stop it from hitting?
the instructions say that the flang ball is on the very top hole on the servo horn and that it should be 18-20mm fromt the top hole to the servo hole and mine is! (pg 23 step 36)
please help
I had the same problem installing my KO Propo servo. I had to add another shim for clearance.
KURAKITA is offline   Reply With Quote
Old 12-24-2004, 12:37 AM   #982
TRAJ's Avatar
Thanks Guys
its all fixed now just put a thinner alloy servo horn and added more spacers so the servo would stick out more to clear the carbon deck
Thanks again to those who helped!
Old 12-24-2004, 07:00 AM   #983
Default Joe Mugen, Call me.
joker
JOKERRACING is offline   Reply With Quote
Old 12-26-2004, 12:22 AM   #984
uaerc's Avatar
Default servo and engine
Hi
I have assembled my RRR, just need you guys to help me out on taking this decision. as on my earlier FWO5R I was using JR. 8425 / 8411 's both 11kg and they seem to have a problem. No response from them at times they just sit there and do nothing, but when i push the wheels they start working and after a while same again... I dunno how many of you have suffered this. But this happened to me on 4 of my servos, cant understand if its the heat or the bashing... the other 2 were 811's and 559 all digitals.
so 4 in total. I was recommended Futaba's
So I decided to move to Futaba since i am using a 3pk HRS radio
Please recommed for the following.
1. Servos for Steering.
2. Servos for Throttle.
3. Engine.. OS 12 TR T or the TR T e-spec whats the diff ??
4. Tune pipe RD logics Turbo 2 Outlaw.
5. gearing recommendations.. to make it faster.
Regards
ZiiZ
uaerc is offline   Reply With Quote
Old 12-26-2004, 02:12 AM   #985
TRAJ's Avatar
Default Re: servo and engine
Originally posted by uaerc
Hi
Regards
ZiiZ
Ive never heard of the servos working once you push the car.
I also use the Futaba 3PK and the best set up is this
1. Steering : S9451 Digital
2. Throttle : S9550 Digital
3. I havnt heard of an OS TR T Espec do you mean O.S. .12 TR (P)-T R-Spec?
4. The RD turbo 2 is an awsome pipe i used to have one on my FW05R but my one was the legal not the Outlaw
5. As for gearing i havnt run my RRR yet so ill let someone else help you there
Cheers
Old 12-26-2004, 03:49 AM   #986
BrainTeased's Avatar
Default Re: Re: servo and engine
1. Steering : S9550 Digital
2. Throttle : S9451 Digital
Cheers
there is an e- spec traj thats the EFRA spec one they are suppose to be rare but they are now in stock at rc mushrooms.
www.feralbatteries.com.au
BrainTeased is offline   Reply With Quote
Old 12-26-2004, 12:10 PM   #987
uaerc's Avatar
Hi Brain teased...
THanks for the input.... would you know the differenc.. since i can race outlaw here which one would you suggest......
I noticed that the 1.3 hp for the R = spec on OSENGINES.com
and couldnt find the tr T engine there. but tower has it @ 1.1 apart from this R spec is discontinued on tower....
E - Spec is available at my LHS for around 60$ more than the TR T engine.......
Is it worth it ... would the E spec work good with the RD pipe
Regards
Aziz
Old 12-26-2004, 12:31 PM   #988
uaerc, if you can run outlaw you are better off with the 5 port TR(P)-T #11365. I think you can get it at tower for around $145. It has the same horsepower rating as the e/r spec engines. With the money saved you can purchuse the OS hyper head, that should bring up the hp a little higher. You should be able to find this engine on OS's site. The 1.1 hp engines are the other 3-port TR's listed below.
11360 3-Port, Rotary carb.
11361 3-Port, Slide carb.
11362 3-Port, (P)
11363 3-Port, (S)
11365 5-Port, (P) Turbo, Slide carb.
11367 3-Port, (P) Turbo, E-Spec
11369 3-Port, (P) Turbo, R-Spec
3434 is offline   Reply With Quote
Old 12-26-2004, 12:38 PM   #989
By the way OSEngines.com is NOT OS Engines web site. Thats tower hobbies /Great Planes /Hobbico's site. Just cause it says its discontinued there is not always true. It just means they are not carrying it any longer.
Old 12-26-2004, 07:07 PM   #990
Racing4Evo's Avatar
Send a message via AIM to Racing4Evo
Hi
Regards
ZiiZ
1) KO 2344
2)S9451
3)either one
4) The best pipe for this motor is the VR 12 from Skyline Racing
5) How big is your track? The stock gearing works well at most tracks and you will probably have to only change one pinion or the other.
Racing4Evo is offline   Reply With Quote
FOR SALE - Mugen MBX5T ProSpec and Kyosho STR with chassis conversion and Kyosho big MattWells R/C Items: For Sale/Trade 5 04-28-2017 10:25 AM
1986 1/12 Kyosho Plazma MKIII With Kyosho LeMan 600E Motor Funkymojo R/C Items: For Sale/Trade 2 05-17-2012 11:11 AM
Custom painted Kyosho SP2 and Kyosho STRR bodies.... RC3 Graphics SWEET W/ PICS CRFXXXT R/C Items: For Sale/Trade 1 01-07-2008 07:38 PM
MACH. 28/NEW PS, KYOSHO MINI INFERNO ST/W/3NEW IB1400 8 CELL PACKS, KYOSHO 1./8 BUGGY newbie2 R/C Items: For Sale/Trade 5 11-18-2007 06:07 PM
Convert Kyosho Quick Start system on Kyosho QRC to Pullstart Morpheus2be Monster Trucks 0 02-16-2005 11:26 PM
