Old 06-04-2009, 06:31 AM   #9811
MikaR's Avatar
Nice Dodge Ivan!!
nitronutzzz, hope you get the dilemma sorted out.. interesting.. let us know if you do and how. You use the same body and tires?
Run my evo last sunday for 1st time, with X312T engine (old model, Kyosho logos on the head). It was fantastic. I loved the way the car handled out of the box with the kit setup. I was also very happy with the engine, hope that will last. Hope to see some sedan guys at the track at the same time to compare my speed though it for sure felt fast )
http://modelcartuning.simplesite.com/
MikaR is offline   Reply With Quote
Old 06-04-2009, 10:04 AM   #9812
Ivan Dickson's Avatar
Trader Rating: 12 (93%+)
Originally Posted by MikaR View Post
Nice Dodge Ivan!!
Thanks mikaR..
SPECIAL THANKS TO ✦ MY WIFE ✦✦ MOTIV RC ✦✦ GRAVITY RC ✦✦ JGO PAINTZ ✦✦ TQ RC RACEWAY ✦✦ TAMIYA RACEWAY ✦
Ivan Dickson is offline   Reply With Quote
Old 06-18-2009, 03:23 AM   #9813
MikaR's Avatar
Hi,
here's my new lid I just painted
The track has recently got pretty clean and the bite is quite good.
Yesterday I changed to the oneway which I really liked after running the diff in front.
I'm using the WCE kit setup as far as I can see, I've been trying to follow the manual to do so.
I'm using GRP foam tires, a fact that I cannot change for the moment. I think they're 40 shore.
Car handles very nice. However, I feel understeer in one fast sweeper turning left in 90deg angle eventually. I would like to accelerate in full throttle from the middle of the sweeper all the way to the main straight, but currently I have to play with the throttle to avoid hitting the fences when coming out from the corner (the car understeers).
Now, before I start experimenting with the setup (I have only the kit parts, no extra springs etc) what would you do in order to improve steering (not to understeer) when accelerating out from the fast corner to the main straight? Turning into corners is fine and I would like to keep the oneway in front.
Less front caster? 2mm clips in front of the hinge pin
Higher rear roll center ? (rear lower hinge pins to the lowest position?)
What else?
All tips appreciated! Thanks
Old 06-22-2009, 01:34 AM   #9814
MikaR's Avatar
Hi, let me try again: I would need more steering when exiting a corner. How?
I cannot change shock springs or tires for the moment. I want to keep the oneway in front.
Old 06-22-2009, 01:54 AM   #9815
GREGORY!'s Avatar
how much camber in front?
try less toe in rear.and higher rear diff silicone.
GREGORY! is offline   Reply With Quote
Old 06-22-2009, 01:58 AM   #9816
SteveP's Avatar
Increase the caster angle slightly, stiffen the rear anti-roll bar, or narrow the rear end. Just a few suggestions.
SteveP is offline   Reply With Quote
Old 06-22-2009, 02:53 AM   #9817
MikaR's Avatar
Thanks a lot Steve and Gregory!
Camber should be the kit setup, maybe 0-1 deg (?)
Rear diff is 30K, the one that comes in the box.
Will try these.
Old 06-22-2009, 09:49 AM   #9818
MikaR's Avatar
Ok, I think I found it; I raised the roll center of the rear slightly (with the hinge pins at their lowest position) as well as increased a bit more front caster. I could drive it all the way full throttle. I also realized that my rear tires wear now more evenly, could that be possible? I didn't touch the swaybars, nor shocks.
Thanks!!
Old 06-29-2009, 06:27 AM   #9819
GREGORY!'s Avatar
hi guys.i want to share with you my rrr wc with some mods that i have make to it.
Old 06-29-2009, 06:34 AM   #9820
GREGORY!'s Avatar
Old 06-29-2009, 09:19 AM   #9821
kest's Avatar
Trader Rating: 1 (67%+)
hi there Gregory..
i can see u have replaced the wheel nut..but why did u did that? i'm asking b'cos it does look very strange and i think that thing could cause plenty of damage when u accidentally hit the sidewall..the impact could spread to the other components..such as the wheel shaft (VZ013), knuckle arm (VZ201), pillow ball (FZ74) and many other parts.
and the second thing..just to give my opinion base on experience..it's better to use the plastic handle (VZ208) rather than the metal option part..the reason is when u accidentally flip over your car, it'll cause severe damage on the roof top and maybe shred it apart in just a second!!
Anyway..nice body work bro.. and happy racing..
K..Y..O..S..H..O..I..S..H..O..B..B..Y
JBRCC
BCRT
kest is offline   Reply With Quote
Old 06-29-2009, 09:32 AM   #9822
GREGORY!'s Avatar
these screws are not for use when racing.are for quick change the set up gauges.i use normal screws when i run the car.
and for the metal bar.i use this because the plastic one is don't clear the crf because it is a bit tall.
Old 06-29-2009, 09:47 AM   #9823
kest's Avatar
I'm a bit confused..but i think that metal bar is taller than the standard..i'm pretty sure b'cos mine is taller..it reaches the roof top of the body shell ( ALTIS 2.3 and DODGE STRATUS). But if yours is different..then is ok.
cheers
JBRCC
BCRT
Old 06-29-2009, 10:03 AM   #9824
GREGORY!'s Avatar
we are saying the same.yes the metal bar are taller.
i use that because the crf is taller than other engines.
i don't care about bodies,if it scratch them it's ok.
the only think that i care is the engine.so i use the tall one to have a bit secure.
Old 06-29-2009, 10:44 AM   #9825
kest's Avatar
Oooh.. its the heatsink u care about..OK..
Well that the pro's and con's having a large and tall heatsink..
but as i said..u better b careful coz your body might be damage..(not just scratch)..u'll see...
cheers bro..
JBRCC
BCRT
FOR SALE - Mugen MBX5T ProSpec and Kyosho STR with chassis conversion and Kyosho big MattWells R/C Items: For Sale/Trade 5 04-28-2017 10:25 AM
1986 1/12 Kyosho Plazma MKIII With Kyosho LeMan 600E Motor Funkymojo R/C Items: For Sale/Trade 2 05-17-2012 11:11 AM
Custom painted Kyosho SP2 and Kyosho STRR bodies.... RC3 Graphics SWEET W/ PICS CRFXXXT R/C Items: For Sale/Trade 1 01-07-2008 07:38 PM
MACH. 28/NEW PS, KYOSHO MINI INFERNO ST/W/3NEW IB1400 8 CELL PACKS, KYOSHO 1./8 BUGGY newbie2 R/C Items: For Sale/Trade 5 11-18-2007 06:07 PM
Convert Kyosho Quick Start system on Kyosho QRC to Pullstart Morpheus2be Monster Trucks 0 02-16-2005 11:26 PM
