Old 03-01-2009, 05:58 PM   #9781
mckrooz's Avatar
Send a message via AIM to mckrooz
Just took it apart and it was still at 0.3mm. The bell spins freely and was pretty clean. It is brand new so this was the first time running it therefore it was squeaky clean.
mckrooz is offline   Reply With Quote
Old 03-01-2009, 06:03 PM   #9782
shesha's Avatar
Send a message via MSN to shesha
I personally would not go with another spring, one our dusty low traction track the 0.3 gave plenty of grip and the kick was very smooth, what are your shim gap and end play set on ?
R.C.C.C.K - Team Kuwait
shesha is offline   Reply With Quote
Old 03-01-2009, 06:27 PM   #9783
Ivan Dickson's Avatar
Trader Rating: 12 (93%+)
Originally Posted by mckrooz View Post
Hopefully one of you guys can help me. I just got the 2D clutch and a new JLR Tuned engine. I was breaking the motor in yesterday and it's starting to make serious power. So much that when the clutch engages, my car over shoots the turn and the motor isn't even race tuned yet. What can I do so that it's a smoother engagement and controllable? The clutch is setup per the instructions. Softer clutch spring? 3D clutch? Halp!
First off you need to set your 2 speed up so that it doesn't engage to early, that way you can make the turn still in first gear, your 2nd gear should kick when your going down a long straight to build up the rpm's then it should shift this should help...
SPECIAL THANKS TO ✦ MY WIFE ✦✦ MOTIV RC ✦✦ GRAVITY RC ✦✦ JGO PAINTZ ✦✦ TQ RC RACEWAY ✦✦ TAMIYA RACEWAY ✦
Ivan Dickson is offline   Reply With Quote
Old 03-01-2009, 06:34 PM   #9784
Another great day of practice with my RRRthe car was very consistant lap after lap it handle very well good on & off power when corning just so easy to drive...can't for our up coming West Coast race this weekend....
Old 03-01-2009, 08:02 PM   #9785
mckrooz's Avatar
2sp is fine. It goes into 2nd down the straight. I'll be at CP this friday to test again.
Old 03-01-2009, 09:54 PM   #9786
Trader Rating: 28 (100%+)
Send a message via AIM to Scott Fisher
I assume you are running the 2d clutch stock... as in the stock spring and red clutch shoe.
Try going with 4 flyweights and then you can also try a grey shoe. When you do that you will need to tighten your spring. Try going to .8mm.
I should be at CP this friday, sat and sunday as well if you need some help setting up your clutch.
| Capricorn | Ybslow | Proline-Protoform | Johnny Bravo Racing | Desoto Racing | Murnan Modified | Matrix Tires | Powermaster Fuel |
Scott Fisher is offline   Reply With Quote
Old 03-01-2009, 09:59 PM   #9787
mckrooz's Avatar
Cool. I'll give that a shot. Is the grey shoe softer or harder than the red?
Old 03-01-2009, 10:02 PM   #9788
I just think its smoother engagement than the red shoe.
The extra flyweights will probably make a much bigger difference than the shoe will.
Old 03-02-2009, 06:10 PM   #9789
shesha's Avatar
red is softer grey is harder.
Old 03-09-2009, 12:40 PM   #9790
Thumbs up
Had a good time at my first race this year with my RRR its been about 1 year since I race my car handle good only problem was that I just needed to run a more consistent line which I didn't but that's was OK considering I finish all my 7 min Qualifiers and never finishing last qualified in the top 20 with a 2yr.old JL RED DOT with 4 1/2 gallons though it and I was having fun as well I figure I would go practice after the races to improve on having a more consistent line for the main well after 7 great laps the motor went I thought I ran out of gas went back to the pit area open up the motor to see inside, well I had broke my con rod which was my fault totally never replace the con rod And my backup engine was no match for the more powerful engines I was racing against so I miss my MAIN I felt that my RRR WC proform well til I race again I want all RRR owners in the world old & new too Go Fast & Don't Look Back....
Old 03-09-2009, 01:57 PM   #9791
kewdawg's Avatar
Gotta change those rods out. Replace them after each gallon to be safe.
Quinn Moon
Trinity / Epic / Revtech / VBC Racing USA / Mugen Seiki / Hot Race Tyres / SkyRocket Racing / SUPAFAST RC
kewdawg is offline   Reply With Quote
Old 03-17-2009, 08:17 PM   #9792
RAP66's Avatar
Front diff parts... What parts do I need to swap out the front one-way to a diff??
Rich
Rich Pedro
[email protected]
www.rcracing.com
RAP66 is offline   Reply With Quote
Old 03-17-2009, 09:12 PM   #9793
mckrooz's Avatar
Rich
You will need:
VZ218 - Differential Joint 19 RRR/EVO
VZ204 - Differential Pully Set (RRR)
VZ012 - Differential Gear Set RRR/EVO
BS107 - Bevel Shafts for Diff (6pcs)
It's not really necessary but if you want to get a pulley set too, you can. Otherwise you can take off the pully from your spool or one way. Remember, the pully on your one way has a ring that is superglued to it. You won't need this on the diff set. If you pry it off, you could damage it. I recommend getting a new pully set.
VZ203 -Pulley Set (RRR/EVO)
Call Kamikaze to see if he has all the parts. Or Ashford hobbies has the parts in stock as well.
Old 03-17-2009, 09:14 PM   #9794
RAP66's Avatar
Awesome!! Thanks Bud!!! any suggestions on oil??
You will need:
Rich Pedro
[email protected]
www.rcracing.com
Old 03-17-2009, 09:15 PM   #9795
mckrooz's Avatar
100K is a good starting point.
FOR SALE - Mugen MBX5T ProSpec and Kyosho STR with chassis conversion and Kyosho big MattWells R/C Items: For Sale/Trade 5 04-28-2017 10:25 AM
1986 1/12 Kyosho Plazma MKIII With Kyosho LeMan 600E Motor Funkymojo R/C Items: For Sale/Trade 2 05-17-2012 11:11 AM
Custom painted Kyosho SP2 and Kyosho STRR bodies.... RC3 Graphics SWEET W/ PICS CRFXXXT R/C Items: For Sale/Trade 1 01-07-2008 07:38 PM
MACH. 28/NEW PS, KYOSHO MINI INFERNO ST/W/3NEW IB1400 8 CELL PACKS, KYOSHO 1./8 BUGGY newbie2 R/C Items: For Sale/Trade 5 11-18-2007 06:07 PM
Convert Kyosho Quick Start system on Kyosho QRC to Pullstart Morpheus2be Monster Trucks 0 02-16-2005 11:26 PM
Currently Active Users Viewing This Thread: 2 (0 members and 2 guests)
