Old 12-21-2004, 04:15 PM   #961
TRAJ's Avatar
Hey guys ive started to build my RRR and i just wanted to ask a Question
when i assembled the 2speed the 2nd gear doesnt move seperatly to the 1st gear
Should the 2nd gear spur move independently to the 1st gear spur?
Please help
Thank You
TRAJ is offline   Reply With Quote
Old 12-21-2004, 05:37 PM   #962
thescum's Avatar
Thanks for the reply jwf_frani.
Traj,
i believe you do. i had a similar issue with the RRR. you'll have to file off the burs on the 2 speed changer, particularly the hole for the 3x3 grub screw (part 153 of Step 25, on pg 18). This should free up the 2 speed. Apart from this lil' hand fitting, you'll probably need to do the following:
1. boring the lower front suspension arms with a 3.05mm reamer (if you have this) or 3mm drill bit
2. use a soldering iron or flame to seal the sides of the fuel (on some early models)
and
3. outfit a 0.5mm shim at the front of the front upper suspension shafts, to take off the slop, so as not to disturb the caster settings. Just ensure that after putting on the shims that there's no binding of the suspension arm.
Except for this, the RRR should piece together very nicely.
thescum is offline   Reply With Quote
Old 12-22-2004, 02:27 AM   #963
rowveg36's Avatar
Trader Rating: 21 (100%+)
what geariing are you guys using for a big fast race track or what is the max i can do for both 1st and 2nd gear and what gearing did they use at the worlds?
rowveg36 is offline   Reply With Quote
Old 12-22-2004, 02:35 AM   #964
rowveg36's Avatar
has anybody tried the 24 t conversion belt? what about 2.3 mm rear sway bar has anybody tried this?
Old 12-22-2004, 06:05 AM   #965
JCB
JCB's Avatar
Where can I find the car setups on this car??
JCB is offline   Reply With Quote
Old 12-22-2004, 06:27 AM   #966
T-shirt's Avatar
at worlds,
they used 17&23 pinion and 61 & 55or56 spur
T-shirt is offline   Reply With Quote
Old 12-22-2004, 06:45 AM   #967
traj,
i would not drill anything out on your car. on mine, the front arms did have binding at first. but after i drove the car about 3 or 4 outings, the binding went away--- it wore in. if you drill out, after a few runs you will have excessive play in the arms.
Joe Chaplow is offline   Reply With Quote
Old 12-22-2004, 07:02 AM   #968
TRAJ's Avatar
Yer i decided not to do it
They are pretty free
I have now fixed my 2speed problem, Thanks to everyone who helped
The car is new so expect it to be pretty tight at first
By far the V one RRR is the tighest car i have ever built and ive built G4, Mugen, RR evos.
I still think Kyosho could have put a Ball Bearing on the throttle linkage horn, i might have to replace it with the 3racing one which has a BB built in.
Old 12-22-2004, 09:50 PM   #969
buboy28's Avatar
Send a message via AIM to buboy28 Send a message via Yahoo to buboy28
AFTERMARKET PARTS
aside from 3racing, is there any other company that manufacture aftermarket or hop-up parts for the v-one RRR that is already available in the market or hobby shops
buboy28 is offline   Reply With Quote
Old 12-23-2004, 03:51 AM   #970
ziggy12345's Avatar
The kawahara 4mm rear shock tower is a must have!
Cheers
Dedicated RC Car Speed Site
http://www.fast-rc.co.uk/forum/index.php
Sponsored by:
Norfolk and Chance
ziggy12345 is offline   Reply With Quote
Old 12-23-2004, 07:21 AM   #971
TRAJ's Avatar
im having a problem with the front steering
when i assemble the flange ball onto ther servo horn and put it on the servo , i then put it back on the chassis, the frlange ball hits the top carbon deck!
has this happened to anyone before?
does anyone know hot to stop it from hitting?
the instructions say that the flang ball is on the very top hole on the servo horn and that it should be 18-20mm fromt the top hole to the servo hole and mine is! (pg 23 step 36)
please help
Old 12-23-2004, 07:43 AM   #972
ziggy12345's Avatar
please help
Have you got it the right way around?
Cheers
Sponsored by:
Norfolk and Chance
Old 12-23-2004, 08:02 AM   #973
TRAJ's Avatar
hold on ill get a pic
ive done it how the manual says!
i know its probably something stupid i didnt do (isnt it always)
Old 12-23-2004, 08:03 AM   #974
TRAJ's Avatar
heres a pic
is this right?
Old 12-23-2004, 08:32 AM   #975
NiMo's Avatar
i don't drive this car, but to me that ball looks like it's on the wrong side.
NiMo is offline   Reply With Quote
FOR SALE - Mugen MBX5T ProSpec and Kyosho STR with chassis conversion and Kyosho big MattWells R/C Items: For Sale/Trade 5 04-28-2017 10:25 AM
1986 1/12 Kyosho Plazma MKIII With Kyosho LeMan 600E Motor Funkymojo R/C Items: For Sale/Trade 2 05-17-2012 11:11 AM
Custom painted Kyosho SP2 and Kyosho STRR bodies.... RC3 Graphics SWEET W/ PICS CRFXXXT R/C Items: For Sale/Trade 1 01-07-2008 07:38 PM
MACH. 28/NEW PS, KYOSHO MINI INFERNO ST/W/3NEW IB1400 8 CELL PACKS, KYOSHO 1./8 BUGGY newbie2 R/C Items: For Sale/Trade 5 11-18-2007 06:07 PM
Convert Kyosho Quick Start system on Kyosho QRC to Pullstart Morpheus2be Monster Trucks 0 02-16-2005 11:26 PM
