Old 10-30-2007, 09:24 PM   #9646
kewdawg's Avatar
Originally Posted by Nosram View Post
Is the RD Logics chassis any good? I bent mine in a big crash, and the local hobby shop doesn't have a replacement. I got on of the RD Logics aftermarket chassis and have fitted everything onto it.
Does it change the handling? The one I have iss 3.5mm thick.
Thank you in advance
Yes, I think so. I used it on one of other Triple Rs. Because it's thicker than the stock chassis and has additional webbing under the front diff, it increases the stiffness of the car. The car will flex less, making it more stable in and out of high speed corners and in high traction situations.
Quinn Moon
Trinity / Epic / Revtech / VBC Racing USA / Mugen Seiki / Hot Race Tyres / SkyRocket Racing / SUPAFAST RC
kewdawg is offline   Reply With Quote
Old 10-31-2007, 06:21 PM   #9647
GREGORY!'s Avatar
Originally Posted by robert maestrey View Post
Try lowering your roll center to the lowest position in the rear...take the rear Hinge pins and slide then into the inserts that allow the pins to sit at lowest postion this should help alot also try softening up the car ...500 weight oils for shocks, black springs all the way around soft settings on sway bars, 2.5 toe in rear, 1 out in front, front 2.5 camber , rear 4.0 camber, 35 tires or 37 front and rear, 10000 diff...ride height and tire size depend on track,size surface smooth and or bumpy, example if smooth and 1500-200ft straight use for quals experiencing 1mm wear every 8 minuts 59mm rear 57 front height front 5mm rear at 6mm all else use stock settings...hope this helps
Thanks ROBERT!But i am thinking that 500w is heavy for bympy.i will try somethink like 400-450.
GREGORY! is offline   Reply With Quote
Old 10-31-2007, 09:52 PM   #9648
robert maestrey's Avatar
no problem....but I have a strong feeling that 500 will be on the money
Sippin Coladas and Chillin
robert maestrey is offline   Reply With Quote
Old 11-03-2007, 10:17 AM   #9649
fpart's Avatar
Trader Rating: 40 (100%+)
Send a message via Skype™ to fpart
Does anyone know the part numbers to order to convert a V One RRR WC Edtion to an V One RRR Evo WC edition? If so I would appreciate it.
Quinn, Come on, you know? tell me!!
teamTrinity.com Sweepracingusa.com
スクービーは私のヒーローです!
Why is Scooby so slow, you might ask?
fpart is offline   Reply With Quote
Old 11-03-2007, 11:39 AM   #9650
tony montana's Avatar
Trader Rating: 66 (100%+)
Not for sure but, I dont think kyosho makes it anymore. Althou if you find one let me know cause I want one to!
K.C. Guy- TLR- Horrizon Hobby- Team Trinity- 92 zero designs- AKA
tony montana is offline   Reply With Quote
Old 11-03-2007, 04:50 PM   #9651
kewdawg's Avatar
I don't know all the part numbers, T-Laner. There was a conversion kit to go from the V one RRR WCE to the V one RRR Evo, but not to the RRR Evo WCE.
Quinn Moon
Old 11-03-2007, 06:21 PM   #9652
Little_Mike's Avatar
YES
R.O.A.R. region 11 stock rubber carpet champion
Sponsored by: Hot Bodies
HB Cyclone Moore Speed WCE Edition - HB/BMI Cyclone(foam)
Team Magic G4RS pwered by EB mods and O.S. engines
Little_Mike is offline   Reply With Quote
Old 11-13-2007, 08:43 PM   #9653
Default VZW054 Universal Swing Shaft
Can anyone tell me whether the VZW054 Universal Swing Shaft is backwards compatible and suits the V1RR Evo as well. (NB. RR only, not RRR)
Glenn is offline   Reply With Quote
Old 11-13-2007, 09:30 PM   #9654
Trader Rating: 13 (93%+)
Default rear diff oil
Hi guys
when is it a good idea to go heavier in rear diff oil?
i currently use 30,000wt and have built up a 50,000wat to try out
what changes would a heavier rear diff oil give?
i drive on a vht prepped high grip trackw ith flowing and tight turns.
Serpent 748 TQ | GIMAR Engines
Walter RC HObby | www.walterrchobby.com.au
BlueRC | www.bluerc.net
mrgsr is offline   Reply With Quote
Old 11-15-2007, 08:41 AM   #9655
Trace's Avatar
Obviously, the heavier you go on the lube, the less it will act as a diff and more like a locked axle. The inside wheel will be slipping more in tight turns reducing traction. You will be drifting the car. It will be "loose" under power in turns. ... could be fun!
BTW, I'm running 100,000 in my front to lock it up (and have front brakes) and it still moves.
Trace
Trace is offline   Reply With Quote
Old 11-15-2007, 10:15 AM   #9656
kewdawg's Avatar
I still have the SPARE PARTS / OPTIONAL PARTS sheets from the RR Evo and I don't see VZW054 as an option. I saw #695016 Power Universal Swingshaft-(for wide tires) for the rear only. On Kyosho America's website, I found #VZW055 Universal Swing Shaft-(for foam rear tires). Maybe, you can use a combination of the two types?
Quinn Moon
Old 11-16-2007, 10:36 PM   #9657
I found VZW054 on the parts list for the V1RRR and the part name is "Universal Swingshaft (For V-One)" for front.
And because it only says for V-One, i thought it might be compatible with all the V-One series cars, of which i own the V1RR evo.
Other parts on the list actually say (RR evo/RRR), so i think V-One would mean all of them...
Your thoughts pls.
Old 11-17-2007, 07:08 AM   #9658
jeff1's Avatar
I'm not sure but the VZW054 for RRR front is too short. Although for RR Evo it will fit as it uses a bigger diff cup and has the same suspension arm lenght of RRR
jeff1 is offline   Reply With Quote
Old 11-17-2007, 10:07 PM   #9659
tofuburger's Avatar
does any one make rears wheels that will fit without modifications? i want to use something besides kyosho wheels.
Larry "Chef LT" Tom
StickIt1Racing.com
HobbyAction.com
tofuburger is offline   Reply With Quote
Old 11-18-2007, 05:21 AM   #9660
what modifcations do you have to make not to run kyosho wheels and why?
FOR SALE - Mugen MBX5T ProSpec and Kyosho STR with chassis conversion and Kyosho big MattWells R/C Items: For Sale/Trade 5 04-28-2017 10:25 AM
1986 1/12 Kyosho Plazma MKIII With Kyosho LeMan 600E Motor Funkymojo R/C Items: For Sale/Trade 2 05-17-2012 11:11 AM
Custom painted Kyosho SP2 and Kyosho STRR bodies.... RC3 Graphics SWEET W/ PICS CRFXXXT R/C Items: For Sale/Trade 1 01-07-2008 07:38 PM
MACH. 28/NEW PS, KYOSHO MINI INFERNO ST/W/3NEW IB1400 8 CELL PACKS, KYOSHO 1./8 BUGGY newbie2 R/C Items: For Sale/Trade 5 11-18-2007 06:07 PM
Convert Kyosho Quick Start system on Kyosho QRC to Pullstart Morpheus2be Monster Trucks 0 02-16-2005 11:26 PM
