Old 08-26-2007, 01:17 AM   #9571
Trader Rating: 28 (100%+)
Send a message via AIM to Scott Fisher
Order a spare con rod as well.
| Capricorn | Ybslow | Proline-Protoform | Johnny Bravo Racing | Desoto Racing | Murnan Modified | Matrix Tires | Powermaster Fuel |
Scott Fisher is offline   Reply With Quote
Old 08-26-2007, 09:23 AM   #9572
Goingfast's Avatar
Trader Rating: 29 (100%+)
Yes I did and the manifold gasket too...
Goingfast is offline   Reply With Quote
Old 08-26-2007, 11:54 AM   #9573
Smart!!! Before you attach the manifold to the engine, put a bit of grease on the gasket. That is probably the weak spot of this setup. They tear a bit more easily than I would like.
Old 08-26-2007, 12:21 PM   #9574
Goingfast's Avatar
What is the best Engine Temp are you running ?
Old 08-26-2007, 12:34 PM   #9575
Don't really tune to temps. Some engines I have never put a temp gun on. One thing our team manager has been doing regarding temps is tuning by temp change. Warm the engine and tune it to run well with some visible smoke. Temp it. Run some more, then temp it again. What he looks for is the change. IF the temp continues to rise eventually the engine will lean bog. Thats too lean. He looks for it to stabilize. We just want it to run as fast as possible, without it getting so hot that the motor lays over near the end of a tank, or eating plugs. Lots of things will have an effect on the engine temps so I don't want to put a number to tune to, but I would say in the 250-280F would be a general area. Performance (good/bad) will determine what the right temp is. If it runs fast (not too rich), doesn't eat plugs, doesn't pit the piston or button, and doesn't lean bog, it is tuned correctly.
Old 08-26-2007, 02:13 PM   #9576
Goingfast's Avatar
Hmmmmm I'll tried that....thanks
PS Hopefully the motor doesn't eat too many plugs me get it right lol
Old 08-26-2007, 05:06 PM   #9577
The engine I ran has two races on it and hasn't blown a plug yet, but if you get it wrong the plug will pop like any other engine.
Old 08-26-2007, 06:27 PM   #9578
Goingfast's Avatar
Got it ..thanks Scott
Old 08-26-2007, 07:40 PM   #9579
huskerfreak's Avatar
So what is the reason for running the 2d clutch over the 3 shoe. I am going to buy an extra clutch assembly but I didn't know if I should stick with the three shoe or go with the 2 shoe/4shoe setup. Is there any advantages. I have been running a regular OS tz but I had the chance to run a hot mods novarossi this weekend and maybe will run it the rest of the season and wanted another clutch.
Any opinioons??
huskerfreak is offline   Reply With Quote
Old 08-26-2007, 07:40 PM   #9580
Any opinions??
Old 08-26-2007, 09:52 PM   #9581
I have both clutches and the 2d seems to have better launch. Some engines dont need it, and some tracks dont have the grip, but when you want it, its there. On the IDM engine, I ran the 3d clutch. On the JP and STI the 2d was the ticket. I know it sucks because clutches can be expensive.
Old 08-26-2007, 10:41 PM   #9582
Trader Rating: 55 (100%+)
Originally Posted by pau_kacang View Post
Joehwee - u drive 3r???? can u tell me the performance n realbility this car. can u give me ur setup n r u using diff or one way
if ur gonna us diff use 30,000 weight as a good starting point for the front diff and 10,000 in the rear
WatchOut is offline   Reply With Quote
Old 08-26-2007, 11:04 PM   #9583
Goingfast's Avatar
Who got the 2D or 4D clutch set up for sell...I might like to try out to compare my 3d clutch .....I'm runny the sirio STI evo 3 right now...
Old 08-27-2007, 03:04 AM   #9584
Aside from ordering straight from Kyosho, I can't tell you who might have the clutch in stock. Perhaps Kamikaze does. Get the 2d clutch and just order a package of the flyweights as well. It works very well on the STI.
When you get your IDM engine, use the collet that comes with the engine, not the one that comes with the clutch. You may have to dremel down the collet so it doesn't stick through the flywheel. For the STI engine use the collet that comes with the clutch. For both you will have to use a shim or two between the flywheel and the engine.
Old 08-27-2007, 04:29 AM   #9585
Grassy's Avatar
IDM EVO 3. contact www.teamxspower.comThe 2d and 4d clutch both have 4 pins, but the 2d and 4d use some different parts. They are both made by Kyosho.
what different parts are they. are they just the spring and fly-weights
thanks
Chris
-ACE HOBBY DISTRIBUTORS AUSTRALIA-
Grassy is offline   Reply With Quote
FOR SALE - Mugen MBX5T ProSpec and Kyosho STR with chassis conversion and Kyosho big MattWells R/C Items: For Sale/Trade 5 04-28-2017 10:25 AM
1986 1/12 Kyosho Plazma MKIII With Kyosho LeMan 600E Motor Funkymojo R/C Items: For Sale/Trade 2 05-17-2012 11:11 AM
Custom painted Kyosho SP2 and Kyosho STRR bodies.... RC3 Graphics SWEET W/ PICS CRFXXXT R/C Items: For Sale/Trade 1 01-07-2008 07:38 PM
MACH. 28/NEW PS, KYOSHO MINI INFERNO ST/W/3NEW IB1400 8 CELL PACKS, KYOSHO 1./8 BUGGY newbie2 R/C Items: For Sale/Trade 5 11-18-2007 06:07 PM
Convert Kyosho Quick Start system on Kyosho QRC to Pullstart Morpheus2be Monster Trucks 0 02-16-2005 11:26 PM
