Old 07-18-2007, 02:49 PM   #9496
doki_doki's Avatar
Location: Cebu City, Philippines and Ocala, Florida, USA
Originally Posted by meaN1 View Post
ahh...kk
Just a tip when breaking in the OSTZ engine, put a few drops of after run oil to lube the engine internals before the initial start. Also, try to heat up the engine using a hair dryer or a heat gun to about 160F to 170F. It will be easier this way and you can avoid the piston and sleeve locking up when it's at the top dead center...
doki_doki is offline   Reply With Quote
Old 07-19-2007, 03:34 PM   #9497
Send a message via Yahoo to Nutso94
Post Kyosho RRR World Class Edition For SALE
I have a Kyosho RRR World Class Edition For Sale. I am located in MD. MD is also the home of C-Whit's Hobby Shop, which is located in Clinton, MD. My email address is [email protected]
It is a 1/10 scale.
Nutso94 is offline   Reply With Quote
Old 07-23-2007, 08:12 AM   #9498
meaN1's Avatar
Trader Rating: 15 (100%+)
If I remember it right, the OSTZ engine comes with a collet. I opted to use the collet that came with the clutch assembly from the kit...
any particular reason, or does it just work better this way?
meaN1 is offline   Reply With Quote
Old 07-23-2007, 10:05 AM   #9499
Chemical X's Avatar
Trader Rating: 16 (100%+)
I had an issue with the collet that came with the OS engine. It was too short and the flywheel was touching the engine block and bearing. When I used the Kyosho collet, the flywheel had enough space between the engine.
Chemical X is offline   Reply With Quote
Old 07-23-2007, 05:40 PM   #9500
tony montana's Avatar
Trader Rating: 66 (100%+)
can anyone post a good setup they are currently running on there rrr wce? Im running mine with the stock setup and want it better. Mine seems to push a little offpower steering and loose on exit. I did drive a bone stock mtx4 this weekend and it was better than my rrr by almost a second per lap. I just want my rrr to have the corner speed and handling charcteristics of that mtx4. The track I ran on is fairly larger. If anyone has heard of it, it is 301 raceway
tony montana is offline   Reply With Quote
Old 07-23-2007, 06:36 PM   #9501
GMartinez's Avatar
Trader Rating: 85 (100%+)
Tony are you using a spool ,diff,or a oneway
most commom cure for offpower power push add a little droop to the front
www.fullthrottlercraceway.com
Home of The U.S. World Nitro Cup 2013,2014,2015,2016
2014 Roar Electric Nationals, IFMAR ISTC Worlds, 2015 Roar Fuel Nationals
2017 U.S.World Nitro Cup Nov 29th - Dec 3rd
U.S.Open Fuel Championship Returning soon
GMartinez is offline   Reply With Quote
Old 07-23-2007, 07:20 PM   #9502
Im running a oneway. Should I go with heavier shock oil or springs
Old 07-24-2007, 02:59 PM   #9503
GMartinez's Avatar
are you running the stock springs
Old 07-24-2007, 03:32 PM   #9504
Trader Rating: 28 (100%+)
Send a message via AIM to Scott Fisher
I would actually increase the droop front and rear. If you are pushing offpower, increasing the droop in the rear will allow more weight to transfer to the front tires under decelleration. (The chassis can raise more without the wheels trying to come off the ground). Increasing the droop in the front will do the same thing but the other way around when you are accelerating. It will allow the front to come up and thereby transfer weight to the rear giving a bit more rear traction.
| Capricorn | Ybslow | Proline-Protoform | Johnny Bravo Racing | Desoto Racing | Murnan Modified | Matrix Tires | Powermaster Fuel |
Scott Fisher is offline   Reply With Quote
Old 07-24-2007, 05:11 PM   #9505
thanks guys and yes Im running the stock springs
Old 07-24-2007, 06:02 PM   #9506
mcsquish's Avatar
I've looked back to page 300 trying to find someone that is in the states that sells 3 racing parts. I have had a on-line store tell me that they have ordered the parts I need but they haven't put them on their web site for me to purchase and I need the parts this week. I would like to have them for the GLC next week.
Also am I understanding this correct, the new shocks are better than the original RRR shocks?
mcsquish is offline   Reply With Quote
Old 07-24-2007, 06:33 PM   #9507
rmdhawaii's Avatar
What 3Racing part(s) are you looking for? (i.e. part numbers) http://www.rc-toro.com has some - but make sure you tell him to wrap your stuff in bubble wrap packaging or put it in a box.
Raceday Hobbies also has some K Factory parts for the RRR that might work for you in a pinch. A little pricey, but very good quality. http://www.racedayhobbies.com/kfactory_kyosho.html
Word is that the new shocks are better than the original.
Nitro Knowledge Base: http://nitrokb.netne.net
My YouTube Channel: http://www.youtube.com/nitrokb -> Lots of on-road nitro & eletric action + some off-road as well
My Flickr Photostream: http://www.flickr.com/photos/nitrokb/
Kyosho V-ONE RRR WC (x2) \ XRAY T2'007 \ Also owned: XRAY NT1 & Mugen MTX-4
rmdhawaii is offline   Reply With Quote
Old 07-24-2007, 08:13 PM   #9508
GMartinez's Avatar
Squish the most common problem with the old shock it is very easy to pinch the bladders & then the shocks would not be very consistent since it would comtract more air
Old 07-24-2007, 08:22 PM   #9509
Super Moderator
Tony Rivas's Avatar
Trader Rating: 53 (100%+)
Default mail
Yo g you got an pm
The "Dominican Assassin"
Sorry for the Spelling but you know what I mean.
Tony Rivas is offline   Reply With Quote
Old 07-25-2007, 07:08 AM   #9510
GREGORY!'s Avatar
HI!What rear tires there are with 2mm off-set?codes?names?can some one help please?
GREGORY! is offline   Reply With Quote
FOR SALE - Mugen MBX5T ProSpec and Kyosho STR with chassis conversion and Kyosho big MattWells R/C Items: For Sale/Trade 5 04-28-2017 10:25 AM
1986 1/12 Kyosho Plazma MKIII With Kyosho LeMan 600E Motor Funkymojo R/C Items: For Sale/Trade 2 05-17-2012 11:11 AM
Custom painted Kyosho SP2 and Kyosho STRR bodies.... RC3 Graphics SWEET W/ PICS CRFXXXT R/C Items: For Sale/Trade 1 01-07-2008 07:38 PM
MACH. 28/NEW PS, KYOSHO MINI INFERNO ST/W/3NEW IB1400 8 CELL PACKS, KYOSHO 1./8 BUGGY newbie2 R/C Items: For Sale/Trade 5 11-18-2007 06:07 PM
Convert Kyosho Quick Start system on Kyosho QRC to Pullstart Morpheus2be Monster Trucks 0 02-16-2005 11:26 PM
