Old 06-22-2007, 07:47 PM   #9421
GMartinez's Avatar
Trader Rating: 85 (100%+)
Originally Posted by kewdawg View Post
Someone has a hard-on for me, I guess. Appearantly, "sour grapes" and immaturity don't mix well. Don't worry. They'll either get bored or get a life. Either way, I win.
LOL been tied up with work will try to drop you a line this weekend
www.fullthrottlercraceway.com
Home of The U.S. World Nitro Cup 2013,2014,2015,2016
2014 Roar Electric Nationals, IFMAR ISTC Worlds, 2015 Roar Fuel Nationals
2017 U.S.World Nitro Cup Nov 29th - Dec 3rd
U.S.Open Fuel Championship Returning soon
GMartinez is offline   Reply With Quote
Old 06-22-2007, 08:14 PM   #9422
kewdawg's Avatar
Cool. Are you coming up for the roar regional in two weeks?
Quinn Moon
Trinity / Epic / Revtech / VBC Racing USA / Mugen Seiki / Hot Race Tyres / SkyRocket Racing / SUPAFAST RC
kewdawg is offline   Reply With Quote
Old 06-23-2007, 04:23 PM   #9423
kaotickc's Avatar
Trader Rating: 43 (100%+)
Hey, do any of you guys use the mugen starterbox?
If you do...any way you could snap a pic so I know where to put the pegs, or to get a close idea.
kaotickc is offline   Reply With Quote
Old 06-23-2007, 05:40 PM   #9424
GMartinez's Avatar
Don't think I will be able to head up there you need to come down for the pro series race in October @ Kissimmee raceway
Old 06-23-2007, 10:33 PM   #9425
SOLOARTIST 702's Avatar
Send a message via AIM to SOLOARTIST 702
Default hmm
whats up GEORGE
SOLOARTIST 702 is offline   Reply With Quote
Old 06-23-2007, 11:36 PM   #9426
kewdawg's Avatar
I may be able to work that race into my scedule.
Quinn Moon
Old 06-24-2007, 07:13 PM   #9427
GMartinez's Avatar
Originally Posted by SOLOARTIST 702 View Post
whats up GEORGE
Solo are you coming down for October proseries race @ Kissimmee
Old 06-24-2007, 07:13 PM   #9428
GMartinez's Avatar
Would be nice LMK
Old 06-24-2007, 07:28 PM   #9429
KyoshoKid's Avatar
Default Clutch problem
Half way through my last race the car stopped all of a sudden and was going forward VERY slowly, then it kicked in again for half a lap then stopped again. While in the pits and having the car off the ground the wheels engaged without any issues, held the car on the ground and gave it throttle and it also engaged. Put it back on the track and it died again.
I pulled apart my clutch and found no major issues. My setup is below:
- 1mm of shims just before the inner bearing??? of the clutch bell so the clutch bell spins nicely for 5-6 seconds (step 43 on RRR WCE manual, before putting on bearing 178)
- 0.5mm of shims onto the Bell Guild Washer (part 143) just before the cap screw goes on (step 43, shims 146, 147)
I tried to follow Josh Cyruls clutch tuning but could not work out which parts he was talking about, which parts in the manual (steps 42 and 43) are
- inner bearing
- outer bearing
- thrust assembly, thrust retainer
He mentions gap and endplay. gap of .35mm - .50mm is OK and agressive feel is .55mm - .70mm. Is this the gap when tightening the clutch spring adjuster? But its mentioned in step 6 you adjust this by adding shims to the outside of the thrust assembly but in step 42 of the manual it says the gap on the spring should be 1.2mm. So which do you adjust, the shims or the tention of the spring?
In Josh Cyruls's step 7, if you adjust the clutch bell endplay from .1mm - .2mm to .2mm - .4mm, how does this effect the aggressiveness?? its allowing the clutch bell to move left to right more. Would the more end play effect how much of the pinion gears come in contact with the spur gears?? The less contact the worse??
So... can someone explain Josh Cyrul's instructions using the parts in the RRR WCE manual?? Also, what could have been wrong with my clutch as everything seemed OK.
KyoshoKid is offline   Reply With Quote
Old 06-24-2007, 09:04 PM   #9430
rcabj's Avatar
Default clutch setups
3 things to remember and not to be confused ( sometimes i also got mix up)
1. clutch gap
2. end play
3. preload spring
but for me there is no end play coz i don't use shims in the inside bearing, just set the preload spring , clutch gap and its done.
BLacK cRoW RaCiNg TeaM
JBRCC
TEAM ORANGE
RCCUTM
pemandu upahan ;)
rcabj is offline   Reply With Quote
Old 06-24-2007, 09:22 PM   #9431
Nosram's Avatar
Can you please tell me where to find Josh Cyruls clutch tuning guide?
Nosram is offline   Reply With Quote
Old 06-24-2007, 09:50 PM   #9432
KyoshoKid's Avatar
http://www.cefx.net/tips/nitro/clutch/index.php
There is also an engine turning section
Old 06-24-2007, 10:05 PM   #9433
rcabj's Avatar
http://www.rctech.net/forum/showthre...tch+gap&page=2
read post #42
JBRCC
TEAM ORANGE
RCCUTM
pemandu upahan ;)
Old 06-24-2007, 11:19 PM   #9434
KyoshoKid's Avatar
There was this link - http://www.rctek.com/info_centax_clutch.html#9
it contains excellent info and pictures and explains every part!!!
Old 06-25-2007, 04:45 AM   #9435
Nosram's Avatar
Thank you all!
FOR SALE - Mugen MBX5T ProSpec and Kyosho STR with chassis conversion and Kyosho big MattWells R/C Items: For Sale/Trade 5 04-28-2017 10:25 AM
1986 1/12 Kyosho Plazma MKIII With Kyosho LeMan 600E Motor Funkymojo R/C Items: For Sale/Trade 2 05-17-2012 11:11 AM
Custom painted Kyosho SP2 and Kyosho STRR bodies.... RC3 Graphics SWEET W/ PICS CRFXXXT R/C Items: For Sale/Trade 1 01-07-2008 07:38 PM
MACH. 28/NEW PS, KYOSHO MINI INFERNO ST/W/3NEW IB1400 8 CELL PACKS, KYOSHO 1./8 BUGGY newbie2 R/C Items: For Sale/Trade 5 11-18-2007 06:07 PM
Convert Kyosho Quick Start system on Kyosho QRC to Pullstart Morpheus2be Monster Trucks 0 02-16-2005 11:26 PM
