Old 06-14-2007, 08:37 AM   #9391
Trader Rating: 13 (93%+)
i have a new rear bulkhead that i may try
im actually thinking of upgrading to a rrr evo it has a new rear end
mrgsr is offline   Reply With Quote
Old 06-14-2007, 10:09 AM   #9392
jeff1's Avatar
I never had this slop whith stock brake hub. With Evo brake pullley I had one time. What I used to do is screw the pulley first pushing into bulkhead, so than go to 2nd shoe and main screw. It works good for me
jeff1 is offline   Reply With Quote
Old 06-14-2007, 05:27 PM   #9393
kewdawg's Avatar
Originally Posted by mrgsr View Post
hi
i have always had an issue with the side to side movement in my 2 speed shaft. have you guys had to shim this? i found that by placing some shims between the brake disk holder and pinion gear the slop gets minimal but no one else that has a rrr at my track has had to do t his..weird i think?
I use shims, also.
Quinn Moon
Trinity / Epic / Revtech / VBC Racing USA / Mugen Seiki / Hot Race Tyres / SkyRocket Racing / SUPAFAST RC
kewdawg is offline   Reply With Quote
Old 06-15-2007, 01:33 AM   #9394
twiggy's Avatar
hi
i use shims between the bulkhead and the side pulley to get rid of MOST of the slop. i still leave a little slop in their otherwise this can cause gears to strip.
as with any car, a little slop is better than having the parts bind up. my front caster has soo much slop that i can move the arm an extra 1mm back and forth. (i reckon i could put another caster clip in there)
www.Moorebankraceway.com
Hamilton 2008 F1 champion!
twiggy is offline   Reply With Quote
Old 06-15-2007, 01:39 AM   #9395
Dynamite's Avatar
Send a message via MSN to Dynamite
i put a shim/washer in there too (between the 2 speed and 1st gear housing)
also can shim up the slop with the 3x5mm shims i think they are, you are right though, you dont want to overshim anything and cause binding
www.racingfactory.org
Kyosho RRR Evo | Sirio Evo III STI | Ko Radio
Dynamite is offline   Reply With Quote
Old 06-15-2007, 04:36 AM   #9396
maskedrider's Avatar
hi
so far, i didnt shim any of this before. And it still perform as good as it without any problem of stripping gear nor spur.
there will be some movement between the 2 speedshaft, and its normal.
as long you mash the gearing good and tighten the engine mount correctly.
you will not facing any problem at all.
maskedrider is offline   Reply With Quote
Old 06-16-2007, 08:47 PM   #9397
Novus's Avatar
Would a Diff or a One-Way be better for the front??
Novus is offline   Reply With Quote
Old 06-16-2007, 09:52 PM   #9398
rcabj's Avatar
i think this depend on few factors such as track condition, car setup , drivers requirement etc....but for me i like d one way better than the fr diff...i suggest u try them both and see which one u really like and make u faster and consistent....
BLacK cRoW RaCiNg TeaM
JBRCC
TEAM ORANGE
RCCUTM
pemandu upahan ;)
rcabj is offline   Reply With Quote
Old 06-16-2007, 11:30 PM   #9399
rmdhawaii's Avatar
One-ways are good for sweeping tracks where you don't need to do a lot of braking. A diff or solid is good for tracks with a lot of turns and you need to brake quite a bit. With a one-way, because you're only braking with two wheels instead of four, the rear may have a tendency of coming around on you under heaving braking.
Hope that helps.
Nitro Knowledge Base: http://nitrokb.netne.net
My YouTube Channel: http://www.youtube.com/nitrokb -> Lots of on-road nitro & eletric action + some off-road as well
My Flickr Photostream: http://www.flickr.com/photos/nitrokb/
Kyosho V-ONE RRR WC (x2) \ XRAY T2'007 \ Also owned: XRAY NT1 & Mugen MTX-4
rmdhawaii is offline   Reply With Quote
Old 06-16-2007, 11:45 PM   #9400
Novus's Avatar
Thanks guys.
I guess I'll be keeping the diff on.
Where in Hawaii are you rmdhawaii?
Old 06-17-2007, 01:59 AM   #9401
rmdhawaii's Avatar
Thanks guys.
Honolulu
Old 06-17-2007, 02:40 AM   #9402
Novus's Avatar
Originally Posted by rmdhawaii View Post
Honolulu
You didn't come to our Off-Road Championship on Maui, did you?
Old 06-17-2007, 02:45 AM   #9403
rmdhawaii's Avatar
No I did not. I don't own an off-road vehicle.
Old 06-17-2007, 04:34 AM   #9404
spyspeed's Avatar
Please need your set-up..
in medium track with sweeping corner my car always push on exiting corner (on power steering).. Thanks
spyspeed is offline   Reply With Quote
Old 06-17-2007, 08:50 AM   #9405
Default RRevo n RRRevo
in Japan...rajiten shop...rajiten.com....2nd hand very good condition RR RM700...and RRR = RM800 complete with enjine....no remote
mant72 is offline   Reply With Quote
FOR SALE - Mugen MBX5T ProSpec and Kyosho STR with chassis conversion and Kyosho big MattWells R/C Items: For Sale/Trade 5 04-28-2017 10:25 AM
1986 1/12 Kyosho Plazma MKIII With Kyosho LeMan 600E Motor Funkymojo R/C Items: For Sale/Trade 2 05-17-2012 11:11 AM
Custom painted Kyosho SP2 and Kyosho STRR bodies.... RC3 Graphics SWEET W/ PICS CRFXXXT R/C Items: For Sale/Trade 1 01-07-2008 07:38 PM
MACH. 28/NEW PS, KYOSHO MINI INFERNO ST/W/3NEW IB1400 8 CELL PACKS, KYOSHO 1./8 BUGGY newbie2 R/C Items: For Sale/Trade 5 11-18-2007 06:07 PM
Convert Kyosho Quick Start system on Kyosho QRC to Pullstart Morpheus2be Monster Trucks 0 02-16-2005 11:26 PM
