Old 04-16-2007, 10:36 PM   #9211
kewdawg's Avatar
Originally Posted by tony montana
like they did with the 1/8
They Did?! Damn, I missed that one. Got any pics or links?
Quinn Moon
Trinity / Epic / Revtech / VBC Racing USA / Mugen Seiki / Hot Race Tyres / SkyRocket Racing / SUPAFAST RC
kewdawg is offline   Reply With Quote
Old 04-17-2007, 06:35 AM   #9212
jag
jag's Avatar
Originally Posted by huskerfreak
On the WC Team Edition setup sheet it says that the rear toe is +2 degrees and I also noticed that one Cyrul setup sheet. Is that correct that you run toe out on the rear? I have never seen anyone run toe out on the rear. This seems a bit odd.
Also can you run the evo blue springs on the the non-evo car? Would these springs make much of a diffrence or should I just stick with the black gold and silver?
+2 is toe in and I don't think the blue springs will fit on the RRR shocks. I don't think the shocks are the same diameter. I would stick with the silver, black and gold.
jag is offline   Reply With Quote
Old 04-17-2007, 06:45 AM   #9213
Eric Gebhard's Avatar
Actually you can run the EVO springs on the old shocks but you have to flip the shock collars over and use a EVO or Mugen bottom spring retainer.
Eric Gebhard is offline   Reply With Quote
Old 04-19-2007, 08:38 AM   #9214
sangyi41's Avatar
Trader Rating: 16 (94%+)
planning upgrade my RRR to RRR evo.the evo con kit already dis.can some 1 list all the evo con kit list part.hehehe...planning upgrade my car to evo.need all the part list...thanx all
Tough Racing Belt For MALAYSIA.TEAM POWER RC PRODUCT MALAYSIA Sale And Support.
FACEBOOK ONLINE RC STORE>>http://www.facebook.com/#!/groups/227796347309837/
Call/Sms/Whatsaps +60175007932 Location(Taiping,Perak)
sangyi41 is offline   Reply With Quote
Old 04-19-2007, 04:10 PM   #9215
Mike Ellis's Avatar
Go to the Evo thread and look at post 1603. Some good info too. Thank Eric
Mike Ellis is offline   Reply With Quote
Old 04-19-2007, 04:21 PM   #9216
No problem glad to help. Here is the article if anyone is looking for it.
Old 04-25-2007, 01:19 PM   #9217
supermoto552's Avatar
Alright everyone, finally got my RRR, and re-built it all, cleaning all i could....not got it to the track yet, but a little test run let me find out its a lot better than my old voneR handling wise.
Firstly, the brake lever is extremly close to the spur gear, in fact slightly rubs, only slightly...whether i use the standard plastic one, or aftermarket one....is this normal, or will it cause much damage?
First problem, the throttle linkage screw that holds the mixer onto the servo linkage vibrated off, and the car revved its little brains out, thank god i caught it before it ripped off at full speed, coulda been so costly!! I've locktited the linkage screw very well now, so hopefully won't happen again....throttle return spring me thinks?!
Last of all, can anyone reccomend a wiring method for servo's and switch, as it looks awfull at the moment...i hear shortening cables? How easy is this to do? Has anyone got any clear pics of how to re-wire....gotta do it soon, as putting my spektrum stuff in it when it arrives.
See before and after...and how close the brake lever is in the pics.
Kyosho v-one rrr-2d4f_3.jpg   Kyosho v-one rrr-front.jpg   Kyosho v-one rrr-rear.jpg
supermoto552 is offline   Reply With Quote
Old 04-25-2007, 05:14 PM   #9218
Mike Ellis's Avatar
Try the VZ229B brake shaft kit. It helps with the angle of the brake arm. The metal arm,VZW063 is a nice add too.
Old 04-26-2007, 02:32 AM   #9219
Hi mike, i've got the Kyosho metal brake holder if thats what that part number is, only i've thrown the packet away, looks like i'll have to get the long arm lever as well too then?!
Cheers.
Old 04-26-2007, 04:36 AM   #9220
etgdpu's Avatar
Hi,
See this post for the wiring. http://www.rctech.net/forum/showpost...postcount=7472
The intelligent can become anyone, anyone can not become intelligent.
etgdpu is offline   Reply With Quote
Old 04-26-2007, 02:16 PM   #9221
Originally Posted by etgdpu
Thats an excellent detailed view, thank you, just what i was after, a lot clearer, i've gone well of the mark with mine...but can you just explain the plug on top of the reciever protector, where is that going to which is batt and servos.
thanks
Adam
Old 04-27-2007, 03:44 AM   #9222
etgdpu's Avatar
thanks
Adam
Hi
The plug is from a small extension sanwa cable. One end is going into the receiver (Batt) and the other (the one you see) waits for the battery plug to get connected.
Old 04-27-2007, 08:02 AM   #9223
Right i understand now, couldn't quite fiqure out where it went, least that does away with worrying about a switch now, will copy you on that one and do exactly the same, a lot neater looking.....not sure whether or not to cut and shorten the servo cables yet though...better get my soldering iron out if i do.
Thanks for getting back to me on this, a great help.
Old 04-28-2007, 04:07 AM   #9224
twiggy's Avatar
i was browsing on redrc.net and found some new options from atomic.
what do you guys think?
http://www.redrc.net/2007/04/atomic-...rrr/#more-2710
[/IMG]http://www.redrc.net/wp-content/uploads/2007/04/atomicrcvonerrr-2.jpg[/IMG]
[/IMG]http://www.redrc.net/wp-content/uploads/2007/04/atomicrcvonerrr-3.jpg[/IMG]
www.Moorebankraceway.com
Hamilton 2008 F1 champion!
twiggy is offline   Reply With Quote
Old 04-28-2007, 04:15 AM   #9225
twiggy's Avatar
hmm some of the pics don't seem to appear.
the rear shock tower looks interesting. as for the brake arm, well thats nothing new as i think 3racing already make one.
the reciever cover is a good idea but most people already use the mugen one.
FOR SALE - Mugen MBX5T ProSpec and Kyosho STR with chassis conversion and Kyosho big MattWells R/C Items: For Sale/Trade 5 04-28-2017 10:25 AM
1986 1/12 Kyosho Plazma MKIII With Kyosho LeMan 600E Motor Funkymojo R/C Items: For Sale/Trade 2 05-17-2012 11:11 AM
Custom painted Kyosho SP2 and Kyosho STRR bodies.... RC3 Graphics SWEET W/ PICS CRFXXXT R/C Items: For Sale/Trade 1 01-07-2008 07:38 PM
MACH. 28/NEW PS, KYOSHO MINI INFERNO ST/W/3NEW IB1400 8 CELL PACKS, KYOSHO 1./8 BUGGY newbie2 R/C Items: For Sale/Trade 5 11-18-2007 06:07 PM
Convert Kyosho Quick Start system on Kyosho QRC to Pullstart Morpheus2be Monster Trucks 0 02-16-2005 11:26 PM
