Old 04-10-2007, 04:38 AM   #9196
johnypiston's Avatar
I am not sure if this is the same thing but your symptoms are identical to what I had a while back. I ended up replacing the entire clutch assembly, 2 speed assebly and rear pulleys ...but nothing. Start the car, hit the throttle and there would be this small movement ...then nothing. I have two RRR's and compared the two part by part and still the problem escaped me.
Finally I replaced the 1st gear housing (if it's called that ) and my problem went away. I think the bearing in there went bad or something ...still can't quite figure out what happened. Try it ....you never know.
johnypiston is offline   Reply With Quote
Old 04-12-2007, 06:20 PM   #9197
A
A's Avatar
Send a message via MSN to A
Originally Posted by Sp Racer
where have you put the counter weights? - i hope they are in between the flywheel pins and not "through" the pins..
check your PM !
pm'ed you back
A is offline   Reply With Quote
Old 04-12-2007, 06:32 PM   #9198
A
A's Avatar
ok sp racer has helped me to find the solution, (THANKYOU SP RACER).. it appears that the clutch was setup correctly but engine tuning was the cause.. the engine os 12 tz3p is so rich from factory. I was reluctant to adjust mixture settings, as the engine manual states, run in as tuned from factory.. once i pinched the fuel hose the engine came to life and the clutch is now engaging properly.. ive tuned it and its now running perfectly.. oh my god what a chump!
thankyou everyone for your advice and help..
Old 04-13-2007, 10:44 AM   #9199
RC MARKET's Avatar
ACTIVE New 200mm GP body !
Kyosho v-one rrr-str51_03l.jpg   Kyosho v-one rrr-str51_02l.jpg   Kyosho v-one rrr-str51_08l.jpg   Kyosho v-one rrr-str51_07l.jpg
RC MARKET is offline   Reply With Quote
Old 04-14-2007, 05:21 PM   #9200
tony montana's Avatar
Trader Rating: 66 (100%+)
can you still get the evo wce conversion. I have a rrr wce and like the stand up throttle servo better
K.C. Guy- TLR- Horrizon Hobby- Team Trinity- 92 zero designs- AKA
tony montana is offline   Reply With Quote
Old 04-14-2007, 06:18 PM   #9201
Eric Gebhard's Avatar
I don't think it is available. If you just want to convert to the stand up servo here are the part that you need:
VZ241 top deck
FM509B the receiver mount is on this parts tree
VZ246 grommets
Hope this helps
Eric
Eric Gebhard is offline   Reply With Quote
Old 04-14-2007, 06:48 PM   #9202
Ivan Dickson's Avatar
Trader Rating: 12 (93%+)
Why do you like the stand up throttle better just curious.
SPECIAL THANKS TO ✦ MY WIFE ✦✦ MOTIV RC ✦✦ GRAVITY RC ✦✦ JGO PAINTZ ✦✦ TQ RC RACEWAY ✦✦ TAMIYA RACEWAY ✦
Ivan Dickson is offline   Reply With Quote
Old 04-14-2007, 07:22 PM   #9203
I think personally it is easier to adjust the throttle linkage
Old 04-14-2007, 07:29 PM   #9204
carkillaii's Avatar
I was told by a team driver ,if there is hi traction you use the laydown , if its low to med traction you use the stand up
carkillaii is offline   Reply With Quote
Old 04-15-2007, 01:33 PM   #9205
RC MARKET's Avatar
Yes !
Old 04-15-2007, 07:01 PM   #9206
think kyosho will come out with a 07 rrr like they did with the 1/8
Old 04-15-2007, 07:21 PM   #9207
huskerfreak's Avatar
So after sitting here all winter reading posts from you guys that live in the warm weather places on how your car runs and everything else I finally was able to run my RRR for the first time. It has sat on my bench for four months.
All I have to say is that the car was really good. It still needs a little more tweaking but I was really happy with it.
I thought I would make a post about it.
huskerfreak is offline   Reply With Quote
Old 04-16-2007, 09:30 PM   #9208
On the WC Team Edition setup sheet it says that the rear toe is +2 degrees and I also noticed that one Cyrul setup sheet. Is that correct that you run toe out on the rear? I have never seen anyone run toe out on the rear. This seems a bit odd.
Also can you run the evo blue springs on the the non-evo car? Would these springs make much of a diffrence or should I just stick with the black gold and silver?
Old 04-16-2007, 09:36 PM   #9209
Wink
+2 is actually toe in.
Old 04-16-2007, 09:51 PM   #9210
Thanks most setup sheets that I have seen had it the other way around. I guess ever car has a different way on listing setups
FOR SALE - Mugen MBX5T ProSpec and Kyosho STR with chassis conversion and Kyosho big MattWells R/C Items: For Sale/Trade 5 04-28-2017 10:25 AM
1986 1/12 Kyosho Plazma MKIII With Kyosho LeMan 600E Motor Funkymojo R/C Items: For Sale/Trade 2 05-17-2012 11:11 AM
Custom painted Kyosho SP2 and Kyosho STRR bodies.... RC3 Graphics SWEET W/ PICS CRFXXXT R/C Items: For Sale/Trade 1 01-07-2008 07:38 PM
MACH. 28/NEW PS, KYOSHO MINI INFERNO ST/W/3NEW IB1400 8 CELL PACKS, KYOSHO 1./8 BUGGY newbie2 R/C Items: For Sale/Trade 5 11-18-2007 06:07 PM
Convert Kyosho Quick Start system on Kyosho QRC to Pullstart Morpheus2be Monster Trucks 0 02-16-2005 11:26 PM
