Old 03-21-2007, 12:15 AM   #9091
KyoshoKid's Avatar
Originally Posted by supermoto552
Hey up guy's,
Just wanted to let you all see the quality of the Hex screws i ordered, went with the ones from.... https://www.tonysscrews.com/displayP...5&categoryId=2
Can't believe the quality and service, the screws are a really nice matt black finish, and are one of the highest tenstile stregths possible, he has separated the kit into induvidual zip bags with the thread size and length printed on the front of the back, this is the most important thing as it so easy when refering back to the manual for srew length, no measuring....and all for only $26 and $6 P&P to UK.
The last screw kit i got was a stainless hex screw kit, and they were all jumbled in a pill box, and the screws weren't that strong, head were really soft.
Just wanted to share with you guys, and pass on this recomendation, and however posted the link in response to my question for these screws, thank you, very pleased.
Adam
I guess these screws are an alternative to titanium as they are all hex screws and less chance of stripping them.
Are they lighter than the standard screw set?
Control the mind, control the finger, control the car
KyoshoKid is offline   Reply With Quote
Old 03-21-2007, 12:23 AM   #9092
Trader Rating: 28 (100%+)
Send a message via AIM to Scott Fisher
Standard Kyosho screws use phillips head as opposed to hex.
| Capricorn | Ybslow | Proline-Protoform | Johnny Bravo Racing | Desoto Racing | Murnan Modified | Matrix Tires | Powermaster Fuel |
Scott Fisher is offline   Reply With Quote
Old 03-21-2007, 11:13 PM   #9093
Hi all,
the new item that I can't see it before a week!
Unbelieveable! Alloy axle is really light weight
http://www.km-rc.com/oscommerce/ca....a24fc3aae41c
Ronaldo is offline   Reply With Quote
Old 03-22-2007, 11:01 AM   #9094
jag
jag's Avatar
Originally Posted by cgstrrf
Sorrym I can't really get your point....
Could you explain more??
Do you mean to apply a 5.5mm lock nut?
I thought you were talking about adjusting the rear camber.
jag is offline   Reply With Quote
Old 03-22-2007, 11:06 AM   #9095
jag
jag's Avatar
Funny about the previous post about screws, I was going to ask the same thing!! I bought a few titanium screws for the engine mount and battery plate and I have stripped these before because they get used often and they cost me just over $10USD not including shipping but you get can a full titanium set for approx $40USD. Which brand is better (price is similar):
- From Pro Shop Futaba (Square @ 4500yen)
- RCMart (Atomic @ $40USD http://www.rcmart.com/catalog/produc...ducts_id=10378)
Also, I could not find any info on the Kyosho K.R.F Multi Tyre Setter from Pro Shop Futaba for 15120yen. Anyone know where I can get info on this? What other tyre truer's are available?
I would only recommend using titanium screws in locations where they do not get used often and where they fasten into plastic.
Old 03-22-2007, 04:54 PM   #9096
KyoshoKid's Avatar
I was thinking the opposite. As the engine mount gets removed more than other parts I didnt want to strip the screws because you do them up quite tight. I guess its better to remove the motor from the engine mount rather than the engine mount from the chassis??
I also got titanium hex screws to bolt the engine to the engine mount as stripping them will be a massive headache.
Doesnt titanium hold well with metal part?
Old 03-22-2007, 05:08 PM   #9097
doki_doki's Avatar
Location: Cebu City, Philippines and Ocala, Florida, USA
I agree with you. I had a bad experience with using titanium screws on aluminum parts before. The titanium screws tend to snap when over tightened on aluminum parts Just sharing my experience
doki_doki is offline   Reply With Quote
Old 03-22-2007, 06:47 PM   #9098
most of the titanium (atomic and kyosho) is fairly poor quality compared to the high strength titanium that most of you are thinking of but very light and well suited to low stress items.
titanium also has some kind of reaction with other metals and heat causing it to seize easily as well making it a poor choice for the motor mount.
lunsford has some high quality stuff
brianhatesnitro is offline   Reply With Quote
Old 03-22-2007, 08:33 PM   #9099
KyoshoKid's Avatar
OK, Ill take out the titanium screws from the engine mount and used stock ones and make sure not the strip it!!
Do Kyosho sell standard screw set for RRR?
Old 03-22-2007, 08:47 PM   #9100
I haven't seen one if they do.
Kyosho V-One RRR - JP Modified Mugen X12 - GQ Racing Tires - Futaba servos - KO Helios w/Spektrum Pro - Maxy's Fuel
Losi 8ight 2.0 RTR for fun times
Dredd is offline   Reply With Quote
Old 03-22-2007, 09:10 PM   #9101
carkillaii's Avatar
Originally Posted by Ronaldo
Hi all,
Is This A 1way Or A Spool?
carkillaii is offline   Reply With Quote
Old 03-22-2007, 10:43 PM   #9102
Looks like a spool
Old 03-22-2007, 10:51 PM   #9103
carkillaii's Avatar
Thanks Fish
Old 03-23-2007, 06:55 AM   #9104
What about 3racing titanium screws? Has anybody tried them out?
I 've been using them for a long time, having replaced all other screws (except the motor mount ones) and the car is a lot lighter (1680 grams, all but fuel included).
Of course I have changed many parts to the 3racing hopups (titanium or carbon) and this has an effect to the over all weight as well.
Never had any stripping issues. I must say that instead they fit perfectly, especially with the other 3racing parts.
petesoulis is offline   Reply With Quote
Old 03-23-2007, 08:37 AM   #9105
doki_doki's Avatar
Haven't really tried using the 3racing screws. My friend had a bad experience using 3racing parts especially on the drivetrain areas and the engine mount... So, I ended up buying the Kawahara and Kfactory Option parts for my kit
FOR SALE - Mugen MBX5T ProSpec and Kyosho STR with chassis conversion and Kyosho big MattWells R/C Items: For Sale/Trade 5 04-28-2017 10:25 AM
1986 1/12 Kyosho Plazma MKIII With Kyosho LeMan 600E Motor Funkymojo R/C Items: For Sale/Trade 2 05-17-2012 11:11 AM
Custom painted Kyosho SP2 and Kyosho STRR bodies.... RC3 Graphics SWEET W/ PICS CRFXXXT R/C Items: For Sale/Trade 1 01-07-2008 07:38 PM
MACH. 28/NEW PS, KYOSHO MINI INFERNO ST/W/3NEW IB1400 8 CELL PACKS, KYOSHO 1./8 BUGGY newbie2 R/C Items: For Sale/Trade 5 11-18-2007 06:07 PM
Convert Kyosho Quick Start system on Kyosho QRC to Pullstart Morpheus2be Monster Trucks 0 02-16-2005 11:26 PM
