Old 02-08-2007, 09:49 PM   #8761
A
A's Avatar
Send a message via MSN to A
Originally Posted by doki_doki
Based on the manual I downloaded from the Kyosho website, it is recommended that you use the #10 servo saver when using a front differential. The #11 is recommended when using oneway
...delete me.....
A is offline   Reply With Quote
Old 02-08-2007, 09:49 PM   #8762
A
A's Avatar
Yeah ill try the #11 and i bet it will be ok.. sweet..
Old 02-09-2007, 12:09 AM   #8763
doki_doki's Avatar
Location: Cebu City, Philippines and Ocala, Florida, USA
Originally Posted by litespeed-dom
I still couldn't understand why there are racers out there with a #11 ackerman can't run a front diff. We have 3 RRR here last year, all of us ran between a 1-way and front diff constantly, and neither of us have the problem with the #11 hitting the diff casing.
Dom
From what I have noticed, this will only be an issue if the belt tension is set to it's loosest position. If you set if just before the loosest postion, then there will be no problem of the #11 steering servo hitting the diff, oneway, spool...
doki_doki is offline   Reply With Quote
Old 02-10-2007, 12:21 PM   #8764
Quietroit's Avatar
Default Rollout
What is the rollout for the rrr wce
G4rs 09|3pk| KO KO PROPO
Quietroit is offline   Reply With Quote
Old 02-11-2007, 11:43 AM   #8765
Ivan Dickson's Avatar
Trader Rating: 12 (93%+)
Someone listed the rollout ratio eariler in this post look back a few weeks.
SPECIAL THANKS TO ✦ MY WIFE ✦✦ MOTIV RC ✦✦ GRAVITY RC ✦✦ JGO PAINTZ ✦✦ TQ RC RACEWAY ✦✦ TAMIYA RACEWAY ✦
Ivan Dickson is online now   Reply With Quote
Old 02-11-2007, 01:52 PM   #8766
Default v-one rrr hop ups
Here are the hop ups i have purchased vor my V-ONE RRR-your opinion?
1 kyosho FRP middle plate
1 kyosho vone RRR EVO wide pumper
1 KYOSHO V ONE RRR sponge packing for fuel tank
1 kyosho V ONE RRR soft brake lining
KYOSHO V ONE RRR EVO rear and front springs set
KYOSHO V ONE RRR EVO 1st and 2nd gears set
1 Kyosho V-ONE RRR EVO muffler stay holder
384 Kyosho SP drive belt
189 Kyosho SP drive belt
180 Kyosho SP drive belt
1 Kyosho V-ONE RRR light weght clutch bell
1 Kyosho 3d lightweght flywheel
1 Kyosho Front Oneway Tube For V-One RRR
1 Kyosho Front Graphite Shock Stay For V-One RRR
1 kyosho Center Bulk For V-One RRR
1 kyosho One Piece Engine Mount For V-One RRR
1 3Racing (#V3R-006) Front Anti-Roll Bar Set For V-One RRR
1 3racing throttle mixing arm -aluminum
1 3 RACING set titanium 45mm turnbucle
1 3Racing (#V3R-014) Front Graphite Upper Bumper For V-One RRR
1 3Racing (#V3R-016A) 7075 Aluminum 3mm Main Chassis For V-One RRR
1 3Racing (#V3R-017) 64 Titanium Rear Main Shaft For V-One RRR
1 3Racing (#V3R-022) Brake Bar For V-One RRR
1 3Racing (#V3R-027) Graphite Battery Base Holder For V-One RRR
1 3Racing (#V3R-043) Graphite Receiver Plate For V-One RRR
1 3Racing (#V3R-047) Rear Hub Post For V One RRR
1 3Racing (#V3R-030) Side Stiffener For V-One RRR (R)
1 3Racing (#KV-028) Front Graphite Body Plate
1 3Racing (#V3R-028) Handle Bar For V-One RRR
K-factory steel gears for clutch bell
1 K-factory hard coated lightweight aluminum 1st gear one way hub
1 K factory (#K1901) Balanced Ventilation Brake Disc
1 K factory (#K1907) V1RRR K-Silver 4MM Rear Carbon Shock(W/Alum S
1 K factory (#K1909) RRR Special Rear Mount(alum.& carbon combo)
K-FACTORY alluminum pulleys all arround
1 x KM V-One RRR Graphite Brake Lever
1 x KM V-One RRR Rear 2.5mm Graphite Body Plate
1 x KM V-One RRR Evo. 2mm Steel Brake Disc
1 x KM V-One RRR Front 2.5mm Graphite Body Plate
1 x KM Muffler Stay Spring Link
1 mugen fuel filter
engine:NOVAROSSI 3plus CT
muffler:SIRIO 2611
Kyosho v-one rrr-11022007192.jpg   Kyosho v-one rrr-11022007193.jpg   Kyosho v-one rrr-11022007194.jpg   Kyosho v-one rrr-11022007195.jpg   Kyosho v-one rrr-11022007196.jpg
nickiphorosn is offline   Reply With Quote
Old 02-11-2007, 01:53 PM   #8767
some more pics!!!
i forgot to mention the amazing Futaba 3pk super with two ecxellent 9451 futaba digital servos.
i hope you like it guys!!!
Kyosho v-one rrr-11022007197.jpg   Kyosho v-one rrr-11022007198.jpg   Kyosho v-one rrr-11022007199.jpg
Old 02-11-2007, 02:02 PM   #8768
Sp Racer's Avatar
You wasted a lot of money - specially with the 3Racing parts.
10 yrs on RC tech ! wow....
Sp Racer is offline   Reply With Quote
Old 02-11-2007, 02:14 PM   #8769
the 3 racing parts are some carbon made parts.i don't think it's waste of money my friend.
Old 02-12-2007, 12:39 AM   #8770
Sp Racer's Avatar
I don't get it, why ask for an opinion when you've already got your own?
And I'll give you a hot tip, carbon fibre isn't always better
The 3pk and the servos are on the money though
Old 02-12-2007, 01:14 AM   #8771
i ask for a second opinion.The most of the parts if you check are included at the wce rrr edition.i admit that some of these parts are "waste of money "as you say,but if you like sth very much i think it's worth to spent some money to make your car look better.The rest make the car stronger and better.e.g the aluminum pulleys and the sp drive belts worth it's money,some evo parts as well.what do you mean about the 3pk and the servos my friend?
Old 02-12-2007, 06:16 AM   #8772
maskedrider's Avatar
was changing/ re-build shock oil after race, i realise that the front one side of the oil was quite clean then the other. which meaning that my car was actually running on one side heavier. both my Rear shock oil are quite equal 'blacken ' and i presummed the rear are running quite ok.
Any suggestion to amend it ? all my tires that i check and relised it did still have a ard 2mm spilt...
so in my next race i wouldm't lose my leading and cause me ended in 3nd position .
Kyosho- Sirio/ OS engine- AVID bearing- Blue thunder fuel- Proline- RC dynamite- Sanwa- RC Art
maskedrider is offline   Reply With Quote
Old 02-12-2007, 06:31 AM   #8773
fritzD's Avatar
Send a message via Yahoo to fritzD
iv even have wasted more on my Kfac CF bumper.. but hell, it looks good. hehehehe!!
fritzD is offline   Reply With Quote
Old 02-12-2007, 11:43 AM   #8774
i agree 100% with you my friend fritzd
Old 02-12-2007, 12:45 PM   #8775
RoNTC3's Avatar
Send a message via AIM to RoNTC3 Send a message via Yahoo to RoNTC3
With so many "after market" parts, can you really call it a Kyosho anymore??
eXpress Motorsports * FOLLETT Motorsports * Final Thoughts Racing
Remember, half the people you know are below average.
RoNTC3 is offline   Reply With Quote
FOR SALE - Mugen MBX5T ProSpec and Kyosho STR with chassis conversion and Kyosho big MattWells R/C Items: For Sale/Trade 5 04-28-2017 10:25 AM
1986 1/12 Kyosho Plazma MKIII With Kyosho LeMan 600E Motor Funkymojo R/C Items: For Sale/Trade 2 05-17-2012 11:11 AM
Custom painted Kyosho SP2 and Kyosho STRR bodies.... RC3 Graphics SWEET W/ PICS CRFXXXT R/C Items: For Sale/Trade 1 01-07-2008 07:38 PM
MACH. 28/NEW PS, KYOSHO MINI INFERNO ST/W/3NEW IB1400 8 CELL PACKS, KYOSHO 1./8 BUGGY newbie2 R/C Items: For Sale/Trade 5 11-18-2007 06:07 PM
Convert Kyosho Quick Start system on Kyosho QRC to Pullstart Morpheus2be Monster Trucks 0 02-16-2005 11:26 PM
