Old 02-03-2007, 06:34 AM   #8686
A
A's Avatar
Send a message via MSN to A
ok.. thanks .. your site is very cool info source.. So is it worth taking the car apart to back them off 1 notch, as u know there are min 4 settings (0 - loose and 4 - tight) and im on 2 or wait untill i am working on the car later to do this.. Im just reluctant bout pulling my beatuful new car apart unnecessarily u know? in your experience do u think this is worth it? ie will it wear pullys/belts/bearings more than normal? thanx
... 1more thing.. ive just assembled my centax using the spacer and it went together beautifully, the manual states the spring collet should be screwed down 1.2mm over the shoulder on the crank..is this a good starting setting?.. i dont have a cluth adjusting tool to screw down the spring collet .. is there anything else that works well for this or does everyone use the correct tool.. think ill just go by one.. im not going to hack it.. good info on clutch gap adjustment on your site too.
A is offline   Reply With Quote
Old 02-03-2007, 06:36 AM   #8687
GMartinez's Avatar
Trader Rating: 85 (100%+)
Originally Posted by A
i will run the spacer on my o.s between the bearing and flywheel, im putting it all together it now and hoping all goes smoothly.. well ive almost finishing buliding my car and checking over the setup.. Can someone tell me the best setting for the belt tensioners front and rear ive got them on the 2nd most loose setting and they seem to be a good tension, i assume the belts will stretch a little after i run the car.. and any other good heads up on build would be nice..thanx...
IMO I set the belt tension guides opposite l on r r on l & on the tight position & once they get a little loose then I put them back to manual settings & they still have some tension which gives a little more belt life
www.fullthrottlercraceway.com
Home of The U.S. World Nitro Cup 2013,2014,2015,2016
2014 Roar Electric Nationals, IFMAR ISTC Worlds, 2015 Roar Fuel Nationals
2017 U.S.World Nitro Cup Nov 29th - Dec 3rd
U.S.Open Fuel Championship Returning soon
GMartinez is offline   Reply With Quote
Old 02-03-2007, 06:40 AM   #8688
GMartinez's Avatar
you can use a thin needle nose to tighten the spring if you do not have a caliper adjust the spring down that you can a least see 2 threads of the nut for a starting point but I highly recommend getting a digital caliper
Old 02-03-2007, 06:41 AM   #8689
GMartinez's Avatar
What's up SMOKE see ya lurking when you gonna get a nitro car
Old 02-03-2007, 07:05 AM   #8690
A
A's Avatar
k, thanx.. i have 2 sets of quality vernier calipers (fine and rough) and have tried to set everything up exactly to spec in the manual..
getting the distance between the hubs and the suspension arms (by adjusting pillow balls) states 3.1mm on the front and 4.5mm on the rear... this is tricky to measure with vernier as the edge has a radius and each measurement seems to have some variation, im going to use feeler gauges to measure this space im thinking this will give me fairly accurate setting..? i suppose ultimately u would use something like a hudy table right?
Old 02-03-2007, 07:26 AM   #8691
GMartinez's Avatar
Good luck & yes on the hudy
Old 02-03-2007, 08:20 AM   #8692
tony montana's Avatar
Trader Rating: 66 (100%+)
hey guys I got the steering servo horn to stop rubbing the tank but now it wont turn full left with out hitting the servo case? I'll take a pic in a few to show you guys
K.C. Guy- TLR- Horrizon Hobby- Team Trinity- 92 zero designs- AKA
tony montana is offline   Reply With Quote
Old 02-03-2007, 08:28 AM   #8693
pic
Old 02-03-2007, 09:16 AM   #8694
litespeed-dom's Avatar
Tony, hard to see from the pics. the servo length and the horn angle when your wheels are straight.
Here's my thought on why you can't turn full left. It could be a couple of reasons. So here are some suggestions to check.
Check to see if you servo is shimmed correctly on the mount. If your servo is closer to the centerline of the car, it might give you more clearance to the servo case, maybe.
Check the angle of your servo horn as well. You might set the horn up so you have full lock to the left and w/o the ballend touching the servo case, then turn full right to see how that setup does.
Give those 2 things a try.
I've attached a picture (the only one I have that you can see the steering servo horn, for your reference. Also the wheels are straight.
Dom
Team Kyosho America - Team Br00d Racing - Team R/C Plus - GQ Racing Tyres - Slapmaster Tools - FSX Racing
litespeed-dom is offline   Reply With Quote
Old 02-03-2007, 09:20 AM   #8695
Originally Posted by RAT-BOI
i run a vone sIII and i have every hop up avalable but i am not shore what belts would be better the sp or the standard what do u guys think
do the sp belt snap or just strip easier than the norm
and whats the opinion on alloy pullyies are they in or out and do they hug the belt to much
SP belt are softer, to create less drag. Regular belts are naturally longer lasting, but of course not as soft.
As for pulleys, not too familiar with the SIII, but Kyosho own aluminum pulleys are very good, the teeth do not get sharpened like other brands and end up cutting your belt. I only run the aluminum brake pulley.
Dom
Old 02-03-2007, 09:25 AM   #8696
I don't have a clutch tool either , I install the spring nut initially with my kung fu grip. If the clutch is assembled and I want to adjust that in the car, I use a pick to lock the spring nut in place and then use a 2.5mm wrench and turn the crank shaft screw to adjust.
Dom
Old 02-03-2007, 09:46 AM   #8697
GMartinez's Avatar
Dom
LOL Kung Fu Grip
Old 02-03-2007, 10:54 AM   #8698
how did you get your throttle servo to sit up right instead of the laid down position?
Old 02-03-2007, 11:14 AM   #8699
robert maestrey's Avatar
Dom is running a RRR Evo Wce....the Evo comes with servo upright.....you can convert by ordering a Evo Upper deck for your car...
Ok this is how it works
RRR -laydown
RRR WCE- laydown
RRR EVO- upright
RRR EVo WCE- upright
hope this helps
Robert Maestrey
Sippin Coladas and Chillin
robert maestrey is offline   Reply With Quote
Old 02-03-2007, 02:22 PM   #8700
jag
jag's Avatar
In my opinion you will never get the suspension setup properly without some type of station.
jag is offline   Reply With Quote
FOR SALE - Mugen MBX5T ProSpec and Kyosho STR with chassis conversion and Kyosho big MattWells R/C Items: For Sale/Trade 5 04-28-2017 10:25 AM
1986 1/12 Kyosho Plazma MKIII With Kyosho LeMan 600E Motor Funkymojo R/C Items: For Sale/Trade 2 05-17-2012 11:11 AM
Custom painted Kyosho SP2 and Kyosho STRR bodies.... RC3 Graphics SWEET W/ PICS CRFXXXT R/C Items: For Sale/Trade 1 01-07-2008 07:38 PM
MACH. 28/NEW PS, KYOSHO MINI INFERNO ST/W/3NEW IB1400 8 CELL PACKS, KYOSHO 1./8 BUGGY newbie2 R/C Items: For Sale/Trade 5 11-18-2007 06:07 PM
Convert Kyosho Quick Start system on Kyosho QRC to Pullstart Morpheus2be Monster Trucks 0 02-16-2005 11:26 PM
