Old 01-16-2007, 09:03 PM   #8581
KyoshoKid's Avatar
Originally Posted by jag
I use the medium ones and the flat spring cup. If you use the short ball cups you risk not getting the correct droop because the shocks are too short. That is what I found on my car.
PS - what is the flat spring cup? whats the part number so I can look at it?
Control the mind, control the finger, control the car
KyoshoKid is offline   Reply With Quote
Old 01-16-2007, 09:22 PM   #8582
kewdawg's Avatar
Originally Posted by KyoshoKid
So the manual in incorrect then?? Well, in the sense of the droop settings
The guy at the track did mention something about droop but I dont get how the droop is effected. Cant you adjust the droop with the droop screws to make it have more droop? You screw in the shock shaft the same distance into the ball cup whether its short or long ball cups. Is it that the overall length is longer (the shaft stays the same lenght but the longer ball cup increases the lengh)?? If the length of the shaft is longer wouldnt that make the springs softer or would you screw down the adjuster to make it the same stiffness as if the short ball cup was used.
Have I made sense??
The length of the shock becomes longer which will allow the arm to have more down travel (sag more). This is needed when you run on really bumpy tracks and/or need to make ride height when you run really small tires. Stick to using the set screws in the arms to adjust droop. Just screw the longer ball cup on to the same distance as the stock one.
*The flat shock retainers came with you kit. You should have some that look like cones with a slot down the middle and flat ones with a slot down the middle. Its found on the shock parts tree. Part# VZ213 Small Parts Set (RRR)
Quinn Moon
Trinity / Epic / Revtech / VBC Racing USA / Mugen Seiki / Hot Race Tyres / SkyRocket Racing / SUPAFAST RC
kewdawg is offline   Reply With Quote
Old 01-16-2007, 11:07 PM   #8583
KyoshoKid's Avatar
Oh yes, I remember those parts.
If its a good thing to have the long ball ends on the rear shocks then why do the fronts have short ball ends? Wouldnt you need the same advatages at the front?
Old 01-17-2007, 01:26 AM   #8584
no because you can get away with using the short ones to get the correct amount of droop/ride height.
ae_ntc3 is offline   Reply With Quote
Old 01-17-2007, 02:05 PM   #8585
what body is everyone running with their rrr wce?
Joe Chaplow is offline   Reply With Quote
Old 01-17-2007, 02:09 PM   #8586
Ivan Dickson's Avatar
Trader Rating: 12 (93%+)
Smile
Madza 6 & Dodge stratus 3.1
SPECIAL THANKS TO ✦ MY WIFE ✦✦ MOTIV RC ✦✦ GRAVITY RC ✦✦ JGO PAINTZ ✦✦ TQ RC RACEWAY ✦✦ TAMIYA RACEWAY ✦
Ivan Dickson is online now   Reply With Quote
Old 01-17-2007, 02:13 PM   #8587
Eric Gebhard's Avatar
I am running the Protoform Dodge Stratus 3.1. I have used the Parma type M and the PF Stratus on my MTX-4. What I found was that the Stratus feels more planted in the rear than the Type M. Also the body seams to be more durable than the Parma.
Eric Gebhard is offline   Reply With Quote
Old 01-17-2007, 02:24 PM   #8588
Mike Ellis's Avatar
Dito.........
Mike Ellis is offline   Reply With Quote
Old 01-17-2007, 03:53 PM   #8589
litespeed-dom's Avatar
The ONLY body I'll drive now regardless of track size or traction.... Mazda 6. I have too much success with that body, no reason not to run it!
Dom
Team Kyosho America - Team Br00d Racing - Team R/C Plus - GQ Racing Tyres - Slapmaster Tools - FSX Racing
litespeed-dom is offline   Reply With Quote
Old 01-17-2007, 04:04 PM   #8590
GMartinez's Avatar
Trader Rating: 85 (100%+)
What up dawg how's everything
www.fullthrottlercraceway.com
Home of The U.S. World Nitro Cup 2013,2014,2015,2016
2014 Roar Electric Nationals, IFMAR ISTC Worlds, 2015 Roar Fuel Nationals
2017 U.S.World Nitro Cup Nov 29th - Dec 3rd
U.S.Open Fuel Championship Returning soon
GMartinez is offline   Reply With Quote
Old 01-17-2007, 04:32 PM   #8591
rmdhawaii's Avatar
Dom
Dom,
How are you mounting the body relative to the front wheel well cut lines? Also, where is the front edge of the rear wing relative to the wing mounts (raised section on the body)?
Thanks!
Rainer
Nitro Knowledge Base: http://nitrokb.netne.net
My YouTube Channel: http://www.youtube.com/nitrokb -> Lots of on-road nitro & eletric action + some off-road as well
My Flickr Photostream: http://www.flickr.com/photos/nitrokb/
Kyosho V-ONE RRR WC (x2) \ XRAY T2'007 \ Also owned: XRAY NT1 & Mugen MTX-4
rmdhawaii is offline   Reply With Quote
Old 01-17-2007, 04:38 PM   #8592
Originally Posted by rmdhawaii
Dom,
Thanks!
Rainer
This is 99% of the case....
I would cut the front wheel wells and then have the front wheel be dead center with the wheel wells, then trim the rear wheel wells according to where the rear wheels sit.
As for the wings, I mount the wing according to ROAR rules of the rear of the wing relative to the rear bumper.
Dom
Old 01-17-2007, 06:39 PM   #8593
jag
jag's Avatar
Exactly. When you are done your shocks will be just a little longer.
jag is offline   Reply With Quote
Old 01-17-2007, 10:37 PM   #8594
KyoshoKid's Avatar
Whats the best way to stiffen/soften the shocks (say the rear shocks)? Is there difference between the below?
A - increase/decrease the angle of the shocks on the shock tower
B - increase/decrease the shock oil and springs
Old 01-18-2007, 07:08 AM   #8595
robert maestrey's Avatar
It looks like 2 of the flyweights are missing in the picture.
The only difference I can see is 4 flyweights vs. 3 flyweights on the stock clutch and the material of the flywheel.
What am I missing?
Also there using a different shoe Jim....instead of grey there going with red...
Sippin Coladas and Chillin
robert maestrey is offline   Reply With Quote
FOR SALE - Mugen MBX5T ProSpec and Kyosho STR with chassis conversion and Kyosho big MattWells R/C Items: For Sale/Trade 5 04-28-2017 10:25 AM
1986 1/12 Kyosho Plazma MKIII With Kyosho LeMan 600E Motor Funkymojo R/C Items: For Sale/Trade 2 05-17-2012 11:11 AM
Custom painted Kyosho SP2 and Kyosho STRR bodies.... RC3 Graphics SWEET W/ PICS CRFXXXT R/C Items: For Sale/Trade 1 01-07-2008 07:38 PM
MACH. 28/NEW PS, KYOSHO MINI INFERNO ST/W/3NEW IB1400 8 CELL PACKS, KYOSHO 1./8 BUGGY newbie2 R/C Items: For Sale/Trade 5 11-18-2007 06:07 PM
Convert Kyosho Quick Start system on Kyosho QRC to Pullstart Morpheus2be Monster Trucks 0 02-16-2005 11:26 PM
