Kyosho v-one rrr
#8521
Originally Posted by joemugen
hi,
i am planning to race the state race at fort myers this weekend. i have the kyosho rrr wce and wondering does anyone have a good starting point set up for this track?
thanks in advance
thanks in advance
#8524
Just wonder to ask which brand of optional parts the guys will use. any suggestions for me?
#8525
http://www.nitrokb.com/vonerrr/UltimateEdition.html
#8526
Originally Posted by rmdhawaii
For a standard RRR or WCE you might give this list a once over.
They are the most common used optional parts, aren't they?
#8527
Thank you for your helpful site. A very detail table for this new player (me)
If you are new to the RRR/WCE, you may want to race your car stock for a while and slowly try different things based on what you think your requirements are. Some people have very little or no upgrades at all, while some upgrade everything. Some of the upgrades may compensate for deficiencies in your setup, driving or tuning - or give you more tuning options, but they are not magic bullets.
The thread I initially started on the "Ultimate Edition" has some really interesting exchanges. If you have the time, you should read through it.
http://www.rctech.net/forum/showthread.php?t=110906
If you haven't already done so, read the first few pages in the published specification. I think it will also give you some things to think about.
Published Specification
http://www.nitrokb.com/vonerrr/V1RRR....1%20Draft.pdf
#8529
Location: Cebu City, Philippines and Ocala, Florida, USA
It's hard to say how commonly used these parts are, as the input came from the small group of RRR racers that hang out in this forum - but as indicated in the published version, there had to be some concurrence from other drivers that the part has some merit.
#8530
Originally Posted by doki_doki
well, in my opinion, you have really done a good job in putting up the information site
#8531
Check this out! Anybody try this yet??
#8533
Originally Posted by mrgsr
do you guys have any tips to stop the front tie rod (the one that adjusts the toe) from popping off? it happened to me a few times today
its popping of the ball ends at the ackerman plate
im going to replace the ball ends and the plastic eyes then try again
thanks!
thanks!
How exactly are you using the plastic ties???
#8534
hello
we found out some very nice alternatives in order to extend the life of some
high wear items used on the kyosho RRR, such as unis, diff cups, and pnions
anyonw interested can pm me since I have pics to explain better how to
use them
of course this involves using alternatives from kyosho and differente manufacturers,
happy racing
use them
happy racing
#8535
Never really came across someone having that problem before. Replace the ball ends for sure. Were they just coming off by themselves or did you crash?
yeh this was happening during crashes (my fault) the track i was at has some hard boards around it.
i seam to have fixed this problem by putting new balls on. the plastic eye ends click on really tight now with some force. the others would clip on real easy.
i run a front diff so i have to sand down the eye parts a bit so they clear the dff case that i have also grinded down.
ill see how this goes and feedback
