Kyosho v-one rrr
#8491
This is the WCE version (not the EVO) and I am using the stock brake pads. I was thinking of getting the APP pads or the K-Factory brake pads, which should help this situation unless anyone has some other suggestion.
Do this, then re-adjust your brakes and i bet everything will be ok !
RRR rocks
#8492
Thanks, I'll give that a try for next weekend.
#8493
Location: Cebu City, Philippines and Ocala, Florida, USA
Originally Posted by Eric Gebhard
Well I finally got to do my first race with the Kyosho RRR. This car is awesome. Strait out of the box with the addition of the solid front axel the car handled great. Lot’s of steering, very stable and extremely strong. I took a couple of hard hits in the chicane and the car kept running like nothing had happened. Next week I will be getting a new Sirio engine so I should have plenty of power to go with the car. One thing I did notice was the brakes seamed to fade about halfway thought the main. This is the WCE version (not the EVO) and I am using the stock brake pads. I was thinking of getting the APP pads or the K-Factory brake pads, which should help this situation unless anyone has some other suggestion.
Eric
Eric
You could try this one http://www.shopkyosho.com/product/pr...2069.16509.0.0 as what litespeed-dom has suggested
#8494
Are you refering to the APP pads? I was thinking about getting a set to try or the K factory brake pads.
#8495
#8496
Cool thanks that the one I'll look at getting.
#8498
Originally Posted by litespeed-dom
VZW219 is 2mm longer so there is more "meat" in your outdrives.
Hope this helps.
Dom
Hope this helps.
Dom
#8499
Originally Posted by antoine80
in my kit RRR not WCE the 2mm spacer was default so the rims had 0offset, my question was if i want to use rims with 2mm offset i can just remove the spacer or i need to buy different axles?
also does anyone has an idea if it is better to use 0mm offset or 2mm offset rims?
#8500
Originally Posted by jag
You cannot just remove the 2mm spacer to use offset wheels. If you want to experiment with wheel offsets you need different universals.
Antony
#8501
Originally Posted by mrgsr
i got the composite bonded ones doki is talking about they are awesome~~
ive had to back my brakepercentage on the radio about 40%
#8502
#8503
Originally Posted by doki_doki
Just curious...Exactly what benefit does one get when using 2mm offset rear tires as compared to the 0mm offset rear tires Thanks in advance
#8504
Honestly, I really wouldn't think there is any advantage for one over the other. It's really just down to which manufacturers wheels/tires you choose. If certain company only has 2mm offset tires and no other option so you'll just have to run that and standard axle. Vice versa.
For me, GQ 0mm offset is a lot easier to get then their 2mm offset, therefore I run the 2mm offset axle so I can run the 0 offset wheels.
Dom
Dom
#8505
Dom
Dom
