Old 01-03-2007, 07:40 PM   #8476
litespeed-dom's Avatar
Originally Posted by doki_doki
Hmm...these new brake pads looks very strong as compared to the stock brake pads that came with the kit. I guess this would be a great brake pad upgrade for the v1rrr and v1rrr evo kit since it is also designed for the MP777. Now with that in mind, having to stop a .21 powered buggy with those pads would be a breeze if these pads where placed in a .12 powered on-road kit... Just my 2 cents
Yup, that is precisely why these pads worked awesome. They were made to stop a .21 powered buggy. Also the pads are made by APP. You know how the brake pads on your real car is kind of a composite metal compound? This is exactly like that instead of your normal plastic/rubber-ish pads our there.
There was so much breaking power, almost too much that we put a couple slots in them so to create lesser braking service!
Dom
Team Kyosho America - Team Br00d Racing - Team R/C Plus - GQ Racing Tyres - Slapmaster Tools - FSX Racing
litespeed-dom is offline   Reply With Quote
Old 01-03-2007, 09:08 PM   #8477
doki_doki's Avatar
Location: Cebu City, Philippines and Ocala, Florida, USA
Dom
That's good to hear that these new brake pads are performing very well Will get one after the stock brake pads that came with the evo kit wear out. As of now, they are doing a great job at stopping my kit where I want it to It's quite a big improvement compared to the brake pads that came with the RRR WCE
doki_doki is offline   Reply With Quote
Old 01-03-2007, 11:05 PM   #8478
Don't know if you notice, the EVO brake cam is redsigned(compare to the original RRR), so the brake lever is now in a better angle to give more leverage for more braking power.
Dom
Old 01-04-2007, 01:22 AM   #8479
antoine80's Avatar
Default Wheel offset
Hey all, happy new year.
i am owning a stock RRR, the rear rims should be 0mm or 2mm offset? i am currently running with 0d offset.
reading the setup sheet i noticed that it must be correct to use 0mm rims if you use the 2mm spacer, if i want to use 2mm offset rims i can just remove the spacers or i need to purchase different wheel shafts?
Last edited by antoine80; 01-04-2007 at 01:30 AM. Reason: (read the setup sheet :) )
antoine80 is offline   Reply With Quote
Old 01-04-2007, 09:09 AM   #8480
If you use 2mm offset rear wheels, then the stock axles will be fine. If you use 0mm offset rear wheels, you'll need VSW007, which the axle is longer and comes with a 2mm spacer that goes between the outer hub bearing and the wheel hex.
Dom
Old 01-04-2007, 09:26 AM   #8481
Ivan Dickson's Avatar
Trader Rating: 12 (93%+)
Dom
What is the price of VSW007 were can you the best deal on this part.
SPECIAL THANKS TO ✦ MY WIFE ✦✦ MOTIV RC ✦✦ GRAVITY RC ✦✦ JGO PAINTZ ✦✦ TQ RC RACEWAY ✦✦ TAMIYA RACEWAY ✦
Ivan Dickson is offline   Reply With Quote
Old 01-04-2007, 11:10 AM   #8482
http://www.shopkyosho.com/product/pr...YOVSW007/410.0
You can also order it through your local Kyosho dealer. Price should be pretty much standardized.
Dom
Old 01-04-2007, 11:28 AM   #8483
Thumbs up
Dom
Thanks I check out RC-mushroom
Old 01-04-2007, 02:03 PM   #8484
antoine80's Avatar
Dom
in my kit RRR not WCE the 2mm spacer was default so the rims had 0offset, my question was if i want to use rims with 2mm offset i can just remove the spacer or i need to buy different axles?
also does anyone has an idea if it is better to use 0mm offset or 2mm offset rims?
Old 01-04-2007, 09:46 PM   #8485
anybody knows where I can find 3racing parts for 3R in the US? I'm looking for the grhaphite battery tray and receiver plate.
oderem is offline   Reply With Quote
Old 01-04-2007, 10:34 PM   #8486
doki_doki's Avatar
Dom
I see.. Thanks for the heads up on that new info
Old 01-05-2007, 06:00 AM   #8487
Eric Gebhard's Avatar
RC-Toro sells 3racing parts.
Eric Gebhard is offline   Reply With Quote
Old 01-05-2007, 08:57 AM   #8488
Rc-mushroom has 3racing also.
Old 01-06-2007, 01:06 AM   #8489
Originally Posted by mrgsr
hello
i would like to ask a question im pretty sure its related to tweak..
why is it that im able to do burnouts turning right but when i try doing burnouts to the left the car just goes straight with the wheels turned left?
on the hudy setup gauge the wheels are both set to +0.5 toe out in the front and the steering throw is exactly the same. the car also drives straight
is related to tweak?
it could be your droop or one of your shocks has lost some oil.
ae_ntc3 is offline   Reply With Quote
Old 01-06-2007, 06:29 PM   #8490
Well I finally got to do my first race with the Kyosho RRR. This car is awesome. Strait out of the box with the addition of the solid front axel the car handled great. Lotís of steering, very stable and extremely strong. I took a couple of hard hits in the chicane and the car kept running like nothing had happened. Next week I will be getting a new Sirio engine so I should have plenty of power to go with the car. One thing I did notice was the brakes seamed to fade about halfway thought the main. This is the WCE version (not the EVO) and I am using the stock brake pads. I was thinking of getting the APP pads or the K-Factory brake pads, which should help this situation unless anyone has some other suggestion.
Eric
FOR SALE - Mugen MBX5T ProSpec and Kyosho STR with chassis conversion and Kyosho big MattWells R/C Items: For Sale/Trade 5 04-28-2017 10:25 AM
1986 1/12 Kyosho Plazma MKIII With Kyosho LeMan 600E Motor Funkymojo R/C Items: For Sale/Trade 2 05-17-2012 11:11 AM
Custom painted Kyosho SP2 and Kyosho STRR bodies.... RC3 Graphics SWEET W/ PICS CRFXXXT R/C Items: For Sale/Trade 1 01-07-2008 07:38 PM
MACH. 28/NEW PS, KYOSHO MINI INFERNO ST/W/3NEW IB1400 8 CELL PACKS, KYOSHO 1./8 BUGGY newbie2 R/C Items: For Sale/Trade 5 11-18-2007 06:07 PM
Convert Kyosho Quick Start system on Kyosho QRC to Pullstart Morpheus2be Monster Trucks 0 02-16-2005 11:26 PM
