Kyosho v-one rrr
Old 11-30-2004, 07:03 PM
  #826
jeffreylin's Avatar
Originally posted by jwf_frani
i wanted to know how many mm do you guys start with on
the clutch nut and how much end play is a good starting point
on this clutch?
Francis, I start with 1.2-1.3mm on the clutch nut and maybe 0.5-0.7mm on the clutch bell play.
The Kyosho clutch works quite well and I almost never need to adjust it.
jeffreylin is offline
Old 11-30-2004, 08:54 PM
  #827
Racing4Evo's Avatar
I run 1mm on the adjustment nut and .6mm end play. The 4D clutch spring is a lot better than the old 3D clutch spring that used to come on thier clutches.
Racing4Evo is offline
Old 12-01-2004, 06:12 AM
  #828
SalvadoriRacing's Avatar
which online store in USA is carrying the v-one RRR?????
thankz!!!!
SalvadoriRacing is offline
Old 12-01-2004, 10:13 AM
  #829
ralliartlanevov's Avatar
i was wondering if anyone can explain how u tell the difference btw spring rate. for example front springs (2.5x1.7 or 3.5x1.7). i dont really get the concept of this. i dont kno wat the number are for.
ralliartlanevov is offline
Old 12-01-2004, 10:23 AM
  #830
Ron C.'s Avatar
thankz!!!!
SalvadoriRacing,
www.towerhobbies.com
They should have the kits available any day now. The parts are
already in stock. You may also email this guy:
[email protected]
He has an online store still being set up but he has almost
everything in stock already.
Hope this helps...
Ron C. is offline
Old 12-01-2004, 10:26 AM
  #831
thanks.....
but only fot the email hahahahahaha!
because tower hobbies is charging almost 500 dollars for the car.........
Old 12-01-2004, 10:33 AM
  #832
Ron C.'s Avatar
thanks.....
You're welcome.
Ron C. is offline
Old 12-01-2004, 12:54 PM
  #833
Default Re: Re: V1RRR Info
Originally posted by InitialD
Fernando, here you go.
Thank you D.
However, I still can't find the length and diameter of the front lower wishbone pin. Anyone?
Thank you
Fernando_M is offline
Old 12-01-2004, 02:03 PM
  #834
I don't know the length, but it is a 3mm diameter front and rear pins
rossiRocket is offline
Old 12-01-2004, 11:03 PM
  #835
Taylor-Racing's Avatar
It works like this:
The 2.5 is the number of (full) coils in the spring.
The 1.7 is the diameter of the wire used to make the spring.
Given that more coils equals a softer spring (all other things being equal), the 2.5x1.7 spring will be harder than the 3.5x1.7 one.
Taylor-Racing is offline
Old 12-02-2004, 09:56 AM
  #836
thanks taylor-racing. now i get it.
Old 12-02-2004, 07:19 PM
  #837
atomic hobbies in florida has it--- i think 3 left for $355. their number is 305-235-3232.
Joe Chaplow is offline
Old 12-06-2004, 01:45 PM
  #838
Racing4Evo's Avatar
Keep it alive...
Old 12-06-2004, 02:09 PM
  #839
Francis M.'s Avatar
are most of you running the 23 tooth side pulley and running the
2mm tires split?
Francis M. is offline
Old 12-06-2004, 02:27 PM
  #840
Racing4Evo's Avatar
Yes for me. Try it with and without the split. Makes a big difference.
