Old 11-16-2006, 08:14 PM   #8356
Trader Rating: 13 (93%+)
Hi Jeff
Sounds like your missing the castor clips. 2-3 mm play is way too much
you should have a bit of play maybe .5mm
check to see you have 2 castor clips on the upper arm. ive never seen that much play on the bottom arms. maybe you hsould try rebuilding the fornt end?
did you buy this car brand new or used?
Originally Posted by jeff1
Hello!
My RRR have a "gap" in the upper front arm and lower rear arm.. it's something betwen 2mm~3mm of play, since I bought it. Is this play normal? Projected? I heard one time from a experienced person that this play helps stability in bumped tracks (like Jundai park in Sao Paulo).. but I don't know this deeply. Should I remove this play with thin shims or keep it?
Serpent 748 TQ | GIMAR Engines
Walter RC HObby | www.walterrchobby.com.au
BlueRC | www.bluerc.net
mrgsr is offline   Reply With Quote
Old 11-16-2006, 08:27 PM   #8357
jeff1's Avatar
I did a mistake, I'm sorry. I mean 0.2 and 0.3mm
even in front upper arms and rear lower arms
jeff1 is offline   Reply With Quote
Old 11-16-2006, 08:33 PM   #8358
play = good
don't shim it up because the car andles better with play in the arms and hubs
ae_ntc3 is offline   Reply With Quote
Old 11-16-2006, 08:36 PM   #8359
jeff1's Avatar
I'm doing my car maintenance, and I'm having an another issue in the steering rods.
I mounted the steering blocks in arms and everything is ok, the movement is smooth when pushing it up and down, also when turning left/right. The problem is when I install the steering rods the movement starts to drag.. if I left in this condition will overload the servo.. I know this part must have a smooth moviment, but I'm not achieving that .. and I'm not understanding what is happening
Old 11-16-2006, 08:39 PM   #8360
jeff1's Avatar
Originally Posted by ae_ntc3
play = good
Are you sure? I heard this one time from a guys that made the best lap here with a old MTX-2 with a lot of play
For me this don't make sense
Old 11-16-2006, 08:43 PM   #8361
jeff1's Avatar
I'm using the number 10 servo saver with bearings of WCE. It's strange without rods all moves smooth.. wonderfully, with rods connected its a nightmare
Old 11-17-2006, 02:15 AM   #8362
when a car has a bit of play, all the suspension components move to their prefered position when under massive loads e.g. acceleration, turning G forces etc. so if your setup isn't great the car finds its own 'centre'.
im not saying leave more than 1mm of play but just a little bit is ok.
if someone can explain it better feel free!
Old 11-17-2006, 02:17 AM   #8363
are the rods rubbing on the front bulkhead?
are the rods hard to snap onto the balls?
do the ballends pivot smoothly on the balls?
Old 11-17-2006, 04:56 AM   #8364
jag
jag's Avatar
i know that the kfactory brake disc fits the mp777 and the rrrWCE. It will not fit the EVO. The brake disc which comes with the EVO is good as long as you use the app or kfactory brake pads.
jag is offline   Reply With Quote
Old 11-17-2006, 05:00 AM   #8365
jag
jag's Avatar
Does anybody know the part number for the EVO conversion kit?
It's time to give it a try.
Old 11-17-2006, 05:45 AM   #8366
SOLOARTIST 702's Avatar
Send a message via AIM to SOLOARTIST 702
Default hmm
you runnin the w/nats
RC AMERICA / XRAY / HUDY/ MATRIX TIRES /KOPROPO / ORCAN GT3 /RED CUP RACING MEMBER / SPEEWORLD RACEWAY/ A+ performance parts /IVE SEEN THE XRAY TEAM DRIVE SO I GOT XRAY CARS / better to keep up than to catch up
WILLIAM PENDERGRASS
SOLOARTIST 702 is offline   Reply With Quote
Old 11-17-2006, 06:22 AM   #8367
jag
jag's Avatar
I doubt it... not good enough yet. Plus I can't take a week off to race. I will go over to see the mains. The 1/8th scale should be incredible this year. I saw Chris T. last weekend and he was fast. I assume he will run that at the WinterNats. If he does, he might end Mickey's streak at the fort.
Old 11-17-2006, 06:42 AM   #8368
Default front bottom arm ear like part.. what is it?
hey guys
always wanted to know the true meaning and what these parts do to the setup.. im talking about the ear type parts that screw into the front of the bottom suspension arm. when you twist these up or down the suspension arm raises or lowers.
can i get a true answer about how to adjust these? thanks!
Johnh
Old 11-17-2006, 08:33 AM   #8369
robert maestrey's Avatar
Originally Posted by mrgsr
hey guys
Johnh
Those are your left and right eccentrics..these are used to adjust your downstops when setting up your car...they do not have any affect on the handling of the car...they are there to make it easier to setup the downstops and line evrything up....hope this helps....
Sippin Coladas and Chillin
robert maestrey is offline   Reply With Quote
Old 11-17-2006, 09:12 AM   #8370
jeff1's Avatar
No, they're not rubbing on the bulkhead. The rods have 3 months of race, and do a lot of snap to place it. One thing that I noticed the ball end of rod that is attached on servo saver ball is binding too much.. very rough, but the ball end to steering block is moving free
FOR SALE - Mugen MBX5T ProSpec and Kyosho STR with chassis conversion and Kyosho big MattWells R/C Items: For Sale/Trade 5 04-28-2017 10:25 AM
1986 1/12 Kyosho Plazma MKIII With Kyosho LeMan 600E Motor Funkymojo R/C Items: For Sale/Trade 2 05-17-2012 11:11 AM
Custom painted Kyosho SP2 and Kyosho STRR bodies.... RC3 Graphics SWEET W/ PICS CRFXXXT R/C Items: For Sale/Trade 1 01-07-2008 07:38 PM
MACH. 28/NEW PS, KYOSHO MINI INFERNO ST/W/3NEW IB1400 8 CELL PACKS, KYOSHO 1./8 BUGGY newbie2 R/C Items: For Sale/Trade 5 11-18-2007 06:07 PM
Convert Kyosho Quick Start system on Kyosho QRC to Pullstart Morpheus2be Monster Trucks 0 02-16-2005 11:26 PM
