Old 10-27-2006, 06:00 PM   #8281
Mike Ellis's Avatar
bjones, without knowing your total set up I don't know which way to send you. I would suggest you try the setup I gave Kyosho America for a track called Timezone. That setup is for a low to medium bite track and works ok with both the one way and front diff. I personally have never come to grips with 37's all the way around. I have run 40's and 42's in different combinations and had more luck. I run the wc shocks and silver springs with a light sway bar almost everywhere I go. Most of the changes have been with toe in in the rear and out in the front and different neg. cambers. If you can run the Timezone setup and feed back how it works for you I may be able to assist you more. You can use the link on my signature to get to the Kyosho site.
Hope to help, Mike
Mike Ellis is offline   Reply With Quote
Old 10-27-2006, 07:47 PM   #8282
thanks mike
have printed it off will try out this weekend this should give me a starting point will let you know the results and maybe you can point me in a direction from there.
cheers
bjones is offline   Reply With Quote
Old 10-28-2006, 04:53 AM   #8283
antoine80's Avatar
Originally Posted by oderem
after trying for a while adjusting the clutch my engine is still engaging too late on the rpms, if i add little screws like on the orion clutch, will the extra weight help the clutch to engage sooner?
why don't you buy a softer clutch spring?
antoine80 is offline   Reply With Quote
Old 10-28-2006, 03:58 PM   #8284
can you tell me wich one fits? thanks in advance.
oderem is offline   Reply With Quote
Old 10-29-2006, 06:33 AM   #8285
doki_doki's Avatar
Location: Cebu City, Philippines and Ocala, Florida, USA
i'm using the KYOSHO FMW16 CLUTCH SPRING (H) with great results. this is listed on the option parts section of the manual. the color is bronze if i'm not mistaken hope this helps
doki_doki is offline   Reply With Quote
Old 10-29-2006, 06:36 AM   #8286
doki_doki's Avatar
guys: would just like to ask how the sway bar works and what effect does on the kit if you make it harder or softer considering that all the other set-up factors remain the same. thanks
Old 10-29-2006, 01:42 PM   #8287
ziggy12345's Avatar
As the car rolls the anti roll bar transfers load from the inside wheel to the outside wheel. This loads up that side as if the spring is stiffer. The result is a faster action. The downside is that the car doesnt roll so far and so you get slightly less grip
Stiffen the roll bar on the front and you get fast initial turn in with a loss of mid corner steering.
Stiffen the roll bar on the back and you get initial understeer.
When setting up the car always try to compensate for the negative effects of a setupchange. For instance
For more reactive steering stiffen the roll bar. To negate the loss of mid corner steering move the caster clips to the front and lower the roll centre
Dedicated RC Car Speed Site
http://www.fast-rc.co.uk/forum/index.php
Sponsored by:
Norfolk and Chance
ziggy12345 is offline   Reply With Quote
Old 10-29-2006, 10:42 PM   #8288
doki_doki's Avatar
i see...thanks... was really happy with the effect of the front and rear sway bars on the kit. before i installed the sway bars, the rear end of the kit was very loose. and after installing it, the rear end was more planted...
Old 10-30-2006, 02:28 AM   #8289
rmdhawaii's Avatar
doki_doki: It would be great if we could get a summary of all of your tuning updates... diff oils, tires, etc. etc. (i.e. before -> after)
Nitro Knowledge Base: http://nitrokb.netne.net
My YouTube Channel: http://www.youtube.com/nitrokb -> Lots of on-road nitro & eletric action + some off-road as well
My Flickr Photostream: http://www.flickr.com/photos/nitrokb/
Kyosho V-ONE RRR WC (x2) \ XRAY T2'007 \ Also owned: XRAY NT1 & Mugen MTX-4
rmdhawaii is offline   Reply With Quote
Old 10-30-2006, 06:00 AM   #8290
antoine80's Avatar
I don't know which are the exact springs that fits, but they are listed in the option parts at the end of the RRR building guide book. There are medium and soft springs, i think that a medium on will let the engine to engage earlier in the RPMS.
What is the distance of the spring nut, the guide say 1.1 mm but 0.9 works fine, what distance do you use?
Old 10-30-2006, 07:10 PM   #8291
doki_doki's Avatar
well, when i was using the stock clutch spring that came with the kit, the distance of the spring nut was around 0.6 to 0.7mm. i had to loosen it so that the clutch would engage earlier. i did this because our tracks has only fair traction. following the recommended settings from the manual didn't work for me. engine had to reach a high rpm before the clutch engaged causing wheel spins. with this settings, sometimes the spring nut would loosen and cause damage to the clutch system. after changing to the FMW16 clutch spring, i was now able to screw in the the spring nut to 1.1mm. with this settting, the clutch would engage much earlier with the engine at a lower rpm as compared to the stock clutch spring. also, no more wheel spins was noted...
Old 10-30-2006, 07:44 PM   #8292
doki_doki's Avatar
sure....no problem
before
(front/rear)
diff: 50,000wt/20,000wt
shock oil: 50wt/50wt
springs: blue/silver
shock position: 2nd/4th from bottom
toe: 1 deg out/2 deg in
camber: -1 deg/-3 deg
swaybars: flat (0 deg)/stock evo swaybars (black color)
tires: 40/40
ride height: 5.5/6.0
droop: 1/3
roll center: stock manual settings
belts: loose
tracks: technical with fair grip (a bit bumpy)
after
(front/rear)
diff: 50,000wt/5,000wt
springs: blue/blue
shock position: 2nd/3rd from bottom
tires: 40/40
droop: 1/3
belts: loose
Old 10-30-2006, 08:14 PM   #8293
UncleTex's Avatar
Send a message via AIM to UncleTex Send a message via Yahoo to UncleTex
Default Southwest Series Finally - San Antonio, Texas
Kyosho Cars dominate the Field taking 8 out of the 12 "A" Main positions.
1. Tommy Porfirio 151 Kyosho KO Propo Rocket Science
2. Guillaume Herve 149 Mugen Airtronics BK
3. Ron Atomic 146 Kyosho Futaba Rocket Science
4. Joe Maxey 135 Mugen Airtronics Rocket Science
5. Anthony Hardee 126 Kyosho Propo Rocket Science
6. Todd Bathe 111 Kyosho Futaba Rocket Science
7. Jeff Parker 101 Kyosho Futaba Rocket Science
8. Ronnie Pena 80 Kyosho KO Propo Rocket Science
9. Luka Ruperts 31 Mugen KO Propo Blue Thunder
10. John Pena 26 Kyosho KO Propo Rocket Science
11. Ed Stewart 17 Kyosho Airtronics Byron
12. Mike Sambrano DNS Serpent KO Propo Rocket Science
UncleTex is offline   Reply With Quote
Old 10-30-2006, 08:45 PM   #8294
rmdhawaii's Avatar
Thanks doki_doki
Old 10-30-2006, 08:46 PM   #8295
rcabj's Avatar
hi...just got this kit less then a month...and last weekend was its 1st club race and with the stock setup i was able to reduce 0.5 sec of my best lap - ... the setup was still not the best or rather 80-90 percent. i feel when it get more dialed i can slash few more tenths...
the only upgrade i did was putting in the fr univrsal j and alu hexes. tq
p/s : for the moment i am not getting the turning that i want to in small or u turning...the car felt lazy during this stages, like the rear too much planted, at sweepers and large corners it was excellent... i was using 37 shore front and 40 rear...
BLacK cRoW RaCiNg TeaM
JBRCC
TEAM ORANGE
RCCUTM
pemandu upahan ;)
rcabj is offline   Reply With Quote
FOR SALE - Mugen MBX5T ProSpec and Kyosho STR with chassis conversion and Kyosho big MattWells R/C Items: For Sale/Trade 5 04-28-2017 10:25 AM
1986 1/12 Kyosho Plazma MKIII With Kyosho LeMan 600E Motor Funkymojo R/C Items: For Sale/Trade 2 05-17-2012 11:11 AM
Custom painted Kyosho SP2 and Kyosho STRR bodies.... RC3 Graphics SWEET W/ PICS CRFXXXT R/C Items: For Sale/Trade 1 01-07-2008 07:38 PM
MACH. 28/NEW PS, KYOSHO MINI INFERNO ST/W/3NEW IB1400 8 CELL PACKS, KYOSHO 1./8 BUGGY newbie2 R/C Items: For Sale/Trade 5 11-18-2007 06:07 PM
Convert Kyosho Quick Start system on Kyosho QRC to Pullstart Morpheus2be Monster Trucks 0 02-16-2005 11:26 PM
