Old 10-11-2006, 03:01 PM   #8206
antoine80's Avatar
Default droop settings..
a general question on droop settings,
i have 3racing blocks and droop measures. the droop gauge is
-10 -8 -6 ... -2 0 2 ... 6 8 10
ok, when in the setting data they say 2mm downstop then you should put the gauge to +2 or -2 ? for instance for the rear part in the setting data kyosho say 2mm downstop.
also if i am correct then droop settings differ according to tire diameter so it is not only the downstop settings.
antoine80 is offline   Reply With Quote
Old 10-11-2006, 04:35 PM   #8207
kewdawg's Avatar
-1st question: Whichever allows the arm to sag 2mm.
-2nd question: The droop setting doesn't change, just the amount you'll have after your tires get smaller.
Quinn Moon
Trinity / Epic / Revtech / VBC Racing USA / Mugen Seiki / Hot Race Tyres / SkyRocket Racing / SUPAFAST RC
kewdawg is offline   Reply With Quote
Old 10-11-2006, 05:27 PM   #8208
Trader Rating: 13 (93%+)
Originally Posted by kewdawg
Are the arms level with the chassis, angled up or angled down? You want the arms to be 2mm below level - creating 2mm of droop a.ka. sag.
my arms are angled up, they are 4mm above the chassis
so they sit on the 4 on the droop block
i use 63mm rear and 61 tyres front
Serpent 748 TQ | GIMAR Engines
Walter RC HObby | www.walterrchobby.com.au
BlueRC | www.bluerc.net
mrgsr is offline   Reply With Quote
Old 10-11-2006, 06:10 PM   #8209
jag
jag's Avatar
Originally Posted by dameetz
Has anyone of you tried the SP rear shock tower (VZW 207)? What is the diffence in handling did you notice? From what I can see it has got blue anodized rear bearing cover comes together with it, and the rear inner camber link pivot ball sits upwards instead of towards the front, and it has got 3 holes instead of 5 holes(EVO). Is this better? And what is the effect of having 2mm spacer under the pivot ball?
I have tried it. I have not had the chance to compare it to the stock in a back to back test. It seems to work well but I am using a slightly modified stock setup right now. It does add a little weight to the rear of the car.
As for the 2mm spacer, I find that removing it will increase the rear traction. I think it lowers the roll center.
jag is offline   Reply With Quote
Old 10-12-2006, 02:00 AM   #8210
antoine80's Avatar
i might haven't make my selft clear.. also i can not understand exactly you mean sag.. the 2mm of downstop in the settings data should be measure 2mm above chasis level or 2mm below chasis level? it is the way you read the setting data.
Old 10-12-2006, 07:27 AM   #8211
kewdawg's Avatar
You said, your arms are angled up, right? Then set the droop so the arms sag 2mm below being level (arms not angled up or down). don't go, solely by what the droop gauge shows. As long as its 2mm below level (the gauge may say -4, -6 or +2, 0. Droop gauges will differ according to brand and type.)
Quinn Moon
Old 10-12-2006, 09:35 AM   #8212
Default Drift wheels
Does drift wheel for the rear comes in various sizes i.e. 28mm 30mm or larger for 1/10 size GP?
Anyone uses any drifting wheel for v-1 3r yet? What brand do u use or what do u recommend?
Black_Widow is offline   Reply With Quote
Old 10-18-2006, 02:31 PM   #8213
robert maestrey's Avatar
Nope I dont drift .....but I know someone that does and I will try to get the info for you....
Sippin Coladas and Chillin
robert maestrey is offline   Reply With Quote
Old 10-18-2006, 02:55 PM   #8214
Novus's Avatar
Hey just wanted to ask you guys if the upper deck on the RRR can fit on the RR Evo....
Novus is offline   Reply With Quote
Old 10-18-2006, 07:28 PM   #8215
it will fit the rrr evo....no problem
Old 10-18-2006, 09:35 PM   #8216
drfritz's Avatar
BUT NOT THE RR EVO....
drfritz is offline   Reply With Quote
Old 10-19-2006, 12:25 AM   #8217
doki_doki's Avatar
Location: Cebu City, Philippines and Ocala, Florida, USA
guys: what adjustment should be made to make the rear end of the car more planted? our local tracks is technical. i'm running 40 shore foam tires on all fours. thanks
doki_doki is offline   Reply With Quote
Old 10-19-2006, 01:19 AM   #8218
if you have alot of traction you could try higher roll center, lower your shock positions(rear) what you are asking is pretty general neeed more info you want it more planted on off power,,, also what track conditions are you driving on...
Old 10-19-2006, 01:48 AM   #8219
doki_doki's Avatar
more traction on power...sorry about that also, traction is only fair. thanks
Old 10-19-2006, 02:09 AM   #8220
Novus's Avatar
Thumbs up
Thanks guys....
FOR SALE - Mugen MBX5T ProSpec and Kyosho STR with chassis conversion and Kyosho big MattWells R/C Items: For Sale/Trade 5 04-28-2017 10:25 AM
1986 1/12 Kyosho Plazma MKIII With Kyosho LeMan 600E Motor Funkymojo R/C Items: For Sale/Trade 2 05-17-2012 11:11 AM
Custom painted Kyosho SP2 and Kyosho STRR bodies.... RC3 Graphics SWEET W/ PICS CRFXXXT R/C Items: For Sale/Trade 1 01-07-2008 07:38 PM
MACH. 28/NEW PS, KYOSHO MINI INFERNO ST/W/3NEW IB1400 8 CELL PACKS, KYOSHO 1./8 BUGGY newbie2 R/C Items: For Sale/Trade 5 11-18-2007 06:07 PM
Convert Kyosho Quick Start system on Kyosho QRC to Pullstart Morpheus2be Monster Trucks 0 02-16-2005 11:26 PM
