Old 10-11-2006, 06:20 AM   #8191
SOLOARTIST 702's Avatar
Send a message via AIM to SOLOARTIST 702
Default hmm
Originally Posted by mrgsr
I had about 3mm from ride height front droop
and about 2mm from ride height rear droop
ive set the car to 0mm front and 4mm rear, 40 wt shock oil, silver springs all round and -2 rear toe in. 50k front diff and 5k rear diff, ill test it saturday and see how we go.
right now im trying to stop leaking shocks
thanks heaps guys
when you stop the leaking shocks let me know mine are leaking also cant seem to stop them ive tried everything
RC AMERICA / XRAY / HUDY/ MATRIX TIRES /KOPROPO / ORCAN GT3 /RED CUP RACING MEMBER / SPEEWORLD RACEWAY/ A+ performance parts /IVE SEEN THE XRAY TEAM DRIVE SO I GOT XRAY CARS / better to keep up than to catch up
WILLIAM PENDERGRASS
SOLOARTIST 702 is offline   Reply With Quote
Old 10-11-2006, 06:21 AM   #8192
Trader Rating: 13 (93%+)
Originally Posted by kewdawg
mrgsr,
4mm of rear droop is a lot! Are you measuring this by using Hudy droop gauges? I would strongly suggest using only 2mm of rear droop.
Im measuring this on hudy droop block and droop gauge
Serpent 748 TQ | GIMAR Engines
Walter RC HObby | www.walterrchobby.com.au
BlueRC | www.bluerc.net
mrgsr is offline   Reply With Quote
Old 10-11-2006, 06:47 AM   #8193
kewdawg's Avatar
Guys, awhile back, I posted pictures of a shock cap mod done to fix this problem. Basically, you drill a small hole in the cap where the bladder's lip sits. Similar to how the (original) Hpi Pro 4 shock caps are drilled to allow the shocks to self-bleed to give you perfect dampening every time you build them.
Quinn Moon
Trinity / Epic / Revtech / VBC Racing USA / Mugen Seiki / Hot Race Tyres / SkyRocket Racing / SUPAFAST RC
kewdawg is offline   Reply With Quote
Old 10-11-2006, 06:50 AM   #8194
kewdawg's Avatar
Unless, you're racing on a track with major dips and ruts and you need the ground clearance, then 4mm is too much. You'll continue to have the same problem.
Quinn Moon
Old 10-11-2006, 06:52 AM   #8195
thanks for your help.. so should i go up to say 6mm or more ?
Old 10-11-2006, 07:16 AM   #8196
dameetz's Avatar
Default SP REAR SHOCK TWR
Has anyone of you tried the SP rear shock tower (VZW 207)? What is the diffence in handling did you notice? From what I can see it has got blue anodized rear bearing cover comes together with it, and the rear inner camber link pivot ball sits upwards instead of towards the front, and it has got 3 holes instead of 5 holes(EVO). Is this better? And what is the effect of having 2mm spacer under the pivot ball?
Dudududududuuuuuu.....
dameetz is offline   Reply With Quote
Old 10-11-2006, 07:22 AM   #8197
mrgsr,
what will happen when the front ride height is 3mm and the rear ride height is 5 mm? Will this help to prevent the rear from skiing?
Black_Widow is offline   Reply With Quote
Old 10-11-2006, 07:22 AM   #8198
kewdawg's Avatar
You said, you were using Hudy droop gauges, right? Then you should set the droop at the 2mm mark on the gauge.
Quinn Moon
Old 10-11-2006, 07:24 AM   #8199
kewdawg's Avatar
No. Just the opposite. Make the changes we talked about and keep the ride height even - front to rear.
Quinn Moon
Old 10-11-2006, 07:27 AM   #8200
kewdawg's Avatar
No, haven't tried it yet. When you raise and level the camber link (also when you lengthen the camber link), you increase the amount of roll the chassis will exhibit.
Quinn Moon
Old 10-11-2006, 07:56 AM   #8201
excuse my ignorance hehe.. wouldnt this give the car more droop? unscrewing the droop screws will lower the arms to 2mm thus give more droop
my droop blocks are 10mm high andthe droop gauge at 10mm is 0
is this right ?
Old 10-11-2006, 07:59 AM   #8202
Default leaking shock..
Ive beentold to put a small dab of shoe goo to under the shock cap to seal the black part tothe shock cap.
hmm is this a bandaid type solution ? he saidhis shock have never once leaked since this mod
Old 10-11-2006, 08:03 AM   #8203
kewdawg's Avatar
is this right ?
Are the arms level with the chassis, angled up or angled down? You want the arms to be 2mm below level - creating 2mm of droop a.ka. sag.
Quinn Moon
Old 10-11-2006, 08:05 AM   #8204
kewdawg's Avatar
Well, that will keep the bladder from dropping out of the cap and allowing oil behind it, but what about being able to "bleed" them properly?
Quinn Moon
Old 10-11-2006, 08:09 AM   #8205
Default hmm
thanks
WILLIAM PENDERGRASS
FOR SALE - Mugen MBX5T ProSpec and Kyosho STR with chassis conversion and Kyosho big MattWells R/C Items: For Sale/Trade 5 04-28-2017 10:25 AM
1986 1/12 Kyosho Plazma MKIII With Kyosho LeMan 600E Motor Funkymojo R/C Items: For Sale/Trade 2 05-17-2012 11:11 AM
Custom painted Kyosho SP2 and Kyosho STRR bodies.... RC3 Graphics SWEET W/ PICS CRFXXXT R/C Items: For Sale/Trade 1 01-07-2008 07:38 PM
MACH. 28/NEW PS, KYOSHO MINI INFERNO ST/W/3NEW IB1400 8 CELL PACKS, KYOSHO 1./8 BUGGY newbie2 R/C Items: For Sale/Trade 5 11-18-2007 06:07 PM
Convert Kyosho Quick Start system on Kyosho QRC to Pullstart Morpheus2be Monster Trucks 0 02-16-2005 11:26 PM
