Old 10-09-2006, 03:23 AM   #8161
Trader Rating: 13 (93%+)
Thanks Ziggy! im gonna head out to the track saturday and try a few things
might try and stiffen the rear a little and soften the front and see hot it goes.
Thanks!
Serpent 748 TQ | GIMAR Engines
Walter RC HObby | www.walterrchobby.com.au
BlueRC | www.bluerc.net
mrgsr is offline   Reply With Quote
Old 10-09-2006, 09:09 AM   #8162
Originally Posted by antoine80
it wasn't that nice.. do you think i should fix it or go to buy a new engine? the price of the axle is about 140Euro... so it is about the 1/2 of a new engine..
I would advise to go for a new engine. (Keep the heat shink or other non wearing parts for spare) If you would to get back the part tat was dmg n fix it back to ur engine, there are few points to note; i.e ur crankcase has already worn off slightly unless it is still new when u broke e shaft. Puting back a new shaft will create further wearing of ur crankcase that will widen the shaftcase. However, I can't garantte that it just my mechanical terms.
Maybe some1 would like to give more suggestion
Black_Widow is offline   Reply With Quote
Old 10-09-2006, 09:36 AM   #8163
Originally Posted by ziggy12345
The RRR is prone to the back sliding out. If you can control it then the car can be driven fast.
The front is too hard compared to the back. I'll explain.
As the weight transfers over when turning the front will load up quicker than the back. The back will have to roll more to get the same grip and looses traction before the outside wheel can bite.
Soften the front and increase the roll bar.
Increase the rear springs and increase the rear shock oil
Stand the rear shocks up to the top
You might find you will loose mid corner steering so soften the front roll bar to compensate if you have gone too far.
Cheers
Cheers
Hi I'm also facing this problem. What do u mean by soften? To lengthen the suspension? Is it the roll bar (red box) u refering?
Old 10-09-2006, 10:25 AM   #8164
antoine80's Avatar
you are correct on this, i had run about 5-6litrs untill now i don't know if these are enough - little or a lot the price for the new item is about 120E and the new engine costs about 300.. and if going for a new engine the question is what engine i always had the idea that novarossi are good engines, i still think of the same thing.. i suppose that the damage was more like an accident rather than a bad engine. i don't know anyway..
antoine80 is offline   Reply With Quote
Old 10-09-2006, 01:39 PM   #8165
SOLOARTIST 702's Avatar
Send a message via AIM to SOLOARTIST 702
Default hmm
just a ? what battery pack you guys using just curious trying to put my car on a diet
RC AMERICA / XRAY / HUDY/ MATRIX TIRES /KOPROPO / ORCAN GT3 /RED CUP RACING MEMBER / SPEEWORLD RACEWAY/ A+ performance parts /IVE SEEN THE XRAY TEAM DRIVE SO I GOT XRAY CARS / better to keep up than to catch up
WILLIAM PENDERGRASS
SOLOARTIST 702 is offline   Reply With Quote
Old 10-09-2006, 02:28 PM   #8166
ziggy12345's Avatar
Change the springs to soften the suspention. Gold springs are hard, Black medium and silver soft. If you change the springs you need to change the weight of the oil. 35wt is medium 20 wt soft 50wt hard OK.
Dedicated RC Car Speed Site
http://www.fast-rc.co.uk/forum/index.php
Sponsored by:
Norfolk and Chance
ziggy12345 is offline   Reply With Quote
Old 10-09-2006, 05:12 PM   #8167
GMartinez's Avatar
Trader Rating: 85 (100%+)
smc 1200 mah thinking of lipo but worried about collisions
www.fullthrottlercraceway.com
Home of The U.S. World Nitro Cup 2013,2014,2015,2016
2014 Roar Electric Nationals, IFMAR ISTC Worlds, 2015 Roar Fuel Nationals
2017 U.S.World Nitro Cup Nov 29th - Dec 3rd
U.S.Open Fuel Championship Returning soon
GMartinez is offline   Reply With Quote
Old 10-09-2006, 10:35 PM   #8168
Default hmm
thanks i wont go lipo unless i become the man but im too old to be the man thanks again
WILLIAM PENDERGRASS
Old 10-10-2006, 12:19 AM   #8169
Default front solid axle ?
ive seen a few front rigid axles lately
1. a plastic one like on the v-one s3
2. 3 racing have one that uses rubber bands that hold the pins in
3. the original diff case with the plastic centre.
what have you guys found to be the best?
i have number 3 now but was thinking the rotating mass is too much ?
Old 10-10-2006, 02:47 AM   #8170
maskedrider's Avatar
Anyone try 50k front and 30k rear ?
I'm running on two swepper and a long straight track
Or what is the best combination for front and rear diff oil ?
Kyosho- Sirio/ OS engine- AVID bearing- Blue thunder fuel- Proline- RC dynamite- Sanwa- RC Art
maskedrider is offline   Reply With Quote
Old 10-10-2006, 02:52 AM   #8171
esham's Avatar
Masked why don't you try oneway.
esham is offline   Reply With Quote
Old 10-10-2006, 02:56 AM   #8172
esham...i'm been running One-way since day one....wanna to try on Diff. this time round to see if suit my ride
Old 10-10-2006, 04:27 AM   #8173
esham's Avatar
Ok then. Long time i didn't try diff out front. I believe the handling will also affected by the track traction condition. But in my normal understanding heavier front diff will make you car understeer off power. U have to test the combination to get the correct combo for you track traction.
Front/Rear
50K/30K
30K/10K
10K/7K
Hope others can share more.
Old 10-10-2006, 06:29 AM   #8174
vapex 6v 1400 mAh, last almost a day race.
Old 10-10-2006, 06:36 AM   #8175
Default leaky shocks
regarding the rrr shocks? I seam to forever be having a problem with them leaking from around the top around the black shock cap that connects to the ball end.
i tried tamiya bladders and it helped. ive just purchased new kyosho bladders and lined the inside of the cap with grease this is the best i could get it.
what am i doing wrong ?
FOR SALE - Mugen MBX5T ProSpec and Kyosho STR with chassis conversion and Kyosho big MattWells R/C Items: For Sale/Trade 5 04-28-2017 10:25 AM
1986 1/12 Kyosho Plazma MKIII With Kyosho LeMan 600E Motor Funkymojo R/C Items: For Sale/Trade 2 05-17-2012 11:11 AM
Custom painted Kyosho SP2 and Kyosho STRR bodies.... RC3 Graphics SWEET W/ PICS CRFXXXT R/C Items: For Sale/Trade 1 01-07-2008 07:38 PM
MACH. 28/NEW PS, KYOSHO MINI INFERNO ST/W/3NEW IB1400 8 CELL PACKS, KYOSHO 1./8 BUGGY newbie2 R/C Items: For Sale/Trade 5 11-18-2007 06:07 PM
Convert Kyosho Quick Start system on Kyosho QRC to Pullstart Morpheus2be Monster Trucks 0 02-16-2005 11:26 PM
