Old 10-08-2006, 07:15 AM   #8146
Originally Posted by antoine80
hi all..
this is what hapened to my engine yesterday i think i am lucky that pieces of the broken iron didn't scratch the piston...
why this think hapened? any idea? just before it smashes i had a crash with an other car, i was hited on the right rear wheel but nothing was broken... although i had the filling that the car wasn't able to run... after that the engine stoped.. i started it again without no problem and after a big straigh the engine stoped again. the rest you can see in the picture
antony
I feel sorry for u, it looks terrible having to suffer that crash. It seems as though the impact on the shaft have caused a dent line of damage and give way when it cant take the rev
Black_Widow is offline   Reply With Quote
Old 10-08-2006, 07:58 AM   #8147
maskedrider's Avatar
hey dude..hows your car anyway ?
Kyosho- Sirio/ OS engine- AVID bearing- Blue thunder fuel- Proline- RC dynamite- Sanwa- RC Art
maskedrider is offline   Reply With Quote
Old 10-08-2006, 08:03 AM   #8148
manage to get it to run after some deep finding n readings on the clutch issue however i notice a lot of bubble in my fuel line, btw is it recommended to place a fuel filter?
Old 10-08-2006, 08:09 AM   #8149
SOLOARTIST 702's Avatar
Send a message via AIM to SOLOARTIST 702
Default hmm
i think the tank has a filter in it
RC AMERICA / XRAY / HUDY/ MATRIX TIRES /KOPROPO / ORCAN GT3 /RED CUP RACING MEMBER / SPEEWORLD RACEWAY/ A+ performance parts /IVE SEEN THE XRAY TEAM DRIVE SO I GOT XRAY CARS / better to keep up than to catch up
WILLIAM PENDERGRASS
SOLOARTIST 702 is offline   Reply With Quote
Old 10-08-2006, 08:11 AM   #8150
are you use those like a bomb filter fitting between the fule line?? you need to clean it time to time to pervent blockage, and wherelse not nessary to fit that
btw, where u run your car at ?
correct
Old 10-08-2006, 08:15 AM   #8151
does drift wheels for the rear comes in different sizes for 1/10 car?
Old 10-08-2006, 08:17 AM   #8152
what drift wheel u refer at ?
Old 10-08-2006, 08:19 AM   #8153
1. no lah mine is those mesh type leh not stone type.
2. Use for drifting.
Old 10-08-2006, 08:23 AM   #8154
Default HMM
correct
i race in vegas, & california three track wonder
WILLIAM PENDERGRASS
Old 10-08-2006, 08:26 AM   #8155
congrat for your acheivedment
Old 10-08-2006, 02:15 PM   #8156
antoine80's Avatar
it wasn't that nice.. do you think i should fix it or go to buy a new engine? the price of the axle is about 140Euro... so it is about the 1/2 of a new engine..
antoine80 is offline   Reply With Quote
Old 10-08-2006, 07:30 PM   #8157
Trader Rating: 13 (93%+)
Default need help with rear side bite and turn in loose rear
hey guys im hoping you can share some thought on my car setup
i need some help with rear side bite traction and off power turn in with the rear sliding out.
racers say its agood tratciuon track with everyonre running 40 shore all round tyres. its short and technical.
front: black springs, 50,000wt diff oil, standard roll centre positions, castor clips one on each side of arm,+1 toe out, camber is set for tyre sto wear flat. 50wt shock oil. The car did work better when i had 30,000wt diff oil, sway bar set to 45degrees
rear: silver springs on bottom shock position, 40wt shock oil. black sway bar with ends all the way in, -3 toe in. canber is -3.5 tyres are wearing flat. 5000wt diff oil. roll centre is standard turned around to lower roll centre
gearing is 1 less tooth on each spur.
thanks heaps guys
Serpent 748 TQ | GIMAR Engines
Walter RC HObby | www.walterrchobby.com.au
BlueRC | www.bluerc.net
mrgsr is offline   Reply With Quote
Old 10-09-2006, 01:18 AM   #8158
ziggy12345's Avatar
The RRR is prone to the back sliding out. If you can control it then the car can be driven fast.
The front is too hard compared to the back. I'll explain.
As the weight transfers over when turning the front will load up quicker than the back. The back will have to roll more to get the same grip and looses traction before the outside wheel can bite.
Soften the front and increase the roll bar.
Increase the rear springs and increase the rear shock oil
Stand the rear shocks up to the top
You might find you will loose mid corner steering so soften the front roll bar to compensate if you have gone too far.
Cheers
Cheers
Dedicated RC Car Speed Site
http://www.fast-rc.co.uk/forum/index.php
Sponsored by:
Norfolk and Chance
ziggy12345 is offline   Reply With Quote
Old 10-09-2006, 01:25 AM   #8159
Cheers
i should silver springs all round ?
what do you mean by increase the rear springs and shock oil?
would using the same weight shock oil all round help? the track is flat with hardly any bumps at all.
wouldnt standing the rear shocks up decrease rear traction?
thanks!
Old 10-09-2006, 03:03 AM   #8160
ziggy12345's Avatar
You have to make sure the back and front is balanced. If its loosing traction at the back then its not loading up fast enough. Stiffen the springs and oil.
Experiment with differeent srpings but dont forget the car acts as one unit. Adjusting the back will change the balance of the car and therfore effect the overall handeling.
When you say you have soft on the back and it has no grip then its because its not balanced with the front. Look at he front and see whats going on
Sponsored by:
Norfolk and Chance
FOR SALE - Mugen MBX5T ProSpec and Kyosho STR with chassis conversion and Kyosho big MattWells R/C Items: For Sale/Trade 5 04-28-2017 10:25 AM
1986 1/12 Kyosho Plazma MKIII With Kyosho LeMan 600E Motor Funkymojo R/C Items: For Sale/Trade 2 05-17-2012 11:11 AM
Custom painted Kyosho SP2 and Kyosho STRR bodies.... RC3 Graphics SWEET W/ PICS CRFXXXT R/C Items: For Sale/Trade 1 01-07-2008 07:38 PM
MACH. 28/NEW PS, KYOSHO MINI INFERNO ST/W/3NEW IB1400 8 CELL PACKS, KYOSHO 1./8 BUGGY newbie2 R/C Items: For Sale/Trade 5 11-18-2007 06:07 PM
Convert Kyosho Quick Start system on Kyosho QRC to Pullstart Morpheus2be Monster Trucks 0 02-16-2005 11:26 PM
