Old 09-20-2006, 06:32 PM   #8041
litespeed-dom's Avatar
You already have one of the torque'st .12 motor out there. Stick with your TZ.
Dom
Team Kyosho America - Team Br00d Racing - Team R/C Plus - GQ Racing Tyres - Slapmaster Tools - FSX Racing
litespeed-dom is offline   Reply With Quote
Old 09-20-2006, 06:32 PM   #8042
Originally Posted by boner
Yes, it's able to support your RX and servo but the question is how is it going to fit on your RRR (assuming that is the car the battery is going on).
Thought of using the fabric velko for different sides to attach secure the battery plate n the batteries?
Black_Widow is offline   Reply With Quote
Old 09-20-2006, 06:49 PM   #8043
spyspeed's Avatar
Originally Posted by markp27
What tyres are you using? Make sure you're using at least a 2mm split front-to-rear.
If you're car is suffering from turn-in understeer either change the spool to a diff with 30,000 or 50,000 oil or even a one-way, as long as you don't have to brake too much.
Set the rear anti-roll bar harder or go to the harder version.
How do you have your front anti-roll bar set?
40Shore up front and 37 rear.. and 2mm split front-to-rear..
front roll bar fully horizontal
that's why i go for spool..
spyspeed is offline   Reply With Quote
Old 09-20-2006, 07:10 PM   #8044
spyspeed's Avatar
Why my pinion gear wear faster? i think i set gear mesh correctly..
may i use steel pinion gear? unfortunelly my LHS out of stock the steel ones.
Can i use Mugen MTX4 1st and 2nd pinion gear? is that work with V1RRR standart clutch bell? Thanks
Old 09-20-2006, 09:01 PM   #8045
rayjay's Avatar
Smile re-motor
Cheers mate. On the Novarossi...How does it compare to the TZ then? Im looking at getting it fairly cheap..Maybe to have as a second motor or backup motor. However... if its not as good as the TZ, i wont worry about getting it..
rayjay is offline   Reply With Quote
Old 09-20-2006, 09:51 PM   #8046
Originally Posted by rmdhawaii
THANKS!!!
oderem is offline   Reply With Quote
Old 09-21-2006, 07:03 AM   #8047
robert maestrey's Avatar
Originally Posted by rayjay
I have a question...I currently have a rrr with a .12 OS TZ. Our track is tight and twisty and i was looking at getting a motor with a bit more punch in it. Im looking at getting an Novarossi Rex RER12. Any thoughts if this will be much of an improvement. Also... what motor do you guys recomend.
I have also used the Tz in the past with great results......but the motor I would recommend if you want awesome grunt and so far has been a workhorse is the new Evo3 STI made by Sirio...just loook at what it did at the worlds.... This motor has taken very good care of me at very big races and i have no complaints... Hope this helps
Sippin Coladas and Chillin
robert maestrey is offline   Reply With Quote
Old 09-21-2006, 07:09 AM   #8048
wallyedmonds's Avatar
but novarossis wont break like a sirio and many have broken the sti
wallyedmonds is offline   Reply With Quote
Old 09-21-2006, 07:10 AM   #8049
no
Old 09-21-2006, 07:12 AM   #8050
Dom
if you think it has torque than theres somthing wrong with your other motors.
Old 09-21-2006, 04:14 PM   #8051
rayjay's Avatar
Smile re- motor
Thanks......
Old 09-21-2006, 04:37 PM   #8052
Sorry man, judging from your posts on different threads, you really have no clue what you are talking about. That "many" have broken STI is actually just you.
Dom
Old 09-21-2006, 07:50 PM   #8053
GMartinez's Avatar
Trader Rating: 85 (100%+)
Wally I know a lot of guys that the cranks in a Novarossi snapped. to make out such a loud opinion that novarossi does not break as easy as a sirio is completly false. Just cause you had a problem & Kyosho took care of you so promptly better than a lot more people can appreciate. I seen numerous times & complaints about Novarossi @ the LHS. Novarossi would comment not our problem you did something wrong to the motor. Just make's it seem that you are being inconsiderate for what they did for you. as for torque it's all in the gearing & clutch setup which you probally don't have a clue on how to set up your motor for certain tracks. The Sirio has more torque over certain motors. What motor are you using in comparision that you are basing this info.
Be more specific & give more details than just bashing the sirio motor.
I guess all the motors that made it to the top ten in the worlds were just an average motor with no torque
www.fullthrottlercraceway.com
Home of The U.S. World Nitro Cup 2013,2014,2015,2016
2014 Roar Electric Nationals, IFMAR ISTC Worlds, 2015 Roar Fuel Nationals
2017 U.S.World Nitro Cup Nov 29th - Dec 3rd
U.S.Open Fuel Championship Returning soon
GMartinez is offline   Reply With Quote
Old 09-22-2006, 06:54 AM   #8054
markp27's Avatar
Send a message via ICQ to markp27
The understeer you're suffering from will be due to you runing the front tyres harder than the rears. Run 40 front and rear and if you still don't have enough steering, then 40 rear and 37 front.
What do you mean about the spool?
markp27 is offline   Reply With Quote
Old 09-22-2006, 06:57 AM   #8055
markp27's Avatar
Dom
I run both the OS MAX TZ and the Sirio STI. I find that the OS MAX has more torque than my STI, but the STI will rev higher and is better for more open, flowing circuits. For smaller circuits where low down power if required, the TZ is very hard to beat.
Cheers, Mark.
FOR SALE - Mugen MBX5T ProSpec and Kyosho STR with chassis conversion and Kyosho big MattWells R/C Items: For Sale/Trade 5 04-28-2017 10:25 AM
1986 1/12 Kyosho Plazma MKIII With Kyosho LeMan 600E Motor Funkymojo R/C Items: For Sale/Trade 2 05-17-2012 11:11 AM
Custom painted Kyosho SP2 and Kyosho STRR bodies.... RC3 Graphics SWEET W/ PICS CRFXXXT R/C Items: For Sale/Trade 1 01-07-2008 07:38 PM
MACH. 28/NEW PS, KYOSHO MINI INFERNO ST/W/3NEW IB1400 8 CELL PACKS, KYOSHO 1./8 BUGGY newbie2 R/C Items: For Sale/Trade 5 11-18-2007 06:07 PM
Convert Kyosho Quick Start system on Kyosho QRC to Pullstart Morpheus2be Monster Trucks 0 02-16-2005 11:26 PM
Currently Active Users Viewing This Thread: 2 (0 members and 2 guests)
