Old 09-20-2006, 12:38 AM   #8026
V1-RRR-WC's Avatar
Originally Posted by mrgsr
hey guys
im trying to under stand the rear camber link a little more
i have my car handling awesome but the rear camber link doesnt seam to be strong enough, always after races i find the rear camber link bent, like the turnbuckle isnt long enough..
what effect would moving the rear camber link to the outerhole give ? im using the original rear camber link.
i find with my camber angle of about 3.5 degrees my car works best
thanks
Hey mrsgr,
I had the same problem and also run a 3.5 camber on my car. Have a look at what I did with the extra link ends that come in your kit.
Cut off about 3mm on the longer link ends and thread them right in. I still get up to 5 deg camber if ever I wanted, but now have a reinforced arm.
Hope this info helps.
V1-RRR-WC is offline   Reply With Quote
Old 09-20-2006, 05:59 AM   #8027
Trader Rating: 13 (93%+)
v1-rrr-wc thats an awesome mod!! thanks heaps dude
i just did it then but just replaced one of the ends with a lonegr end
feels much stronger now
Serpent 748 TQ | GIMAR Engines
Walter RC HObby | www.walterrchobby.com.au
BlueRC | www.bluerc.net
mrgsr is offline   Reply With Quote
Old 09-20-2006, 06:24 AM   #8028
Originally Posted by rmdhawaii
Does anyone know who all of these guys are in this photo?
http://210.253.122.57/blog/rc/log/im...06090059_1.jpg
i know about half of them... does that count?
ae_ntc3 is offline   Reply With Quote
Old 09-20-2006, 06:48 AM   #8029
Originally Posted by litespeed-dom
What is your rear roll center at? Also how many spacers do you have underneath the outside camber link?
Dom
my rear roll centre is set to the standard one upside down so its slightly lower than standard. I took both the spacers off under the outside link and this actually gave thecar more side bite and thats what im after
Old 09-20-2006, 06:49 AM   #8030
Originally Posted by markp27
Mrgsr,
If you're still getting positive wear at between -3.5 and -4 Degrees, then I would suspect that the tyre rims are too soft. Which tyres are you using?
Cheers, Mark.
I use the kawahara zba wheel/tyre. these wheels sea to be the most strongest ive used
Old 09-20-2006, 09:19 AM   #8031
SOLOARTIST 702's Avatar
Send a message via AIM to SOLOARTIST 702
Default hmm
a few ron atomic ,josh cyrul,shimo,chris tos, adrien bertien forgot the bottom right guys name
RC AMERICA / XRAY / HUDY/ MATRIX TIRES /KOPROPO / ORCAN GT3 /RED CUP RACING MEMBER / SPEEWORLD RACEWAY/ A+ performance parts /IVE SEEN THE XRAY TEAM DRIVE SO I GOT XRAY CARS / better to keep up than to catch up
WILLIAM PENDERGRASS
SOLOARTIST 702 is offline   Reply With Quote
Old 09-20-2006, 11:02 AM   #8032
maskedrider's Avatar
any/what different between running 30k and 50k on rear diff.
Kyosho- Sirio/ OS engine- AVID bearing- Blue thunder fuel- Proline- RC dynamite- Sanwa- RC Art
maskedrider is offline   Reply With Quote
Old 09-20-2006, 11:11 AM   #8033
dodo's Avatar
Send a message via Yahoo to dodo
ken furukawa?
dodo is offline   Reply With Quote
Old 09-20-2006, 11:16 AM   #8034
dodo's Avatar
the smaller the number will give you more off power steering but the car tends to be more twitchy on the straights. the bigger the number will give you more stable car on the straights but less off power steering (more understeer).
(somebody correct me if i'm wrong pls)
Old 09-20-2006, 12:09 PM   #8035
V1-RRR-WC's Avatar
No probs mrgsr! Your timing could not have been better.
When I lost a race only last weekend because of a tap from another car that broke this link arm, I vowed never to let this happen again. This is how I view all my mistakes in RC. (Never again)
The threads on the stock link ends were bearly holding so a slight tap in the right position and POP!!!!
Glad to help.
Old 09-20-2006, 12:17 PM   #8036
boner's Avatar
Yes, it's able to support your RX and servo but the question is how is it going to fit on your RRR (assuming that is the car the battery is going on).
Originally Posted by Black_Widow
Can this Sanyo Nimh 6v 2500 mAh Rx battery pack support Futaba R203HF Rx and 2 nos of Futaba S9451 Servos?
boner is offline   Reply With Quote
Old 09-20-2006, 12:35 PM   #8037
when running on a track with a hell whole lot of traction, i could only assum a brand new asphault track, run 50k (or drag racing, but then you would probably want to lock the rear diff up.. but i dont know a whole lot about that since i never drag race before). a track with good traction run 30k. and a track with low traction run 10k.
the difference is when cornering, a lighter oil lets the rear tires counter rotate allowing for better drivability on low traction.
the drawback is that the car will have less acceleration coming out of the turn.
Joe Chaplow is offline   Reply With Quote
Old 09-20-2006, 05:13 PM   #8038
where i can find part vz109 servo saver nut? is on back order on shoppatron, i been looking for it locally with no luck, my car is out of comission due to this, any help will be apreciated.
oderem is offline   Reply With Quote
Old 09-20-2006, 05:30 PM   #8039
rmdhawaii's Avatar
Try these guys:
http://www.acehardwarehobbies.com/2....2aa2217eaa2b66
Nitro Knowledge Base: http://nitrokb.netne.net
My YouTube Channel: http://www.youtube.com/nitrokb -> Lots of on-road nitro & eletric action + some off-road as well
My Flickr Photostream: http://www.flickr.com/photos/nitrokb/
Kyosho V-ONE RRR WC (x2) \ XRAY T2'007 \ Also owned: XRAY NT1 & Mugen MTX-4
rmdhawaii is offline   Reply With Quote
Old 09-20-2006, 06:24 PM   #8040
rayjay's Avatar
Default re-motor
I have a question...I currently have a rrr with a .12 OS TZ. Our track is tight and twisty and i was looking at getting a motor with a bit more punch in it. Im looking at getting an Novarossi Rex RER12. Any thoughts if this will be much of an improvement. Also... what motor do you guys recomend.
rayjay is offline   Reply With Quote
FOR SALE - Mugen MBX5T ProSpec and Kyosho STR with chassis conversion and Kyosho big MattWells R/C Items: For Sale/Trade 5 04-28-2017 10:25 AM
1986 1/12 Kyosho Plazma MKIII With Kyosho LeMan 600E Motor Funkymojo R/C Items: For Sale/Trade 2 05-17-2012 11:11 AM
Custom painted Kyosho SP2 and Kyosho STRR bodies.... RC3 Graphics SWEET W/ PICS CRFXXXT R/C Items: For Sale/Trade 1 01-07-2008 07:38 PM
MACH. 28/NEW PS, KYOSHO MINI INFERNO ST/W/3NEW IB1400 8 CELL PACKS, KYOSHO 1./8 BUGGY newbie2 R/C Items: For Sale/Trade 5 11-18-2007 06:07 PM
Convert Kyosho Quick Start system on Kyosho QRC to Pullstart Morpheus2be Monster Trucks 0 02-16-2005 11:26 PM
