Old 09-12-2006, 02:30 AM   #7951
MCRUZ's Avatar
Wink
Originally Posted by ickvanovs
my rrr always spin when i try to turn off-throttle
but on throttle, the car tend to understeer
what should i do?
Off throttle add more droop to the rear end. Your car is diving too much into a corner. Keep adding till it goes away. Make sure your tires are not too soft in front also. Understeer, not enough droop in front and rear suspension maybe too soft. Try to flatten the front meaning the arms don't drop too much. This should help.
M32EVOX
MCRUZ is offline   Reply With Quote
Old 09-12-2006, 03:48 AM   #7952
ianhobbies's Avatar
Location: Costa Del Sol, Marbella, Spain www.bradir.net
Send a message via ICQ to ianhobbies
Default what's this?
http://www.kyosho.com/jpn/support/recall/20060907.html
what's this?
WWW.BRADIR.NET - The Radio Control Motorsport Blog! / twitter @ianhobbies
ianhobbies is offline   Reply With Quote
Old 09-12-2006, 04:29 AM   #7953
buboy28's Avatar
Send a message via AIM to buboy28 Send a message via Yahoo to buboy28
Originally Posted by ianhobbies
from the site its says about the RRR-EVO Convertion kit regarding the damper springs translated it via babelfish but the english translation is a little bit blurry maybe someone here knows how to read Japanese text and translate it clearly please
buboy28 is offline   Reply With Quote
Old 09-12-2006, 04:30 AM   #7954
doki_doki's Avatar
Location: Cebu City, Philippines and Ocala, Florida, USA
hmmm...i don't undertand a thing. it's all in japanese
doki_doki is offline   Reply With Quote
Old 09-12-2006, 07:50 AM   #7955
bjc
This is what I translated it to be in Jap, just use the language tool in google search HERE -
“The No.36502 V-ONE RRR Evo. conversion kit” inside, in damper spring news of contents difference commodity mixture
 The capital trade product the patronage granting it is grateful always truly.
 Well, shipment, presently you have sold late from July, “No. In the part product of 36502 V-ONE RRR Evo. conversion kits”, usually the for front (length 21mm) 2, the for rear (length 26mm) 2 the commodity of the contents difference having mixed into the damper spring of the expectation which has entered, was ascertained.
 Furthermore, the for front 4, 0 and the like for the rear are verified as a contents difference.
  The customer whom purchase it receives is very much to be the number of hands, but verification it receives the contents of the corresponding part, when the contents difference it was verified, communication it can receive to our company user consultation room, the fish you say to ask.
 Because in the future it starts expecting perfection in prevention quality control of recurrence of this kind of situation, that also in the future patronage it grants the capital trade product, we ask.
< Inquiry >
■TEL: 046-229-4115 ■FAX: 046-229-1501
* Office Hours: Monday ~ Friday (celebration national holiday is excluded) 10: 00~18: 00 (as for Mail 24 hour acceptances)
bjc is offline   Reply With Quote
Old 09-13-2006, 08:02 AM   #7956
jjmudd's Avatar
WOW.
jjmudd is offline   Reply With Quote
Old 09-14-2006, 07:08 AM   #7957
Send a message via MSN to ickvanovs
Originally Posted by drfritz
Need more info than that.
what you runnung diff wise, drop, toe,tire ect.
Originally Posted by antoine80
for the understeer try to remove a bit droop from the front wheels try very little each time 2 degrees each time or 2 minutes of hour each time.
for me the problems with the back of the car were solved either when i changed the rear absorbers to a more vertical position or changed the shocks to harder ones (the red ones from evolva)
hey guys, thx for the input
hmm actually im not really sure what setup i ran last time. my friend set it up 2 months ago. i never care about setup before, but now i know that i need a properly setup car to have a good run.
currently im still rebuilding my kit, any setup recommendation i can start with?
btw i got rrr almost wce with sirio evo 2 engine.
ickvanovs is offline   Reply With Quote
Old 09-14-2006, 07:29 AM   #7958
dodo's Avatar
Send a message via Yahoo to dodo
start running 2mm split between your front and rear tires (front smaller) and everything will greatly improve. no use playing around your setup and not running split on your tires. have you try your car again lately with split as i told u before?
dodo is offline   Reply With Quote
Old 09-14-2006, 09:33 AM   #7959
not yet
i just got access to a tire truer
Old 09-14-2006, 09:40 AM   #7960
Default engine installation for kyosho v-one rrr wc step 43
dun really understand what it mean in this picture. Is this portion suppose to be loose to allow it to shift 0.5mm? If so it will be loose on the cap screw at the end. Can someone advise me hw I shld go abt it to install correctly .
Black_Widow is offline   Reply With Quote
Old 09-14-2006, 09:52 AM   #7961
antoine80's Avatar
download from Kyosho website the RRR EVO build document, it has more info for setting up the clutch bell. It describes it in two steps.
antoine80 is offline   Reply With Quote
Old 09-14-2006, 12:23 PM   #7962
ianhobbies's Avatar
Default worlds
things are looking good for the kyosho boys in the world championships!
Old 09-14-2006, 01:37 PM   #7963
rmdhawaii's Avatar
You might want to go to my Web site and read through the build tips. It offers some suggestions on how to properly adjust the clutch. Link is in my signature.
Nitro Knowledge Base: http://nitrokb.netne.net
My YouTube Channel: http://www.youtube.com/nitrokb -> Lots of on-road nitro & eletric action + some off-road as well
My Flickr Photostream: http://www.flickr.com/photos/nitrokb/
Kyosho V-ONE RRR WC (x2) \ XRAY T2'007 \ Also owned: XRAY NT1 & Mugen MTX-4
rmdhawaii is offline   Reply With Quote
Old 09-14-2006, 11:18 PM   #7964
Thanks for the info, btw which area is the endply. Sorry still rookie and just setup my new v-one rrr with my o.s .12 engine no one to turn to but this forum helps alot for me to pick this hooby up.
Your advise needed.
Thanks again
Old 09-14-2006, 11:46 PM   #7965
rmdhawaii's Avatar
Your advise needed.
Thanks again
"End play" is the amount of movement between the rear clutch bell bearing and the end of the threaded shaft just in front of the clutch nut.
FOR SALE - Mugen MBX5T ProSpec and Kyosho STR with chassis conversion and Kyosho big MattWells R/C Items: For Sale/Trade 5 04-28-2017 10:25 AM
1986 1/12 Kyosho Plazma MKIII With Kyosho LeMan 600E Motor Funkymojo R/C Items: For Sale/Trade 2 05-17-2012 11:11 AM
Custom painted Kyosho SP2 and Kyosho STRR bodies.... RC3 Graphics SWEET W/ PICS CRFXXXT R/C Items: For Sale/Trade 1 01-07-2008 07:38 PM
MACH. 28/NEW PS, KYOSHO MINI INFERNO ST/W/3NEW IB1400 8 CELL PACKS, KYOSHO 1./8 BUGGY newbie2 R/C Items: For Sale/Trade 5 11-18-2007 06:07 PM
Convert Kyosho Quick Start system on Kyosho QRC to Pullstart Morpheus2be Monster Trucks 0 02-16-2005 11:26 PM
