Old 09-05-2006, 08:59 PM   #7936
robert maestrey's Avatar
Originally Posted by maskedrider
wanne to refresh myself and to others as well....
comment of using is gearing setting : 17/61, 23/55.
what will the advantage and disadvantage. example i'm on the Long straight with 2 big sweeper track.
Lastly, different between Hard brake liner and soft liner..
thanks you
depends how long staright is ....the key is to listen to your motor and the power band this will tell you if you need to add gear or not.....also shift point is very important...if your shift point is not correct this could throw you off making you think you have incorrect first gears when it could actually be your shft point.... Clutch must also be very good to have correct feel....hope this helps
robert maestrey is offline   Reply With Quote
Old 09-05-2006, 09:03 PM   #7937
Originally Posted by antoine80
hi all,
it's being a long time since my last post. The summer in Greece is nice and too hot, so i prefered to store my RRR next sunday although is my next race, so i started preparing the last days.
Is anyone running without using overdrive?
i don't have a tyre truer (out of budget now..).
what are the differences in car handling ?
BR
Antony
No I dont.....
Car tends to push a little....
Try to borrow....use the 2mm split car handles much better..Hope this helps
Old 09-06-2006, 03:54 AM   #7938
antoine80's Avatar
Originally Posted by robert maestrey
No I dont.....
i will try to find one to borrow.. anyway i bought the 387T belt, in order to use the 24 pulley and i will see what i am going to do.
thnx again
antoine80 is offline   Reply With Quote
Old 09-06-2006, 07:18 AM   #7939
maskedrider's Avatar
currently i using 16T/60 22T/55 and it works fine to me. have the low and mid power.. so intend to change to 17T and 23T with 61/55 spur to test it out, so afraid that the mid-power will loss out, thats the reason i'm asking you guys comment about it
Kyosho- Sirio/ OS engine- AVID bearing- Blue thunder fuel- Proline- RC dynamite- Sanwa- RC Art
maskedrider is offline   Reply With Quote
Old 09-08-2006, 07:52 PM   #7940
thnx again
Anytime...go Red
Old 09-09-2006, 07:29 AM   #7941
ianhobbies's Avatar
Location: Costa Del Sol, Marbella, Spain www.bradir.net
Send a message via ICQ to ianhobbies
Default 387
387 is recommended on rubber coz of the same equal diam required for the tires, not recommended when using foams
WWW.BRADIR.NET - The Radio Control Motorsport Blog! / twitter @ianhobbies
ianhobbies is offline   Reply With Quote
Old 09-10-2006, 03:36 AM   #7942
antoine80's Avatar
but if you use foam with the same diameter?
Old 09-10-2006, 03:39 AM   #7943
antoine80's Avatar
Anytime...go Red
yesterday i was driving the car with the setup 24 pulley/ 387Belt, the car was smooth for my standards but the rear foam well "melting" after half litre of fuel the rear tires don't have more than 3mm foam i thing these are 38 shore, so i will get 40 the next time.
also i changed the rear springs to the red ones from evolva. the car was very very easy to drive with this change
Old 09-10-2006, 04:01 AM   #7944
antoine80's Avatar
Default clutch nut set
is there a way to adjust the centax nut, without the need to remove the whole bell from the the engine?
Old 09-10-2006, 08:35 AM   #7945
YES!
Easy, stick a small screwdriver through the bell into the adjusting nut slot.
Then turn the flywheel to adjust the nuts position on the shaft.
rcrossco_1 is offline   Reply With Quote
Old 09-10-2006, 03:25 PM   #7946
antoine80's Avatar
Originally Posted by rcrossco_1
YES!
i should stick the screwdriver thourhg the small holes in the bell? there are two small holes one oposite the other.. i will try so, because i unscrewed two times the engine the last time i played in order to adjust the nut
Old 09-11-2006, 08:18 PM   #7947
Send a message via MSN to ickvanovs
my rrr always spin when i try to turn off-throttle
but on throttle, the car tend to understeer
what should i do?
ickvanovs is offline   Reply With Quote
Old 09-11-2006, 08:57 PM   #7948
drfritz's Avatar
what should i do?
Need more info than that.
what you runnung diff wise, drop, toe,tire ect.
drfritz is offline   Reply With Quote
Old 09-11-2006, 09:50 PM   #7949
v one rrr rocks, yesterday was my first day on joining as amateur class, I was late I miss the first heat of qualifiying so I start last position (10) of the race and finish third place , the car was running good, no hitting walls,the car is perfect, wish me luck on my next race at Kyosho on road championship here at Montclair Ca.
vmacrrr
vmacrrr is offline   Reply With Quote
Old 09-12-2006, 01:48 AM   #7950
antoine80's Avatar
what should i do?
for the understeer try to remove a bit droop from the front wheels try very little each time 2 degrees each time or 2 minutes of hour each time.
for me the problems with the back of the car were solved either when i changed the rear absorbers to a more vertical position or changed the shocks to harder ones (the red ones from evolva)
FOR SALE - Mugen MBX5T ProSpec and Kyosho STR with chassis conversion and Kyosho big MattWells R/C Items: For Sale/Trade 5 04-28-2017 10:25 AM
1986 1/12 Kyosho Plazma MKIII With Kyosho LeMan 600E Motor Funkymojo R/C Items: For Sale/Trade 2 05-17-2012 11:11 AM
Custom painted Kyosho SP2 and Kyosho STRR bodies.... RC3 Graphics SWEET W/ PICS CRFXXXT R/C Items: For Sale/Trade 1 01-07-2008 07:38 PM
MACH. 28/NEW PS, KYOSHO MINI INFERNO ST/W/3NEW IB1400 8 CELL PACKS, KYOSHO 1./8 BUGGY newbie2 R/C Items: For Sale/Trade 5 11-18-2007 06:07 PM
Convert Kyosho Quick Start system on Kyosho QRC to Pullstart Morpheus2be Monster Trucks 0 02-16-2005 11:26 PM
