Old 09-03-2006, 05:51 AM   #7921
Originally Posted by 710baby
LOOKS GOOD CAN"T WAIT TO TRY IT BUT IM PLANNING OF STAYING AWEAY FROM THE WALLS
Why are you typing in CAPS ALL THE TIME?
Are you retarded?
rcrossco_1 is offline   Reply With Quote
Old 09-03-2006, 06:30 AM   #7922
v one rrr rocks =)
myk505 is offline   Reply With Quote
Old 09-03-2006, 09:48 AM   #7923
antoine80's Avatar
Default overdrive
hi all,
it's being a long time since my last post. The summer in Greece is nice and too hot, so i prefered to store my RRR next sunday although is my next race, so i started preparing the last days.
Is anyone running without using overdrive?
i don't have a tyre truer (out of budget now..).
what are the differences in car handling ?
BR
Antony
antoine80 is offline   Reply With Quote
Old 09-04-2006, 03:56 AM   #7924
Ec1
Ec1's Avatar
Does anyone know a decent starting setup for the Worlds Track in Brisbane?? Is it a oneway or front Differential Track??
I got a late inventation for the worlds and will not arrive at the trtack until monday morning (last day of practise) ........
Thanks!
Ec1 is offline   Reply With Quote
Old 09-04-2006, 08:00 PM   #7925
GMartinez's Avatar
Trader Rating: 85 (100%+)
Are you retarded?
Rcrosco ask me in person then i can answer & before you make a comment like that you need to research all my post before asking DUMBASS
www.fullthrottlercraceway.com
Home of The U.S. World Nitro Cup 2013,2014,2015,2016
2014 Roar Electric Nationals, IFMAR ISTC Worlds, 2015 Roar Fuel Nationals
2017 U.S.World Nitro Cup Nov 29th - Dec 3rd
U.S.Open Fuel Championship Returning soon
GMartinez is offline   Reply With Quote
Old 09-05-2006, 01:03 AM   #7926
MCRUZ's Avatar
Thumbs up GOOD LUCK
GOOD LUCK TO TEAM KYOSHO AT THE SEDAN WORLDS!!
M32EVOX
MCRUZ is offline   Reply With Quote
Old 09-05-2006, 02:51 AM   #7927
Sp Racer's Avatar
Thanks!
Hey!
I'm an Aussie racing a RRR Evo at the worlds, look me up, I'd be happy to hook you up with whatever set-up we come up with in the week leading up to the event..
Not sure of what everybody has been using up until now, but i'd be surprised if it's not a 1 way...
Luis Sola
10 yrs on RC tech ! wow....
Sp Racer is offline   Reply With Quote
Old 09-05-2006, 03:06 AM   #7928
maskedrider's Avatar
wanne to refresh myself and to others as well....
comment of using is gearing setting : 17/61, 23/55.
what will the advantage and disadvantage. example i'm on the Long straight with 2 big sweeper track.
Lastly, different between Hard brake liner and soft liner..
thanks you
Kyosho- Sirio/ OS engine- AVID bearing- Blue thunder fuel- Proline- RC dynamite- Sanwa- RC Art
maskedrider is offline   Reply With Quote
Old 09-05-2006, 07:09 AM   #7929
Trader Rating: 13 (93%+)
Default rear sway bar question..
hey team
when setting up the rear sway bar..do you adjust it so that both wheels lift at the same time from either side by using the linkages to the arms ?
is this the correct way? should there be any slack in the sway bar when doing this ?
thank you
i hope my question is clear
Serpent 748 TQ | GIMAR Engines
Walter RC HObby | www.walterrchobby.com.au
BlueRC | www.bluerc.net
mrgsr is offline   Reply With Quote
Old 09-05-2006, 08:00 AM   #7930
jag
jag's Avatar
Originally Posted by mrgsr
hey team
That's the way I do it.
I'm not sure if this is the correct way. I have a very small amount of play.
jag is offline   Reply With Quote
Old 09-05-2006, 08:05 AM   #7931
same as Jag...
Old 09-05-2006, 08:10 AM   #7932
jag
jag's Avatar
Originally Posted by fastrcracer
The rear shocks don't seem long enough to allow the rear suspension arms to rest on the droop screws. The arms are not even with the chassis yet. HAs anyone else had this problem ?
Yes, this can be a problem. Use the next longer ball cups on the bottom of the rear shocks and you will be fine.
Where do you measure your droop setting from on this car ?
The bottom of the shock mount area. If you don't already have it, get a copy of the standard WCE setup sheet. It shows exactly where to measure the droop.
The adjustable rear swaybar hits the rear blocks when you lift the car up and doesn't allow the full suspension movement, any help here ?
Just bend the bar slightly to clear the upper arms.
Old 09-05-2006, 08:20 AM   #7933
jag
jag's Avatar
thanks you
How long is the staight? I use a 23t 2nd gear at Kissimmee and that straight is over 200' long. I guess it also depends upon the engine and clutch setup.
Old 09-05-2006, 08:30 AM   #7934
yup...the straight is about there and i on stock set-up for my Sirio.
Old 09-05-2006, 08:55 PM   #7935
robert maestrey's Avatar
hey team
thank you
correct should be no slop......if bothe arms do not lift evenly you have a sway bar tweak......rememebr sway bar should be free enough to not bind up suspension but there should be no slop or play. hope this helps.
robert maestrey is offline   Reply With Quote
FOR SALE - Mugen MBX5T ProSpec and Kyosho STR with chassis conversion and Kyosho big MattWells R/C Items: For Sale/Trade 5 04-28-2017 10:25 AM
1986 1/12 Kyosho Plazma MKIII With Kyosho LeMan 600E Motor Funkymojo R/C Items: For Sale/Trade 2 05-17-2012 11:11 AM
Custom painted Kyosho SP2 and Kyosho STRR bodies.... RC3 Graphics SWEET W/ PICS CRFXXXT R/C Items: For Sale/Trade 1 01-07-2008 07:38 PM
MACH. 28/NEW PS, KYOSHO MINI INFERNO ST/W/3NEW IB1400 8 CELL PACKS, KYOSHO 1./8 BUGGY newbie2 R/C Items: For Sale/Trade 5 11-18-2007 06:07 PM
Convert Kyosho Quick Start system on Kyosho QRC to Pullstart Morpheus2be Monster Trucks 0 02-16-2005 11:26 PM
