Old 08-27-2006, 07:39 AM   #7846
doki_doki's Avatar
Location: Cebu City, Philippines and Ocala, Florida, USA
Default v1rrr evo
here is a picture of the sticker that's on the kyosho v1rrr evo box. hop it is clear enough for you to read
anyways: here's is what is written on the sticker...
*front and rear shocks for 13mm diameter (internal) shocks springs and painted shock springs.
*new designed carbon upper plate to be mounted throttle servo at upright position.
*machined aluminum 21T drive pulley with new brake hub (3mm pin type).
*new main shaft and high durability 1st and 2nd spur gears against impacts.
*double polished brake rotor with soft brake pads (red).
doki_doki is offline   Reply With Quote
Old 08-27-2006, 07:40 AM   #7847
doki_doki's Avatar
here are pictures of the front end of the kit. the servo saver does no come with bearings as with the wce kit. instead bushing were placed
Old 08-27-2006, 07:40 AM   #7848
doki_doki's Avatar
here's a picture of the new soft brake pads included in the kit (it's colored red). i hope i will not experience brake fade much often compared to the wce
Old 08-27-2006, 07:40 AM   #7849
doki_doki's Avatar
here are pictures of the new front and rear shocks for 13mm internal diameter shocks springs and painted blue shock springs. what i noticed is that the upper part of the shock are bigger compared to the wce. only the rear shock tower is carbon fiber with 6 shock positions to choose from. the front is made of hard plastic with only 2 shock positions to choose from.
Old 08-27-2006, 07:41 AM   #7850
doki_doki's Avatar
here's a picture of the new machined aluminum 21T drive pulley with new brake hub (3mm pin type) similar to the design of the v1r, v1rr, v1rr evo models. also noticed the the brake disc is smaller compared to the older v1r series. i placed a small spring in between the 2 brake pads to help the pads disengage faster after using them
Old 08-27-2006, 09:30 AM   #7851
SOLOARTIST 702's Avatar
Send a message via AIM to SOLOARTIST 702
Default hmm
the pictures are just so beautiful are the shocks the same as the wce
RC AMERICA / XRAY / HUDY/ MATRIX TIRES /KOPROPO / ORCAN GT3 /RED CUP RACING MEMBER / SPEEWORLD RACEWAY/ A+ performance parts /IVE SEEN THE XRAY TEAM DRIVE SO I GOT XRAY CARS / better to keep up than to catch up
WILLIAM PENDERGRASS
SOLOARTIST 702 is offline   Reply With Quote
Old 08-27-2006, 02:19 PM   #7852
carkillaii's Avatar
Will the Evo using the Evolva Shocks now might upgrade mine to an Evo
carkillaii is offline   Reply With Quote
Old 08-27-2006, 02:22 PM   #7853
Default hmm
gotcha were you at man get to the track sometimes
WILLIAM PENDERGRASS
Old 08-27-2006, 05:25 PM   #7854
RobertjDrew's Avatar
Send a message via Yahoo to RobertjDrew
What's up? I just wanted to let you guys know that I have a used RRR for sale on eBay. It includes a Rex engine all electronics except receiver and radio. Also spare parts and various foam tires. It's for $385. My seller name on eBay is robshady1. Thanks. Later.
Robert Drew
Novak Electronics - Team Trinity - Upgrade R/C - RCID - Drew Racing
RobertjDrew is offline   Reply With Quote
Old 08-27-2006, 06:58 PM   #7855
Trader Rating: 13 (93%+)
Default hopping car..
hey guys
yesterdays race meet my car was handling awesome in the heats. however in the final with the only change being full size tyres (63rear 61 front) the car was very skippy and handling very loose on the track.
the main problem i saw was that the car was very hoppy in the straight and this track is pretty flat with no bumps.
could shocks /shock oil be the problem here because i did notice the rear shocks leaked quite a bit. i made sure the camber droop and ride height were all the same as the heats as well..
Serpent 748 TQ | GIMAR Engines
Walter RC HObby | www.walterrchobby.com.au
BlueRC | www.bluerc.net
mrgsr is offline   Reply With Quote
Old 08-27-2006, 09:28 PM   #7856
robert maestrey's Avatar
Originally Posted by mrgsr
hey guys
for sure shocks could have been your problem....also check your rear diff joints for any wear this will also cause hoping..hope this helps
robert maestrey is offline   Reply With Quote
Old 08-27-2006, 09:30 PM   #7857
wallyedmonds's Avatar
why dos the new car look like a mugen now ( ok im joking)
wallyedmonds is offline   Reply With Quote
Old 08-27-2006, 10:52 PM   #7858
Default hmm
hey guys
i will second that it has to be the shocks i had the same problem found out there was no shock oil & the car just bounced on springs check it out & report your findings please
WILLIAM PENDERGRASS
Old 08-28-2006, 02:29 AM   #7859
doki_doki's Avatar
the shocks on the evo are totally different from the the wce. the part where the shock caps are placed are bigger compared to the wce shocks. also in the box sticker, it mentioned that the internal diameter is 13mm
Old 08-28-2006, 06:46 AM   #7860
Tim Johnson's Avatar
the shocks that come on the EVO are the same as the Evolva 1/8th car.
_______________________________________________________
Support your Local Hobby Shop, because you can't race on Ebay!
Airtronics|Kyosho|
Tim Johnson is offline   Reply With Quote
FOR SALE - Mugen MBX5T ProSpec and Kyosho STR with chassis conversion and Kyosho big MattWells R/C Items: For Sale/Trade 5 04-28-2017 10:25 AM
1986 1/12 Kyosho Plazma MKIII With Kyosho LeMan 600E Motor Funkymojo R/C Items: For Sale/Trade 2 05-17-2012 11:11 AM
Custom painted Kyosho SP2 and Kyosho STRR bodies.... RC3 Graphics SWEET W/ PICS CRFXXXT R/C Items: For Sale/Trade 1 01-07-2008 07:38 PM
MACH. 28/NEW PS, KYOSHO MINI INFERNO ST/W/3NEW IB1400 8 CELL PACKS, KYOSHO 1./8 BUGGY newbie2 R/C Items: For Sale/Trade 5 11-18-2007 06:07 PM
Convert Kyosho Quick Start system on Kyosho QRC to Pullstart Morpheus2be Monster Trucks 0 02-16-2005 11:26 PM
