Old 08-20-2006, 09:21 PM   #7801
jjmudd's Avatar
Originally Posted by Tim Johnson
Whats up Dom.
Great Job with the Isssssland hobbies plug. I am sure Ron is very happy about that
And John show`n somd K support in Canada!
Hey Guys,
I just wanted to say thanks to Ron at Island Hobbies for working really hard to help me out this weekend at the Canadain Asphalt Invitational and to Tim Johnson at Kyosho USA for really showing what customer service is all about!!!
I'll tell you what boys, for only having the car for two weeks previous to this race and really, only running one day before this weekend, as well as breaking in a new Orion CRF WASP engine on the same day as the first outing with the car, I must say I am extatic with this car. I qualified 6th in the A and finished 2nd...not too bad for a car and engine I had only run once before. I would like to tell you it was all driver but man it's easy to look good when a car and engine do what they are supposed to do!!!
I had to laugh at the CRF engine though. All the guys in the A were running 5 minute pit stops and the CFR was running 7 -8.5 minutes. Top notch for a box stock engine.
Anyhow, thanks again guys for making my weekend of racing very enjoyable!!! Oh yeah, I won the A main in 1/8 nitro too! I'll post some pic.s of the event when I get them.
John Hughes ( aka Johnny T-Bone)
jjmudd is offline   Reply With Quote
Old 08-20-2006, 10:22 PM   #7802
SOLOARTIST 702's Avatar
Send a message via AIM to SOLOARTIST 702
Default race
Originally Posted by jjmudd
Hey Guys,
congrats on your finish glad the car works out for you cant beat that
RC AMERICA / XRAY / HUDY/ MATRIX TIRES /KOPROPO / ORCAN GT3 /RED CUP RACING MEMBER / SPEEWORLD RACEWAY/ A+ performance parts /IVE SEEN THE XRAY TEAM DRIVE SO I GOT XRAY CARS / better to keep up than to catch up
WILLIAM PENDERGRASS
SOLOARTIST 702 is offline   Reply With Quote
Old 08-21-2006, 04:40 AM   #7803
MCRUZ's Avatar
Talking
Hey Guys,
Congrats, awesome job!!! Nice to see RRR's podium. Hey Will, what is it I hear your thinking about switching cars?
M32EVOX
MCRUZ is offline   Reply With Quote
Old 08-21-2006, 04:24 PM   #7804
robert maestrey's Avatar
Hey Guys,
Nice to hear others having sucsess with the RRR...Great job
robert maestrey is offline   Reply With Quote
Old 08-22-2006, 11:14 PM   #7805
jjmudd's Avatar
There are some pic.s up the Canadian Asphalt Invitational webpage, http://www.edmontonrc.com/CAI ,click the results link and then the 2006 results and at the bottom of the page is a link to the pictures. I am the guy in the black t-shirt with the orange and blue cars.
John
Old 08-23-2006, 03:42 AM   #7806
acutts's Avatar
If anyone is interested
http://www.rctech.net/forum/showthread.php?t=126481
acutts is offline   Reply With Quote
Old 08-24-2006, 07:42 AM   #7807
Default Clutch problem
Hi everyone, I need help on building my clutch on my RRR WCE. The clutch shoe binds to the bell everytime I tightened the thrust bearing retaining screw. I know I put the right shims and I checked if all parts are there. I followed the instructions carefully and also followed the build tips on the RRR Knowledgebase. I don't know what I'm doing wrong. Please help, I need my car to be working before Sunday's race at my local track.
Thanks in advance.
leadacid1 is offline   Reply With Quote
Old 08-24-2006, 08:43 AM   #7808
jeff1's Avatar
You should add shims between the clutch nut and the inner bearing until the bell run free
jeff1 is offline   Reply With Quote
Old 08-24-2006, 09:04 AM   #7809
Thanks for the reply Jeff1, I tried that as well. The clutch bell runs free even when I spin it vertically. I used the 5x7 shims (tried different amounts) placed it between the flywheel nut and the inner bearing. But when I finally tightened the screw to hold it all together, the whole clutch system binds. I know I'm doing something wrong but right now im lost.
Old 08-24-2006, 09:16 AM   #7810
fritzD's Avatar
Send a message via Yahoo to fritzD
did you orient the thrush bearing correctly? the thicker side is supposedly inside.
fritzD is offline   Reply With Quote
Old 08-24-2006, 09:24 AM   #7811
Team Kamikaze's Avatar
Thanks in advance.
If you have a spacer between the flywheel and the engine, then you need to take it off ,it should take care of the problem you are having.
Home of the Kamikaze Driver's Development Program = guaranteed podium finish
Kamikaze Toys and Hobbies Inc.
Follow us here on Facebook!
Team Kamikaze is offline   Reply With Quote
Old 08-24-2006, 10:21 AM   #7812
You are correct....you dont need that spacer...but you must make sure you have correct gap setting...once that is done...add shims to eliminate your endplay..you only want about .01 endplay....if your clutch is locking up chances are youve added too many shims....and if you have the spacer before the flywheel that would make it even worse.....hope ths helps
remeber gap is very important .4 to .6 max i wouldnt go any further
Old 08-24-2006, 11:09 AM   #7813
geeunit1014's Avatar
would you guys reccomend the upgrade to ceramic bearings? i need to do some bearing maintenence, and i was wondering if this upgrade is worth it.
Mike Gee
Awesomatix USA/Pyscho Cells Racing/Tekin/Sweep Racing/RSD/180 Raceway/Johns Mobile Raceway/TQ Wire/Avid/Sanwa
geeunit1014 is offline   Reply With Quote
Old 08-24-2006, 11:37 AM   #7814
Fritz D - That's the 1st one I checked, and yes the thicker one is on the engine side.
Team Kamikaze, robert maestrey - Thanks for your replies, yes I do have a spacer behind the flywheel. I'll take that out and check.
Old 08-24-2006, 12:28 PM   #7815
Mike Ellis's Avatar
I'm not sure there is a performance diffence that would give you better lap times. I personally stick with regular bearings and just clean them after each race day. Just my own thoughts
Later, Mike
Mike Ellis is offline   Reply With Quote
FOR SALE - Mugen MBX5T ProSpec and Kyosho STR with chassis conversion and Kyosho big MattWells R/C Items: For Sale/Trade 5 04-28-2017 10:25 AM
1986 1/12 Kyosho Plazma MKIII With Kyosho LeMan 600E Motor Funkymojo R/C Items: For Sale/Trade 2 05-17-2012 11:11 AM
Custom painted Kyosho SP2 and Kyosho STRR bodies.... RC3 Graphics SWEET W/ PICS CRFXXXT R/C Items: For Sale/Trade 1 01-07-2008 07:38 PM
MACH. 28/NEW PS, KYOSHO MINI INFERNO ST/W/3NEW IB1400 8 CELL PACKS, KYOSHO 1./8 BUGGY newbie2 R/C Items: For Sale/Trade 5 11-18-2007 06:07 PM
Convert Kyosho Quick Start system on Kyosho QRC to Pullstart Morpheus2be Monster Trucks 0 02-16-2005 11:26 PM
