Old 08-09-2006, 01:35 PM   #7741
Send a message via AIM to Proteus
Originally Posted by robert maestrey
personally I like the one way...tried the solid in practice at the Glc....but I was much faster with the one-way....im gonna try to run the solid some more to get used to it....but right now for me I feel the one way is faster.
I know what you mean. It took me a some time getting used to it.
Proteus is offline   Reply With Quote
Old 08-09-2006, 01:41 PM   #7742
markp27's Avatar
Send a message via ICQ to markp27
I would first of all change the shock oil to kyosho 500 or 600 - the Assos oils you are running are quite hard oils: 60WT Assos is approx 700 Kyosho; 70WT Assos is almost 1000 Kyosho, which is almost a diff oil.
These heavy oils will cause the transition of the car to slow down when you lift off or go onto the throttle.
Cheers, Mark.
markp27 is offline   Reply With Quote
Old 08-09-2006, 01:54 PM   #7743
robert maestrey's Avatar
Originally Posted by markp27
Nice report, Robert!
I'm off to the European Championship on Sunday - a full week of testing and racing at the superb Heemstede track in Holland.
Really looking forward to it!!
Cheers, Mark.
good luck mark....
Robert...
Guys sorry havent posted setup yet it will be up soon from Glc
robert maestrey is offline   Reply With Quote
Old 08-09-2006, 02:17 PM   #7744
Mike Ellis's Avatar
Nice job at the GLC Robert, sounds like a great event to attend.
I agree with you on the one way, our club races are open enough to lay down some good traction. Some of the other events are really tight and low grip
Later, Mike
Mike Ellis is offline   Reply With Quote
Old 08-10-2006, 02:54 AM   #7745
ziggy12345's Avatar
The grip levels generally experienced at the tracks here in europe prevent us from running one-ways. They work ok, but there is a very small window in which they work well. Also most tracks here are large and normally have a couple of places where you have to break hard.
A solid works well here, but my driving style requires heaps of steering at turn-in, so I always run a diff setup. For the normal grip levels, a front 10k and rear 7k works really well and you end up with a very lively car which turns in extremely well - also powering out of the corners is excellent.
On a high grip circuit here, you can only really run a max of 30k rear diff oil, otherwise the rear end becomes too unstable powering out of corners.
Cheers, Mark.
You are right about the diff oil! I have been trying softer and softer diff oil and the handeling gets better and better.
Dedicated RC Car Speed Site
http://www.fast-rc.co.uk/forum/index.php
Sponsored by:
Norfolk and Chance
ziggy12345 is offline   Reply With Quote
Old 08-10-2006, 12:29 PM   #7746
markp27's Avatar
Ziggy, try softer springs, too - Serpent yellow rears and red fronts work well - they are both softer than the Kyosho silvers. Combine those with a 500 Kyosho oil and you'll have a car which is incredibly easy to drive. You may find you need to go a bit harder with the springs at the front, though.
If you're running at aldershot, I'm sure that setup will work extremely well!
Old 08-10-2006, 12:32 PM   #7747
markp27's Avatar
good luck mark....
Robert...
Thanks Robert - I just hope the weather improves - we've been having a lot of rain and I can't see that it is supposed to change.
Cheers, Mark.
Old 08-10-2006, 01:27 PM   #7748
Hey guys thanks for all the kind words...I really appreciate it
Old 08-10-2006, 02:21 PM   #7749
litespeed-dom's Avatar
Hey Robert, you are probably still working on getting your setup on the sheet. But let me ask iif you tried different bodies throughout the event? What did you end up running? Thanks buddy!
Dom
Team Kyosho America - Team Br00d Racing - Team R/C Plus - GQ Racing Tyres - Slapmaster Tools - FSX Racing
litespeed-dom is offline   Reply With Quote
Old 08-10-2006, 02:24 PM   #7750
Here's the setup I ran at the GLC
F:
Shock oil: 600 wt
Diaphragm: Stock
Shock piston: 1 hole
Spring: front black
Shock position: 1.5
castor angle: 10.5 deg
camber angle: 2
toe angle: 1 deg out
front width: 199
droop-downstop- 0
Roll bar: soft
Tire: jaco 42 at 57.5mm
Ride height: 4
Knuckle arm: 0 deg
servo saver: 11
rollcenter upper arm position- stock
one way
Rear:
Shock oil: 600 wt
Diaphragm: stock
Shock piston: 2 hole
Shock spring: gold
shock position: 2
upper arm height: 2mm shim
camber angle: 3.5
toe angle: 1.5 deg
rear width: 200mm
downstop (droop): 3
antiroll bar: 2.0
Tire: Jaco 50 at 59.5 mm
wheel offset: 0
ride height: 5
roll center lower arm position: stock
Rear diff : 100,000 wt
Gearing: 16/23 61/55
Clutch shoe: grey
spring: standard
clearance: .4
Adj nut:1.2
Body: protoform stratus 3.1
Engine:Sirio Evo3 Sti
7 sirio plug
25%Tornado
Car was very good, had a slight mid corner push
Enjoy
Robert Maestrey
Old 08-10-2006, 02:26 PM   #7751
Dom
Dude you must be a mind reader...check out the time when you posted asking your question and when my sheet went on .... spooky....Dom
Didnt try anything but the stratus...was having problems..so the body wasnt a main concern....
Robert Maestrey
Old 08-10-2006, 02:34 PM   #7752
Robert Maestrey
That is freaky!
Thanks Robert! We've been running at least 40k rear diff oil up here, might give 30k a try this weekend. Seems like guys are running lower weight oil to calm the rear end down a bit, but honestly with 50k I wasn't really having a big problem with the rear end. My rear end has been planted with 50k oil on mid and high traction traction. It does come around a bit on low bite track though.
As far as bodies go... I've tried 3.1 and M-type with limited time and been going back to the Mazda on each occasion. The Mazda has been good to me and I figure why mess with what's working.
Dom
Old 08-10-2006, 02:55 PM   #7753
That is freaky!
Dom
I've tried the 3.1 and the Kawahara lexus. The lexus definately makes my car come around and just feels more responsive. The 3.1 felt too planted. I painted up a M-type but didn't get a chance to mount it. I would like to try the Mazda though.
Old 08-10-2006, 02:56 PM   #7754
That is freaky!
Dom
At the glc I used 100,000
Old 08-11-2006, 12:48 AM   #7755
Hi,
would you put the setup of the clutch that you use?
does somebody know the hardness of the new docks of the evo regarding the normal?
thank you
TMG4EVOII is offline   Reply With Quote
FOR SALE - Mugen MBX5T ProSpec and Kyosho STR with chassis conversion and Kyosho big MattWells R/C Items: For Sale/Trade 5 04-28-2017 10:25 AM
1986 1/12 Kyosho Plazma MKIII With Kyosho LeMan 600E Motor Funkymojo R/C Items: For Sale/Trade 2 05-17-2012 11:11 AM
Custom painted Kyosho SP2 and Kyosho STRR bodies.... RC3 Graphics SWEET W/ PICS CRFXXXT R/C Items: For Sale/Trade 1 01-07-2008 07:38 PM
MACH. 28/NEW PS, KYOSHO MINI INFERNO ST/W/3NEW IB1400 8 CELL PACKS, KYOSHO 1./8 BUGGY newbie2 R/C Items: For Sale/Trade 5 11-18-2007 06:07 PM
Convert Kyosho Quick Start system on Kyosho QRC to Pullstart Morpheus2be Monster Trucks 0 02-16-2005 11:26 PM
