Old 08-03-2006, 12:29 AM   #7696
Dynamite's Avatar
Send a message via MSN to Dynamite
Originally Posted by Toinou
Hello,
Witch " basic " setup can you used to drived on rubber tyres with the RRR ??
Thank you for your answers.
Toinou
you have all the parts in your kit, exept for the correct middle belt. swap the 23t up front of the middle belt for the 24t that came in the kit, and get the optional side belt for use with the 24t pully, part number is listed in your manual.
i have never raced with rubber tires on my rrr but i have done practice with them just using the car drivetrain setup for foam tires without a problem - all the 24t pulley and belt do is bring the car close back to 50/50 drive.
www.racingfactory.org
Kyosho RRR Evo | Sirio Evo III STI | Ko Radio
Dynamite is offline   Reply With Quote
Old 08-03-2006, 05:06 AM   #7697
Trader Rating: 47 (100%+)
Originally Posted by elchoclo
Does anybody have problems with the shock absorbers, for some reason the ones on my RRR leak a lot, have tried everything, changing the diaphragms for new ones didn't help, I even tried using teflon tape to get a better seal with minor improvements, basically after a couple of runs they start to leak from the top, any tips to fix this problem? I know i'm not the only one because in my local club there are 10 more drivers with the same car - same problem.
Any suggestion will be appreciated!
Yeah I started to have a lot of problems.
I use Tamiya TRF shock diaphrams now though.
They are a little larger in diameter, so they don't seem to fall into the shock and cause it to leak.
The smaller diameter 1/8th shocks seem to build better also, but the cap is still the same.
TOP GEAR R/C
EAST COAST HOBBIES
Craig1 is offline   Reply With Quote
Old 08-03-2006, 07:56 AM   #7698
ianhobbies's Avatar
Location: Costa Del Sol, Marbella, Spain www.bradir.net
Send a message via ICQ to ianhobbies
Default shocks
check out GSRACING's "shocks rebuild kit"
WWW.BRADIR.NET - The Radio Control Motorsport Blog! / twitter @ianhobbies
ianhobbies is offline   Reply With Quote
Old 08-03-2006, 09:10 AM   #7699
Toinou's Avatar
Send a message via MSN to Toinou
Thank you
Toinou is offline   Reply With Quote
Old 08-03-2006, 09:19 AM   #7700
SOLOARTIST 702's Avatar
Send a message via AIM to SOLOARTIST 702
Default hmm
ive had major problems i just kept changing diaphragm's and finally they got better but would suggest replacing those shocks with what brand i cant say im still looking
RC AMERICA / XRAY / HUDY/ MATRIX TIRES /KOPROPO / ORCAN GT3 /RED CUP RACING MEMBER / SPEEWORLD RACEWAY/ A+ performance parts /IVE SEEN THE XRAY TEAM DRIVE SO I GOT XRAY CARS / better to keep up than to catch up
WILLIAM PENDERGRASS
SOLOARTIST 702 is offline   Reply With Quote
Old 08-03-2006, 11:38 AM   #7701
I will try all the tips (I'm really sick about changing the shock oil every day) I'll let you know wich one worked better!
elchoclo is offline   Reply With Quote
Old 08-03-2006, 03:39 PM   #7702
el salvador's Avatar
dom are you caming to fantasy worlds summer sizzler
ARC R8 X2/ Max RP9 or O.S. R2101 ,Capricorn LAB C02-TOP Elite R, ARC R11....
"Every Cemetery in Chicago Votes Democrat!"
el salvador is offline   Reply With Quote
Old 08-03-2006, 04:07 PM   #7703
what is so different about the v-one rrr wce that make it a beter car to drive
Old 08-03-2006, 04:32 PM   #7704
litespeed-dom's Avatar
Yes, I'll be at that race.
Dom
Team Kyosho America - Team Br00d Racing - Team R/C Plus - GQ Racing Tyres - Slapmaster Tools - FSX Racing
litespeed-dom is offline   Reply With Quote
Old 08-03-2006, 05:28 PM   #7705
geeunit1014's Avatar
does anyone have a setup for the rrr that wont wear out the rear tires so fast? my car is dailed, but i cant stand going through 2-3 pairs of rears for every pair of fronts
Mike Gee
Awesomatix USA/Pyscho Cells Racing/Tekin/Sweep Racing/RSD/180 Raceway/Johns Mobile Raceway/TQ Wire/Avid/Sanwa
geeunit1014 is offline   Reply With Quote
Old 08-03-2006, 07:01 PM   #7706
Trader Rating: 24 (100%+)
did you try a harder shore rear tire with a softer spring.
RANDY SMOOTH is offline   Reply With Quote
Old 08-04-2006, 03:19 AM   #7707
KyoshoKid's Avatar
kewdawg:
I found out why my 2 speed changer was rubbing (getting stuck) on the spur gear. The set screw was pushing the collar too far out so the 2 pads werent close enough together. If I screwed out the set screws the spur gear wouldnt even go on (keeping them just under the surface)
I had a look at a RR and FW-05R and noticed they dont have a set screw at all in the 2 speed changer, so I took them out and now the gear turns freely!! I doubt this will make a huge difference??
Also, Im concerened about the front one way pully. I used Arolldite to glue it but wouldnt this come apart from racing wear and tear? I had an issue with an aluminium pully on my V One S, the side came off after 1 day of racing as the belt was rubbing against it one one side. Has anyone had trouble with it?
KyoshoKid is offline   Reply With Quote
Old 08-04-2006, 10:28 AM   #7708
ziggy12345's Avatar
Soften the shock oil and / or the springs and soften the diff oil. It looks ,ike your tyres are skipping under power and spinning on the tarmac so wearing them quickly
Cheers
PS... Thats EVO1's Avatar!!!!
Dedicated RC Car Speed Site
http://www.fast-rc.co.uk/forum/index.php
Sponsored by:
Norfolk and Chance
ziggy12345 is offline   Reply With Quote
Old 08-04-2006, 05:44 PM   #7709
i dont think the tires are spinning just wearing fast compared to the front tires that dont have to do any braking. right now im running the kit shock oil(50wt i believe), and 10k rear oil. i dont want to go up on the rear shore to0 much, as the track is not ultra high bite, and very tight, and i dont have any other kyosho springs. right now i have 37's all around.
if i remember right, i took this av. from someone on another forum that i dont frequent, if someone else on here has this pic, its purley coinsidence!
Mike Gee
Old 08-05-2006, 11:56 PM   #7710
Send a message via MSN to ickvanovs
is there any special method to remove pinion?
ickvanovs is offline   Reply With Quote
FOR SALE - Mugen MBX5T ProSpec and Kyosho STR with chassis conversion and Kyosho big MattWells R/C Items: For Sale/Trade 5 04-28-2017 10:25 AM
1986 1/12 Kyosho Plazma MKIII With Kyosho LeMan 600E Motor Funkymojo R/C Items: For Sale/Trade 2 05-17-2012 11:11 AM
Custom painted Kyosho SP2 and Kyosho STRR bodies.... RC3 Graphics SWEET W/ PICS CRFXXXT R/C Items: For Sale/Trade 1 01-07-2008 07:38 PM
MACH. 28/NEW PS, KYOSHO MINI INFERNO ST/W/3NEW IB1400 8 CELL PACKS, KYOSHO 1./8 BUGGY newbie2 R/C Items: For Sale/Trade 5 11-18-2007 06:07 PM
Convert Kyosho Quick Start system on Kyosho QRC to Pullstart Morpheus2be Monster Trucks 0 02-16-2005 11:26 PM
Currently Active Users Viewing This Thread: 9 (0 members and 9 guests)
