Old 07-25-2006, 03:57 AM   #7651
litespeed-dom's Avatar
Originally Posted by KOLORS
guys, which lightweight first gear housing should i get for my wc...VZW064 (kyosho parts list) or TSW15 (wc manual)?
VZW064
Dom
Team Kyosho America - Team Br00d Racing - Team R/C Plus - GQ Racing Tyres - Slapmaster Tools - FSX Racing
litespeed-dom is offline   Reply With Quote
Old 07-25-2006, 04:00 AM   #7652
For those interested in checking out the new RRR EVO manual, exploded view, parts list....
http://www.kyosho.co.jp/web/download...e_index-e.html
Dom
Old 07-25-2006, 05:15 AM   #7653
ianhobbies's Avatar
Location: Costa Del Sol, Marbella, Spain www.bradir.net
Send a message via ICQ to ianhobbies
Default rrr evo
Originally Posted by doki_doki
fortress hobbies already has them in stock are you switching to the rrr evo?
yes i saw the pics on our local thread, it's easy to convert my standard rrr to evo specs, but i still want to use the laydown throttle servo configuration..
WWW.BRADIR.NET - The Radio Control Motorsport Blog! / twitter @ianhobbies
ianhobbies is offline   Reply With Quote
Old 07-25-2006, 02:39 PM   #7654
jjmudd's Avatar
Am I correct at guessing Kyosho shock oil weights transfer this way...
K600wt = 60wt Losi/Associated
K500wt = 50wt Losi/Associated
etc...etc...???
jjmudd is offline   Reply With Quote
Old 07-25-2006, 04:40 PM   #7655
jeff1's Avatar
Originally Posted by jeff1
Hello
guys,
I had some problems with brake last race (about 30min). He was very good from the start, excellent efficiency but in 15 min I had to started brake before, where I used 2m I had used 4m. I don't know exactly what happened I noticed that brake arm became less responsive, I needed more servo course to active it
I'm using 3racing brake disc, and original pads.. any suggestion?
thanks a lot
Can somebody help me?
jeff1 is offline   Reply With Quote
Old 07-25-2006, 04:47 PM   #7656
i am also using 3racing disk brake with original brake pads. i notice defficiency in braking after a couple of tanks of fuel also. i dont know if the break still needs to be broken in, this may be the problem.
krnfx is offline   Reply With Quote
Old 07-25-2006, 07:07 PM   #7657
Send a message via AIM to Proteus
Just in case you all are wondering what the new spring rates are (for RRR Evo), here they are. The first number is grams and the next number is lbs.
Front: Light Blue: 468 / 26.15
Blue: 584 / 32.62
Dark Blue: 719 / 40.17
Rear: Light Blue: 468 / 26.15
Blue: 525 / 29.33
Dark Blue: 588 / 32.85
So basically with the new kit, they went approx 5lbs stiffer in the rear and approx 2lbs softer in the front (based on kit setups). Interesting.
Proteus is offline   Reply With Quote
Old 07-25-2006, 08:08 PM   #7658
jjmudd's Avatar
etc...etc...???
Anyone??
Old 07-25-2006, 08:47 PM   #7659
Hi, unfortunately I do not use hopup brake disc. I haven't had any problem with brake fade using stock setup during longer mains.
Dom
Old 07-25-2006, 08:49 PM   #7660
Anyone??
John, I can't say they are equivalent. Even with the same 60wt oil, Losi and AE are different. I personally use AE oil and been using 60 and 50wt.
Dom
Old 07-25-2006, 08:50 PM   #7661
Blue: 584 / 32.62
Blue: 525 / 29.33
Also another thing to keep in mind. New rates also being used with smaller diameter yet longer shock bodies.
Dom
Old 07-25-2006, 09:13 PM   #7662
jjmudd's Avatar
Thanks Dom
Old 07-25-2006, 09:50 PM   #7663
JP116's Avatar
Default ...
I am looking for some advice here..After reading a bit i thought i should make my first post...
I am running a front spool on my v-one-rrr and am wondering what the effects lighter or heavier diff oil in the rear will have on the way the cars feels entering in and out of the turns. I am running 45w shock oil front and rear with stock black and gold springs. I am running 0 degree camber and toe in the front with about -2degree toe in the rear with 0 degree camber. I like to brake right before i enter the turn so i cut it very tight then power out of the turn.. Any tips on how i could better the car set-up would be appreciated.. Thanks
JP116 is offline   Reply With Quote
Old 07-25-2006, 09:56 PM   #7664
KOLORS's Avatar
Originally Posted by litespeed-dom
VZW064
Dom
thanks dom
KOLORS is offline   Reply With Quote
Old 07-26-2006, 11:46 AM   #7665
Mike Ellis's Avatar
The heavier the rear diff lube, the more the rear end will drift out and add front steering. You may want to go to the Kyosho site and print off the setups that have been supplied. The setup from me is for a low traction track, even though I ran the oneway, the setup would still be similar. What type traction do have at the track your running?
Hope this helps, Mike
Mike Ellis is offline   Reply With Quote
FOR SALE - Mugen MBX5T ProSpec and Kyosho STR with chassis conversion and Kyosho big MattWells R/C Items: For Sale/Trade 5 04-28-2017 10:25 AM
1986 1/12 Kyosho Plazma MKIII With Kyosho LeMan 600E Motor Funkymojo R/C Items: For Sale/Trade 2 05-17-2012 11:11 AM
Custom painted Kyosho SP2 and Kyosho STRR bodies.... RC3 Graphics SWEET W/ PICS CRFXXXT R/C Items: For Sale/Trade 1 01-07-2008 07:38 PM
MACH. 28/NEW PS, KYOSHO MINI INFERNO ST/W/3NEW IB1400 8 CELL PACKS, KYOSHO 1./8 BUGGY newbie2 R/C Items: For Sale/Trade 5 11-18-2007 06:07 PM
Convert Kyosho Quick Start system on Kyosho QRC to Pullstart Morpheus2be Monster Trucks 0 02-16-2005 11:26 PM
