Old 07-23-2006, 11:40 AM   #7621
drfritz's Avatar
are you running the stock v one rr up rights ? if so you need to run 2deg off set rims to clear the up rights, if you are running the v one rrr ones you will need to get the vzw007 and run zero off set rims, or the stock wc ones(not sure on the part # and two deg off set rims.
another thing you can do and it is alot cheapr, get the 3r racing alum hex adapters in the 2 deg off set, with thses you ca run the stock axiles with the old style hubs and zero off set rims.
drfritz is offline   Reply With Quote
Old 07-23-2006, 01:17 PM   #7622
well, i have 3racing rear universals. 2mm offset i believe.
i noticed theres was a spacer on each dogbone. so i placed the spacer in between the outter bearing and the pin/wheel hex. Is this not a good idea?
or can i use this as a permanent fix.
krnfx is offline   Reply With Quote
Old 07-23-2006, 02:55 PM   #7623
drfritz's Avatar
If it works go for it. you might want to go back and surf the old v one rr thread and see what was done before.
Old 07-23-2006, 07:46 PM   #7624
performula's Avatar
Did anyone come up with a method to take the pinion gears off the light weight clutchbell without bending it? I know it was an issue before.
performula is offline   Reply With Quote
Old 07-23-2006, 08:13 PM   #7625
doki_doki's Avatar
Location: Cebu City, Philippines and Ocala, Florida, USA
can anyone make a list of the difference between the v1rrr wce and the v1rrr evo? like the following: does the v1rrr evo come with 1 piece engine mount? universals? aluminum pipe holder? lightened 1st gear bearing, etc??? thanks
doki_doki is offline   Reply With Quote
Old 07-23-2006, 08:33 PM   #7626
performula's Avatar
http://www.nitrokb.com/vonerrr/index.html
The answer is no to all of your questions.
Old 07-23-2006, 10:31 PM   #7627
Motorman's Avatar
Ok Kyosho guru's I need a question answered. PN VZ115-23 is a first gear pinion for the RR and FW05. Will it fit Second gear on the RRR bell which I believe is has the same diameter threads on second as the RR and FW05 had on first.
Just here to give the world grief.
Motorman is offline   Reply With Quote
Old 07-23-2006, 10:35 PM   #7628
performula's Avatar
Yes, because I ordered one for the RRR. You can also see it here - page 11:
http://www.kyosho.co.jp/web/products...r_060322-e.pdf
*and I have the part in hand. VZW066-23 (for RRR&FW05)
Old 07-23-2006, 10:42 PM   #7629
Motorman's Avatar
so you are saying that gear will actually fit second on the rrr
Old 07-23-2006, 10:49 PM   #7630
performula's Avatar
I'm sorry. I mis-interpreted your Q. It is a 1st gear for the RRR too.
Did you change the part number question? I could have sworn you put VZW066-23. I still answered the question wrong though.
Old 07-23-2006, 10:55 PM   #7631
buboy28's Avatar
Send a message via AIM to buboy28 Send a message via Yahoo to buboy28
HI DOKI, I THINK THAT IT WILL BE THE WCE VERSION OF THE RRR-EVO THAT YOU ARE DESCRIBING ( IF KYOSHO WILL COME UP ONE ) , I'M STILL THINGKING IF I GOING TO GET ONE NOW BUT I MIGHT WAIT TILL AFTER THE IFMAR WORLDS
buboy28 is offline   Reply With Quote
Old 07-23-2006, 11:07 PM   #7632
Motorman's Avatar
yes I did change the number the only difference between them is one is steel and the other is alumunium. I was told those gears would fit second on the RRR clutch bell even though they say first. Is the hole in them small like a regular 16 type pinion for the RRR or is it big like second?
could you measure the inside of the hole and tell me what it is?? On the one you have
Old 07-23-2006, 11:41 PM   #7633
VZ115-23 or the steel version is the 2nd pinon gear for RRR. This same gear is used on the FW-05R/RR as the 1st pinon gear.
cvccsi is offline   Reply With Quote
Old 07-23-2006, 11:47 PM   #7634
Motorman's Avatar
Thanks thats what I needed to know. I appreciate it.
Old 07-23-2006, 11:56 PM   #7635
No Problem...
FOR SALE - Mugen MBX5T ProSpec and Kyosho STR with chassis conversion and Kyosho big MattWells R/C Items: For Sale/Trade 5 04-28-2017 10:25 AM
1986 1/12 Kyosho Plazma MKIII With Kyosho LeMan 600E Motor Funkymojo R/C Items: For Sale/Trade 2 05-17-2012 11:11 AM
Custom painted Kyosho SP2 and Kyosho STRR bodies.... RC3 Graphics SWEET W/ PICS CRFXXXT R/C Items: For Sale/Trade 1 01-07-2008 07:38 PM
MACH. 28/NEW PS, KYOSHO MINI INFERNO ST/W/3NEW IB1400 8 CELL PACKS, KYOSHO 1./8 BUGGY newbie2 R/C Items: For Sale/Trade 5 11-18-2007 06:07 PM
Convert Kyosho Quick Start system on Kyosho QRC to Pullstart Morpheus2be Monster Trucks 0 02-16-2005 11:26 PM
