Old 07-18-2006, 04:38 AM   #7546
ianhobbies's Avatar
Location: Costa Del Sol, Marbella, Spain www.bradir.net
Send a message via ICQ to ianhobbies
Default RRR hubs
Originally Posted by kidDynomite
The fronts too. Rear end felt more planted and the car seemed to have more steering.
i tried this on my RR and it works fine. go for it! but i haven't tried putting .8 module spurs and pinions.. anyone ?
WWW.BRADIR.NET - The Radio Control Motorsport Blog! / twitter @ianhobbies
ianhobbies is offline   Reply With Quote
Old 07-18-2006, 04:59 AM   #7547
etgdpu's Avatar
Default rear camber
Hello all,
I have a small problem with my rear camber and I would appreciate some ideas. I have concluded to the following setup for my local track.
Front
height: 5.5mm
width: 196mm
shock oil: 600
springs: Kyosho Green (from the V1S series)
tires: 37 GRP
camber: 2
toe: 0
caster: arms all the way to the rear and all the spacers to the front
upper pin bases: default position
one way
servo saver: 12
rear
height: 6.0mm
width: 198mm
shock oil: 400
springs: Kyosho RED 1.7 (from the Fantom/Evolva)
tires: 40 GRP (0 offset, using the 2mm spacers)
camber: 3.5 or even more (here is my problem)
toe: +2.5 or 3
lower pin bases: type B and the hole towards the ground (second position from the groung)
upper camber links: default position and default (2mm) spacer
differential: 30000 with 4 gears
My problem is that the cone of the rear tires is not always right and shows that a little more camber is required. However, I am already to 3.5 - 4 and if I give more then the ball cups of the rear camber links get stuck on the balls and the rear arms do not move free. Anyway, it sounds a little extreme that I need more than 4 rear camber.
Also I would like to mention that my rear tires wear faster than the front and I already use harder rears.
Any comment or idea is very much appreciated.
The intelligent can become anyone, anyone can not become intelligent.
etgdpu is offline   Reply With Quote
Old 07-18-2006, 06:51 AM   #7548
fritzD's Avatar
Send a message via Yahoo to fritzD
pre, The V-one RR evo has 0.8M spurs and pinions. The same spurs with RRR. The internal drive ratio of RR and RR evo is 2.5 so the 1st and 2nd gear pinions are 20+ teeth and 24+ teeth, respectively.
fritzD is offline   Reply With Quote
Old 07-18-2006, 10:47 AM   #7549
bah. The guy from the hobby shop already special ordered the VoneRR rear hubs=/ even though he has the VoneRRR rear hubs in stock ><
I guess im stuck waiting for the regular RR hubs ><
krnfx is offline   Reply With Quote
Old 07-18-2006, 02:55 PM   #7550
dougday's Avatar
Originally Posted by etgdpu
Hello all,
Front
height: 5.5mm
width: 196mm
shock oil: 600
tires: 37 GRP
camber: 2
toe: 0
one way
servo saver: 12
rear
height: 6.0mm
width: 198mm
shock oil: 400
toe: +2.5 or 3
Your car is a bit narrow. Try 198 front and 200 rear. The additional space on the rear will help you getting 4 deg camber on the left and 3.5 on the right. (that is if your are running clockwise at your track)
dougday is offline   Reply With Quote
Old 07-19-2006, 02:28 AM   #7551
ziggy12345's Avatar
Hello all,
Front
height: 5.5mm
width: 196mm
shock oil: 600
tires: 37 GRP
camber: 2
toe: 0
one way
servo saver: 12
rear
height: 6.0mm
width: 198mm
shock oil: 400
toe: +2.5 or 3
Too much droop. Take it all out
Dedicated RC Car Speed Site
http://www.fast-rc.co.uk/forum/index.php
Sponsored by:
Norfolk and Chance
ziggy12345 is offline   Reply With Quote
Old 07-19-2006, 04:10 AM   #7552
I want to buy V-One RRR spur.Fwo5 R or RR's spur is fit to V One RRR Spur?
2nd Spur
http://www.korearcmall.co.kr/shop/sh...e=055004000083
Thanks.
amorfy_onur(tr) is offline   Reply With Quote
Old 07-19-2006, 06:14 AM   #7553
Dynamite's Avatar
Send a message via MSN to Dynamite
hey etgdpu,
what rear inner camber link position are you using? try running the outer (highest one) if your not already, also try raising the link on the hub by placing additional spacers in there that should help with quicker camber change on the track.
also, what downstop settings and tire diameters are you running? vbmenu_register("postmenu_2512851", true);
www.racingfactory.org
Kyosho RRR Evo | Sirio Evo III STI | Ko Radio
Dynamite is offline   Reply With Quote
Old 07-19-2006, 06:16 AM   #7554
Dynamite's Avatar
2nd Spur
Thanks.
that spur is for RRR
Old 07-19-2006, 08:54 AM   #7555
maskedrider's Avatar
Does it nesserary to spray those WD40 or Oil Lubricate on the Bearing after or during interval on each race ? I found some does and some Don't ??
Kyosho- Sirio/ OS engine- AVID bearing- Blue thunder fuel- Proline- RC dynamite- Sanwa- RC Art
maskedrider is offline   Reply With Quote
Old 07-19-2006, 09:25 AM   #7556
performula's Avatar
Hello all,
Front
height: 5.5mm
width: 196mm
shock oil: 600
tires: 37 GRP
camber: 2
toe: 0
one way
servo saver: 12
rear
height: 6.0mm
width: 198mm
shock oil: 400
toe: +2.5 or 3
Yeah, I'm having the same issue. Car is planted, but the tires are coning from the outside - in, not like the recommended inside - out (negative camber tire wear look).
Left rear:
Left rear:
Right rear, close but still a slight cone:
performula is offline   Reply With Quote
Old 07-19-2006, 09:34 AM   #7557
Old 07-19-2006, 09:49 AM   #7558
tommi's Avatar
Hey there, baby is born? She/he looks very healthy and great! (It is a girl?) Congrats!!
It is recommended to do lubing/cleaning maintenance to the bearings, and it depends on how much time you have and how hardworking you are, if you're talking about interval during a race that is. The only bearings I lube during a race are the clutch bearings and the thrust bearing. The others I do it once every 2 months...
tommi is offline   Reply With Quote
Old 07-19-2006, 10:59 AM   #7559
Mike Ellis's Avatar
For those who are having the problem of rear tire coning from outside /in the suspention down travel should be checked. I noticed on the set up posted that down travel is not mentioned. The RRR seems to work best with 2-3 mm down travel from ride height. The traction at most of our tracks is low/medium. Rear tow is 2-3 degrees in and camber is 2-3 degrees neg. With 2-3 mm droop (down travel ) the tires wear flat or slightly coned from inside to out. The shock length needs to be checked to be sure of proper droop. Remember the droop needs to be checked every time you have to run the collars up or down. I do not use setup blocks at all. I set the ride height and lift the car up and lower it until the wheels touch and remeasure. Also sometimes it's hard to stop the reverse coning if you have long fast corners in the same direction. In that case you could end up with different camber setting left to right anyway.
Hope this helps, Mike
Mike Ellis is offline   Reply With Quote
Old 07-19-2006, 02:31 PM   #7560
Tim Johnson's Avatar
Kyosho America has just received these new parts:
VZW204 Rear Adjustable Stabilizer Set(RRR/RRR E
VZW204-01 Rear Adjustable Stabilizer Bar(RRR/RRR E
VZW219 Universal Swing Shaft Set(RRR/RRR Evo/2P
_______________________________________________________
Support your Local Hobby Shop, because you can't race on Ebay!
Airtronics|Kyosho|
Tim Johnson is offline   Reply With Quote
FOR SALE - Mugen MBX5T ProSpec and Kyosho STR with chassis conversion and Kyosho big MattWells R/C Items: For Sale/Trade 5 04-28-2017 10:25 AM
1986 1/12 Kyosho Plazma MKIII With Kyosho LeMan 600E Motor Funkymojo R/C Items: For Sale/Trade 2 05-17-2012 11:11 AM
Custom painted Kyosho SP2 and Kyosho STRR bodies.... RC3 Graphics SWEET W/ PICS CRFXXXT R/C Items: For Sale/Trade 1 01-07-2008 07:38 PM
MACH. 28/NEW PS, KYOSHO MINI INFERNO ST/W/3NEW IB1400 8 CELL PACKS, KYOSHO 1./8 BUGGY newbie2 R/C Items: For Sale/Trade 5 11-18-2007 06:07 PM
Convert Kyosho Quick Start system on Kyosho QRC to Pullstart Morpheus2be Monster Trucks 0 02-16-2005 11:26 PM
