Old 07-15-2006, 06:47 AM   #7516
kewdawg's Avatar
Originally Posted by moot
blown off track.no compound.
using silver springs all round.
40wt shock oil all round
10000 in the front diff,
5000 in the rear.
1.5 front camber
2 rear camber
2 front toe
2.5 rear toe
drop 0 front 5mm rear
flat front sway bar
and rear one pulled in 2mm
using 35 shore tires all round.
If, the inner roll-centers (at the hinge pins) are in the stock positions:
-Change the front diff lube to 30,000.
-Change the front shock oil to 60wt. and spring to black.
-Change the front camber to 1 degrees.
-Change the rear toe to 3 degrees and camber to 3 degrees.
-Change the rear droop to 2 mm (on the gauge) - you have too much weight transferring to the front. This will cause the rear end to come around, too fast in low traction situations.
-Change the rear bar joint position to flush on the sway bar.
-Lengthen the rear upper links(use the inner position) and remove the 2 mm blue spacers.
With these changes, the car should be a lot more planted and easier to drive.
Quinn Moon
Trinity / Epic / Revtech / VBC Racing USA / Mugen Seiki / Hot Race Tyres / SkyRocket Racing / SUPAFAST RC
kewdawg is offline   Reply With Quote
Old 07-15-2006, 11:21 AM   #7517
franknitty69's Avatar
Send a message via AIM to franknitty69 Send a message via Yahoo to franknitty69
Default wce conversion kit
hello,
who is selling the wce conversion kit? what's the price?
thanks,
ahmed
franknitty69 is offline   Reply With Quote
Old 07-15-2006, 03:26 PM   #7518
SOLOARTIST 702's Avatar
Send a message via AIM to SOLOARTIST 702
Default 2nd
Originally Posted by franknitty69
hello,
thanks,
ahmed
likewise
RC AMERICA / XRAY / HUDY/ MATRIX TIRES /KOPROPO / ORCAN GT3 /RED CUP RACING MEMBER / SPEEWORLD RACEWAY/ A+ performance parts /IVE SEEN THE XRAY TEAM DRIVE SO I GOT XRAY CARS / better to keep up than to catch up
WILLIAM PENDERGRASS
SOLOARTIST 702 is offline   Reply With Quote
Old 07-15-2006, 03:30 PM   #7519
Default hot
100 & what ever degrees here in the lv 702 forgetaboutit
WILLIAM PENDERGRASS
Old 07-16-2006, 09:11 PM   #7520
nitrodude's Avatar
Thunking about getting one of these. Is it worth getting the EVO over the original? I have a good deal on a original with some hopups and parts. Thanks, let me know
Steven Muller
AKA El Pibe RUFAST? HAHA!!!
Ronin Speed Parts
nitrodude is offline   Reply With Quote
Old 07-16-2006, 09:20 PM   #7521
litespeed-dom's Avatar
Do you mean getting an EVO over the origianl RRR, not the WCE? The RRR WCE is a very capable car still. If you are deciding to between an EVO and the regular RRR kit, then I say go with the EVO.
If you have a good deal on the WCE with parts, I wouldn't hesitate it.
Dom
Team Kyosho America - Team Br00d Racing - Team R/C Plus - GQ Racing Tyres - Slapmaster Tools - FSX Racing
litespeed-dom is offline   Reply With Quote
Old 07-16-2006, 09:26 PM   #7522
nitrodude's Avatar
I have a deal on non-wce with a bunch of parts and bunch of Kawahara 3Racing and K factory hop ups for $325. I like the fact that ot comes with a bunch of spares.
ALso whats new on the EVO?
Steven Muller
Ronin Speed Parts
Old 07-16-2006, 11:01 PM   #7523
The main noticeable is the top deck, the necessary hardware to do the standup throttle servo...
Rear bulkheads, layshaft, brake disc, brake pulley, brake shaft, center bulkhead, rear shock bodies, diaphrams, new springs (rates) set, belt tensioner.... that's all I could think of at the moment. I'm sure I missed a some other things.
Dom
Old 07-16-2006, 11:02 PM   #7524
Dom
Oh, forgot 1 important thing.... new harder materials spur gears!
Dom
Old 07-16-2006, 11:04 PM   #7525
jjmudd's Avatar
Drove the new RRR-WC today. I put the car on the track as I got it from the guy I purchased it from. Now I didn't have a decent body on the car and the car was set up with the front oneway, heavy black springs up front and golds out back. Looking at the back of the car, the rear arms do not even hang to parallel with the ground (they are slanted up). Even with the down stops removed the arms didn't even hang level.
That being said, the car had unreal stearing (too much maybe), but off power the car would swap ends like nobody's business.
So here is my question, (understanding that stiffening the front/softening the rear...too much weight transfer to the front off power...etc...etc...) what exactly does a guy need to do to get some rear bite (car has rear traction on power). Looking at some setups on the net, it seems like guys are running harder tires in the rear or at least equal shore ratings, front and back and I ran 45's up front and 40's in the rear. ALso the rears were 0 offset and not the 2 degree offset.
Any ideas.
Thanks,
John
jjmudd is offline   Reply With Quote
Old 07-16-2006, 11:24 PM   #7526
John, to answer all of your questions without going too much into details here on the thread and pretty much writing an essay (PM me whenever you need help).... Disconnect the shocks and make sure you are getting good arm travel, the shocks might be limiting your arms travel. Also check your rear roll center, see where they're at.
Gold is the hardest springs for the RRR and that gives a lot of forward bite and tons of front steering, it also comes with the price of a loose rear. When you were driving, what were your droop settings F&R? How's the traction? Is the rear coming around going into the corner? Mid? Or coming out of the corner?
In case if you dont' know already... Kyosho springs are...
Gold--Black--Silver
Hard--Medium--Soft
As for tires, I've been running 40's all the way around for medium traction and 42F/40R for higher traction tracks. (This is for down the road.... once you have a good setup and running 45's front still has too much steering, Kyosho offers optional 1 and 2 degree knuckles, you can kill some steering using those knuckles as well.) But I would suggest try to figure out what you have right now.
As for the rear 0mm offset tires, the optional VSW007 will allow you to run 0mm offset tires, still maintain 200mm track width with plenty of your dogbones in the outdrive. Try to run 200mm track width in the back if possible.
Again, don't hesitate to ask any questions.
Dom
Old 07-16-2006, 11:44 PM   #7527
Trader Rating: 24 (100%+)
Talking
Any ideas.
Thanks,
John
Go back to stock setting and then go from there you do not know what kind of track he was runing on.(this car is no joke you will be very happy with it)
RANDY SMOOTH is offline   Reply With Quote
Old 07-17-2006, 12:27 AM   #7528
GREGORY!'s Avatar
One qhestion,can i use the PART:VSW035.alym.stay for front sway bar,on rrr
??This is an option for the FW05 RR...
GREGORY! is offline   Reply With Quote
Old 07-17-2006, 05:48 AM   #7529
isnt it
black-hard
gold-medium
silver-soft
ae_ntc3 is offline   Reply With Quote
Old 07-17-2006, 05:54 AM   #7530
Sp Racer's Avatar
isnt it
black-hard
gold-medium
silver-soft
Nope -
silver - soft
black - medium
gold - hard
10 yrs on RC tech ! wow....
Sp Racer is offline   Reply With Quote
FOR SALE - Mugen MBX5T ProSpec and Kyosho STR with chassis conversion and Kyosho big MattWells R/C Items: For Sale/Trade 5 04-28-2017 10:25 AM
1986 1/12 Kyosho Plazma MKIII With Kyosho LeMan 600E Motor Funkymojo R/C Items: For Sale/Trade 2 05-17-2012 11:11 AM
Custom painted Kyosho SP2 and Kyosho STRR bodies.... RC3 Graphics SWEET W/ PICS CRFXXXT R/C Items: For Sale/Trade 1 01-07-2008 07:38 PM
MACH. 28/NEW PS, KYOSHO MINI INFERNO ST/W/3NEW IB1400 8 CELL PACKS, KYOSHO 1./8 BUGGY newbie2 R/C Items: For Sale/Trade 5 11-18-2007 06:07 PM
Convert Kyosho Quick Start system on Kyosho QRC to Pullstart Morpheus2be Monster Trucks 0 02-16-2005 11:26 PM
