Old 07-12-2006, 09:16 AM   #7486
litespeed-dom's Avatar
Originally Posted by ziggy12345
Its for adjusting tweak. Use a tweak board and this adjustment become apparent
Ziggy is correct. And to elaborate a bit more...
When I setup droop (on the bench at home when I have plenty of time), I disconnect the shocks, loosen the front sway by the set screws and then push them out so they don't touch each other at all. Then do your droop setting on pit board/blocks. Once that's done, I push the bars back toward each other, that's when the little tab adjustment come in handy. I'll adjust the 2 tabs so that I make sure I'm retaining the same droop each side and full arms travel. Then I pop the shocks back on after I'm done.
Hope this helps.
Dom
Team Kyosho America - Team Br00d Racing - Team R/C Plus - GQ Racing Tyres - Slapmaster Tools - FSX Racing
litespeed-dom is offline   Reply With Quote
Old 07-12-2006, 09:24 AM   #7487
dodo's Avatar
Send a message via Yahoo to dodo
i think it won't differ so much in terms of CG. correct me if i'm wrong but the heaviest part of a servo lies at the bottom, so whether it's standup or laydown, the bottom part of the servo will still be at the bottom part of the chassis...
well it's just my opinion...
dodo is offline   Reply With Quote
Old 07-12-2006, 09:41 AM   #7488
I agree with you, my thought on the servo motor as well. Since the first pics of the EVO came out I've been saying the CG won't really make "that" much difference.
Dom
Old 07-12-2006, 09:57 AM   #7489
Munkmotion's Avatar
Originally Posted by jag
Do we know the standup servo is the "way to go" yet? Who has been using it... Josh, Marc, Ron, anybody?
What else is in the conversion kit?
Thanks for the info/update.
Rather than the top deck, I'm much more interested the revised two speed shaft and brake/pulley components, with the claimed easier maintenance, as the RRR as it stands now is uncharacteristically difficult to work on (compared to the rest of the rrr) in this area.
It does look very different, but does anyone know exactly how it is different?
Also, is it likely there will actually be a "kit" or just a list of part numbers you need to buy?
Munkmotion is offline   Reply With Quote
Old 07-12-2006, 10:13 AM   #7490
SOLOARTIST 702's Avatar
Send a message via AIM to SOLOARTIST 702
Default evo
Originally Posted by litespeed-dom
I honestly don't think I will be able to "feel" the difference when it comes down to the CG. I'm anticipating my brakes might feel a little different, hopefully a bit more modulation. Regardless whether it's the "way to go", I'll be doing the top deck conversion just because of the easy access to the throttle servo. And just because to try new things out, see it myself and put this whole "High servo CG" issue that everyone was complaining about to rest.
I'm anticipating the parts will be here next week.
Dom
glad to get the info i have 2 rrr i will change 1 to evo are conversion parts avail. yet
RC AMERICA / XRAY / HUDY/ MATRIX TIRES /KOPROPO / ORCAN GT3 /RED CUP RACING MEMBER / SPEEWORLD RACEWAY/ A+ performance parts /IVE SEEN THE XRAY TEAM DRIVE SO I GOT XRAY CARS / better to keep up than to catch up
WILLIAM PENDERGRASS
SOLOARTIST 702 is offline   Reply With Quote
Old 07-12-2006, 10:47 AM   #7491
Instead of having 1 pin holding the alu brake hub, another pin holding the pulley, the pulley is now installed using a set screw. Also the pulley has 2 prongs which the brake disc is mounted. Kinda like the setup on the Evolva.
As for if there will actually be a "kit", still waiting to answer.
Dom
Old 07-12-2006, 08:16 PM   #7492
V1-RRR-WC's Avatar
Default Front Diff
I am switching to the front diff from the spool. From what I have been reading and research done, the car should be alot easier to drive.
To some of the persons who are presently using the front diff and pleased with it, what wt oils you find works best?
50,000 wt
100,000 wt
120,000 wt
I am planing for a major event next weekend and don't have much time for trial & error.
Thanks in advance for this vital info!
V1-RRR-WC is offline   Reply With Quote
Old 07-12-2006, 09:26 PM   #7493
Team Kamikaze's Avatar
50,000 wt
100,000 wt
120,000 wt
50,000wt
Home of the Kamikaze Driver's Development Program = guaranteed podium finish
Kamikaze Toys and Hobbies Inc.
Follow us here on Facebook!
Team Kamikaze is offline   Reply With Quote
Old 07-12-2006, 09:27 PM   #7494
want an EVO?
Old 07-12-2006, 10:37 PM   #7495
V1-RRR-WC's Avatar
Originally Posted by Team Kamikaze
50,000wt
Thanks as always!!!
Old 07-12-2006, 11:22 PM   #7496
Thanks as always!!!
You are always welcome
Old 07-13-2006, 12:03 AM   #7497
I have just started doing some different combo of oil for front and rear diff recently. I went the opposite of what people would normally run... I did 30k front, 50k rear... worked pretty good surprisingly.
I'm having parts for another set of diffs coming so I can just do back to back testing w/o too much time wasted changing oil. Different combos with front spool, 30k & 50k front, 30k/40k/50k rear.
Dom
Old 07-13-2006, 12:24 AM   #7498
ziggy12345's Avatar
50,000 wt
100,000 wt
120,000 wt
60K. I did some testing and found the front diff easier to drive than the spool and the one way, it was more consistent.
Cheers
Dedicated RC Car Speed Site
http://www.fast-rc.co.uk/forum/index.php
Sponsored by:
Norfolk and Chance
ziggy12345 is offline   Reply With Quote
Old 07-13-2006, 12:28 AM   #7499
Default huh
want an EVO?
ive got 2triple Rs i can make one an evo
WILLIAM PENDERGRASS
Old 07-13-2006, 01:34 AM   #7500
Here's a brand new EVO for sale....
http://cgi.ebay.com/Brand-New-V-One-...QQcmdZViewItem
I think luketob is on this board too.
Dom
FOR SALE - Mugen MBX5T ProSpec and Kyosho STR with chassis conversion and Kyosho big MattWells R/C Items: For Sale/Trade 5 04-28-2017 10:25 AM
1986 1/12 Kyosho Plazma MKIII With Kyosho LeMan 600E Motor Funkymojo R/C Items: For Sale/Trade 2 05-17-2012 11:11 AM
Custom painted Kyosho SP2 and Kyosho STRR bodies.... RC3 Graphics SWEET W/ PICS CRFXXXT R/C Items: For Sale/Trade 1 01-07-2008 07:38 PM
MACH. 28/NEW PS, KYOSHO MINI INFERNO ST/W/3NEW IB1400 8 CELL PACKS, KYOSHO 1./8 BUGGY newbie2 R/C Items: For Sale/Trade 5 11-18-2007 06:07 PM
Convert Kyosho Quick Start system on Kyosho QRC to Pullstart Morpheus2be Monster Trucks 0 02-16-2005 11:26 PM
