Old 06-30-2006, 02:06 AM   #7381
Hoggy's Avatar
Trader Rating: 26 (100%+)
Hey all just got a RRR With an OS 12TZ3p just wondering if anyone could give me a basic set up for low grip asphalt. like springs, cambers, toe in toe out.
Thanks in advance.
Hoggy is offline   Reply With Quote
Old 06-30-2006, 04:29 AM   #7382
Ice_nl's Avatar
Send a message via MSN to Ice_nl
Originally Posted by Osiris 75
Yep, I installed the front diff, and that's when I noticed the problem. I used the exact out drives the manual mentioned, and it was running fine. All of the sudden the dog bone is barely in the cup, and it starts the front tire to start wobbling. When I try try to maybe pull out the cup a little, it doesn't budge.
Did you find a way to solve the problem? I tried setting track width narrower at the front, from 199 to 194, but it didn't help. I bought a new set of out drives, but from your reply it sounds like something else must be the problem and the new out drives will have the same problem?
Here is a pic of the diff with the damaged out drive, this happened the first time i ran a diff in a club race.
I hope i can fix this before Sunday as i want to see if i am driving better with an diff at the Heemstede track. Last time i was there it was wet and i had to run a one way because i didn't had a diff yet.
RC-Models.nl | Shepherd Velox V8 EC OM-Edition | Shepherd Velox F1 | Buri Racer E1.2 | Tamiya 419x
Ice_nl is offline   Reply With Quote
Old 06-30-2006, 07:28 AM   #7383
maskedrider's Avatar
Originally Posted by markp27
Hi,
The Heemstede track is very fast with a very long straight. The engine was all revved out with the 22T 2nd gear, so I changed to the 23, which was perfect. Also there are a couple of very tight corners which require some delicate throttle control, so I put the 17T on the first gear, so that the car didn't accelerate so sharply in those corners. The 61 and 55 were just fine tuning.
Cheers, Mark.
got it understand...may try it out as my local track is quite similar to Heemstede.. HAve a super long straight and some tight corner...
Kyosho- Sirio/ OS engine- AVID bearing- Blue thunder fuel- Proline- RC dynamite- Sanwa- RC Art
maskedrider is offline   Reply With Quote
Old 06-30-2006, 07:54 AM   #7384
Osiris 75's Avatar
Trader Rating: 17 (100%+)
I'll try it out tonight, but even when i tried to adjust the width, it was still right at the edge of the cup. I might just have to go back to the one way!!
SPONSORS: AWESOMATIX USA / HOBBYWING USA / AVID CONCEPTS / R1 WURKS / POWERMASTER FUELS (VP RACING) / 2MM DESIGNS
RC TARGET/CAPRICORN USA / REFLEX RACING / ULTI TIRES
Chris Kemper
Osiris 75 is offline   Reply With Quote
Old 06-30-2006, 09:14 AM   #7385
litespeed-dom's Avatar
I just snapped a quick pics here before I got into work... is your outdrive/cvd installed look like this???
Dom
p.s. I do have to change the bone on my CVD though, the pin is wearing down.
Team Kyosho America - Team Br00d Racing - Team R/C Plus - GQ Racing Tyres - Slapmaster Tools - FSX Racing
litespeed-dom is offline   Reply With Quote
Old 06-30-2006, 10:14 AM   #7386
Osiris 75's Avatar
Dom
The pin is sitting right at the tip of the cup. It was looking like your picture, but now it's not.
Chris Kemper
Old 06-30-2006, 10:20 AM   #7387
So when you initially installed it it looks like that but now it is not??? I'm a bit confused. Why would it not be on the same location now?
Dom
Old 06-30-2006, 11:29 AM   #7388
kidDynomite's Avatar
orisis, are you sure your measurements are under 200mm? What tires are you running and what offset?
VZ218 seems to be the right diff joints. Are you sure you didn't accidentally put the rear univ. in the front?
Not trying to knock ya, just trying to help you solve this. It should sit just like in Dom's shot.
kidDynomite is offline   Reply With Quote
Old 06-30-2006, 11:58 AM   #7389
Ice_nl's Avatar
mine where also sitting at the edge, not like in the picture. I also checked the universals and they are the right ones.
Old 06-30-2006, 12:05 PM   #7390
Ok, something isn't right then. I suspect the bone.
I guess the only way we can find out is to measure the CVD bone. You guys measure yours and post it and I'll go home and measure mine and the NIP I have as well. And I'll post it tonight.
Dom
Old 06-30-2006, 12:06 PM   #7391
Osiris 75's Avatar
Dom
Well, would a different tire offset maybe cause it??
Chris Kemper
Old 06-30-2006, 12:10 PM   #7392
Osiris 75's Avatar
No problem. It was working fine initially, and now it's not. Maybe it's because I was using different tires on the front!!!!! I'll have to check..
Chris Kemper
Old 06-30-2006, 12:13 PM   #7393
If you use a 1mm or 2mm offset front wheels, you would have to crank the pivot balls in further to get 199 or 200mm track width, so the CVDs would have moved in further anyway....
Unless your wheels have offset the other way, that'll require you to turn the pivot balls out....
If you can take a picture of half of the entire front end, maybe we can see if something is out of place.... without a picture it's hard to figure out.
Dom
Old 06-30-2006, 12:27 PM   #7394
OVA
OVA's Avatar
Trader Rating: 79 (100%+)
Dom
Mine works fine..... It look like the one in the Pics ...Why I don't know
I have not failed. I've just found 10,000 ways that won't work
OVA is offline   Reply With Quote
Old 06-30-2006, 12:32 PM   #7395
Dom
Osiris, Doms right. Measure your bone because size does matter.
OVA, you should be OK with the women.
FOR SALE - Mugen MBX5T ProSpec and Kyosho STR with chassis conversion and Kyosho big MattWells R/C Items: For Sale/Trade 5 04-28-2017 10:25 AM
1986 1/12 Kyosho Plazma MKIII With Kyosho LeMan 600E Motor Funkymojo R/C Items: For Sale/Trade 2 05-17-2012 11:11 AM
Custom painted Kyosho SP2 and Kyosho STRR bodies.... RC3 Graphics SWEET W/ PICS CRFXXXT R/C Items: For Sale/Trade 1 01-07-2008 07:38 PM
MACH. 28/NEW PS, KYOSHO MINI INFERNO ST/W/3NEW IB1400 8 CELL PACKS, KYOSHO 1./8 BUGGY newbie2 R/C Items: For Sale/Trade 5 11-18-2007 06:07 PM
Convert Kyosho Quick Start system on Kyosho QRC to Pullstart Morpheus2be Monster Trucks 0 02-16-2005 11:26 PM
